| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Wonderfully Wicked
ESC settings you use for you Wicked EDF motors
I have many people who ask what ESC settings to use. There are so many ESC brands out there it is impossible to keep up with them all so that is the main reason why I recommend only using the Pentium ESCs as I know it works and the cost is quite reasonable. However, other ESCs such as the Castle Creations Phoenix, and Thunderbird series work just fine. What I would like is for people who have a Wicked EDF motor to please post what ESC they are using and and ESC settings or firmware they have so we can have a database of what works and for what setup.
For the Hobbywing Pentium ESCs I use the following on all Wicked versions with 3S or 4S: low timing normal startup no brake So if you have another brand ESC please post what settings you are using and what KV motor you have as well as 3S or 4S lipo and what fan unit. Also I wanted to point out ESCS to avoid. ESCS to AVOID Electrifly Series Suppo ESCs Rebranded Suppos ESC listed on Ebay under the name of "Mystery Pentium" (has big heat sink on it which the Hobbywing Pentium 40, 60 and 80 amp ESCs do not have.) I will add more to this list as I find out. The issues on these ESCs is what is the RPM*pole limit. The Pentium ESCs have a rpm*pole limit of 420,000. So a 6 pole motor can run up to 420,000/6 = 70,000 rpm. A 2 pole motor can run up to 420,000/2= 210,000 rpm. Many of the lower cost ESCs are below 280,000 so they can only spin up the wicked to 46,000 rpm. Most 4s setups are higher than this RPM so that is why the ESC can not be used. It may be possible on 3S to use them, provided the rpm is low enough. Don |
#2 |
Don when you say low timing what degree to you know. My Eflite has a few low setting.
| Thread Tools | |
| Discussion Schulze Lipodimatic Battery Monitor Settings for High Power EDF? | Gordon | Electric Ducted Fan Jet Talk | 0 | Oct 25, 2009 12:43 PM |
| Discussion What Timing Settings to use for EDF motors? | fooyukvoon | Power Systems | 8 | Sep 26, 2009 05:58 PM |
| New Product DonsRC Wicked EDF and Wicked EDF Extreme Motors | The Don | Product Announcements | 43 | Jan 04, 2009 01:42 PM |
| Sold GWS ME262 Kit with Wicked EDF motors and ESC | The Don | Aircraft - Electric - Jets (FS/W) | 0 | Oct 07, 2008 11:25 PM |
| For Sale Garage Sale MOTORS and ESC's all NEW!! LSJS /Dons Wicked EDF | jet_jer | Aircraft - Electric - Power Systems (FS/W) | 11 | Mar 19, 2008 04:46 PM |
