Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Nov 05, 2009, 07:46 AM   #1
Reto
new spoilers for scale sailplanes
Hello Folks
I just found this spoilers that come with an integrated actuator (kind of an inline proportional servo):
http://www.topmodel.co.jp/150_1869.html
Elektrische Landeklappen (1 min 5 sec)
I think this is a very good idea.
First you don't need additional openings in the wing for normal servos that are linked with conventional spoilers. Installation in a wing should be straight forward.
You don't have to do cumbersome linkage between a servo and the spoilers.
Two of these spoilers should move synchronously automatically, so you don't need any mixing on the radio (or adjustements on the linkage).
Best regards:
Reto
RetoF3X is offline Find More Posts by RetoF3X   Reply With Quote
Old Nov 05, 2009, 12:51 PM   #2
any dealers in US?
The web site given is Japanese, yet the video is German. Do you know who the manufacturer is and whether there is a dealer in the US? Looks good to me, without the slop I've come to deal with on other metal spoilers.
Scott
shinck is offline Find More Posts by shinck   Reply With Quote
Old Nov 05, 2009, 01:04 PM   #3
yyz
yyz's Avatar
Those look a *lot* like the Graupner Teck brakes w/ linear actuators added. Like the idea. Wonder if the choppy actuation is an operator thing? It looked a little rough to my eye.
Look forward to a report,
EDIT: I take the "choppy" comment back. I listened to the video more carefully and they look and sound fine. Great idea.
yyz is offline Find More Posts by yyz   Reply With Quote
Old Nov 05, 2009, 01:53 PM   #4
Challenge is rewarding
djklein21's Avatar
yep, 10-1 the choppy sound is the ratchet on the Tx gimbal
djklein21 is online now Find More Posts by djklein21   Reply With Quote
Old Nov 05, 2009, 02:23 PM   #5
Very cool. BUT, what if the motor fails after these are built into a model, when a servo goes bad you can replace the drive mechanism, but these look integrated, I would hesitate using them because of that.
s2000 is offline Find More Posts by s2000   Reply With Quote
Old Nov 05, 2009, 02:34 PM   #6
I thought about that also, but I have never had a servo fail on a spoiler. Usually the spoiler, servo, and wing has met an untimely end so I don't have to worry
Old Nov 05, 2009, 02:34 PM   #7
yyz
yyz's Avatar
The third paragraph thoroughly covers replacing the actuator:
スポイラーとモーター、ギアなどの駆動部分が一体になったため、専用サーボや面倒なピアノ線のリンケージが 不要。 独自のロック機構で格納ポジションにある時はモーター駆動電流は流れず、それでいてスポイラーが吸い出され ることもありません。
また、取り付けは至って簡単、本体を主翼に埋め込み、受信機のエンコンチャンネルなどにELFスポイラーの コードを挿すだけであなたのグライダーがスポイラー付きに変身する。
スポイラー部は制動効果の高い2枚ブレードで、着陸の難しいスケールグライダーや高性能グライ ダーに最適。
1セット左用、右用各1本入り。
<データ>
形式:電動式駆動装置内蔵スポイラー
全長:(全幅)300mm(電動駆動部含む、リード線含まず)
ブレード収納部:長さ250mmx高さ(主翼に入る深さ)10mmx幅9mm
スポイラーブレード最大幅:250mm
スポイラー展開時の最大高さ(主翼上面より):20mm
重量:38g(コード含む)
動作電圧:4.8V〜6.0V(ニッカド、ニッケル水素4本パック)
動作パルス幅:ポジティブパルス 1.5±0.3μs
リード線の長さ(JRタイプコネクタ付):約400mm
Old Nov 05, 2009, 02:40 PM   #8
Working on your standup routine, I see
Old Nov 05, 2009, 02:45 PM   #9
Vini, Vidi, Scalies
LoopingFred's Avatar
Hi,
Available in Germany at Staufenbiel HERE and equiped their latest gliders, like the ask13 (very nice one by the way! )
A bit expensive for a pair of 250mm IMO...
Fred
LoopingFred is offline Find More Posts by LoopingFred   Reply With Quote
Old Nov 05, 2009, 04:02 PM   #10
Electric Airplane Junkie
bhchan's Avatar
They are Pilot brand. At the current exchange rate they are a little over 105.00 US$ a pair. Not bad for the set up, considered a pair of Graupner spoilers is about 40-50.00 and 2 servos.
Brian, an EAJ
bhchan is online now Find More Posts by bhchan   Reply With Quote
Old Nov 05, 2009, 04:11 PM   #11
The SKY MAN's Avatar
The scale model that i'm building at the mo would require four of these!
Too much money
The SKY MAN is offline Find More Posts by The SKY MAN   Reply With Quote
Old Nov 05, 2009, 05:13 PM   #12
And you would still need a hole in the bottom of the wing to access replacing the motor, until I see one I'll stick with a servo driven sytem. Neat idea though!
Old Nov 05, 2009, 11:15 PM   #13
cheyenne's Avatar
Maxx products had them at the I Hobby Show in Chicago. Only one size, but he said they are working on a larger version.
cheyenne is offline Find More Posts by cheyenne   Reply With Quote
Old Nov 06, 2009, 01:04 AM   #14
bhchan's Avatar
Was there a price on them at the show?
Brian, an EAJ
Old Nov 06, 2009, 01:43 AM
nicolezhu85
An infraction has been given for this post.  Infraction type: Excessive advertising (Spam)
Sold 1/4 scale Landing Gear for a Scale Glider New gliders Aircraft - Sailplanes (FS/W) 1 Sep 03, 2009 10:52 AM
Sold 1/5 scale Landing Gear for a Scale Glider New gliders Aircraft - Sailplanes (FS/W) 1 Sep 03, 2009 10:51 AM
Discussion Spoilers for DAW Ka6? harrye Slope 2 Aug 24, 2009 03:13 AM
Bored? Want to fight?
Join the RCGroups clan!
