Go Back   RC Groups > Aircraft - Exotic and Special Interest > Free Flight
Old Nov 04, 2009, 09:42 PM   #1
Gee Bee Fanatic!
skyline223's Avatar
Electric Free Flight?
How would you go about doing an electric free flight model? Not RC, but simply substituting an electric motor for rubber bands. Of course this has been done, but I simply want to know what setup you guys are using.
skyline223 is offline Find More Posts by skyline223   Reply With Quote
Old Nov 04, 2009, 11:29 PM   #2
I'd like to know the same thing.
Kev
kevin matthews is offline Find More Posts by kevin matthews   Reply With Quote
Old Nov 04, 2009, 11:54 PM   #3
I never did one but think I know how I might go about it. First I would measure the thrust the rubber setup was developing. Since weight is an issue I would go with a dc brushed motor and battery as you need nothing to change the dc to pulsating dc to drive the brushless motor.A brushless motor has to have a separate device.
Once required thrust was established start examining obsolite gws type motors or specialty suppliers of simular geared type motors. In most cases you want to turn a simlar size prop at about the same revolutions if the plane flew well under it's rubber set up. Or turn it faster with a much lesser pitch. So I would tach the original blade under rubber power to find the rpms.
.As you said hopefully someone who has actually done it may contribute to your thread.
barry wilson is offline Find More Posts by barry wilson   Reply With Quote
Old Nov 05, 2009, 05:08 AM   #4
I think you'll have to be a bit more definite about what information you need and what type of models you're interested in.
I mainly make small indoor models from scratch and they just use a geared motor, a lipo battery and a timer. I make my own timers but you can buy them from various places. The motors and batteries mainly come from RC toys like Palm-Z/AeroAce planes and Picooz helis.
For bigger outdoor stuff the old GWS motors are a good place to start as Barry says. I'm not sure I'd bother with what the original rubber motor and props do, I'm more likely to look at what similar size RC models use and start there. But I'm only interested in sport flying. I guess if you were doing something competetive you'd want to get a lot more technical.
Steve
slipstick is offline Find More Posts by slipstick   Reply With Quote
Old Nov 05, 2009, 08:05 AM   #5
Gee Bee Fanatic!
skyline223's Avatar
Well the plane is a Guillows 20" Piper Super Cub. It honestly didnt fly very well under the rubber setup. I believe the plane is a bit too heavy for the rubber power - thats why I was asking about electric power.
Old Nov 05, 2009, 09:15 AM   #6
For something that size I think I'd try the motor and gearbox out of a Parkzone Ember with a single lipo cell 70-130mAh and timer. Apart from the timer you can buy the bits as Parkzone spares. The timer (and a wide choice of alternative motors) you can get from somewhere like BSD http://www.bsdmicrorc.com/ (look under Misc Electronics).
But it really depends on how heavy we're talking about. If you get too heavy for a given wing area you're never going to get anything to fly well regardless of the power source.
Steve
Old Nov 05, 2009, 10:02 AM   #7
scrubs's Avatar
I consider the small GWS LPS motors as anything but obsolete for FF. For RC you need a speed controller anyway but not so with FF. So if I can save those few grams I will. And this also means less cost for something that may go OOS.
I use the smallest LPS motors in 24-30" sport FF jobs. Here's a 27" Rambler with a N20 that I later converted to the 4:1 LPS, a 2 cell 250 lipo and a Rees timer.
bill
  • Name: rambler.jpg
scrubs is offline Find More Posts by scrubs   Reply With Quote
Old Nov 05, 2009, 10:04 AM   #8
Gee Bee Fanatic!
skyline223's Avatar
Ive seen people try to fly it using the sukhoi/ember power setup here on RCG but they have all failed. I wonder if the power system out of one of those old air hogs electric free flights would work? Probably not...
http://www.amazon.com/Air-Hogs-Quick...7433377&sr=1-3
Old Nov 05, 2009, 10:08 AM   #9
scrubs's Avatar
For your 20" Guillows I'd use a Kenway N20 4:1 or a 7mm SS motor in a BSD gearbox.
bill
Old Nov 05, 2009, 10:09 AM   #10
Gee Bee Fanatic!
skyline223's Avatar
Scrubs - something like this?
http://www3.towerhobbies.com/cgi-bin...?&I=LXHHJ9&P=7
Old Nov 05, 2009, 10:28 AM   #11
*jj
You will need a special electronic timer, such as the one from Atomic Workshop, called the Zombie. This takes the current from the battery to the motor. There are other types of timer, such as that from K&P, which use an ECU and replace an RC receiver, which can replace a diesel for larger FF models. Some types of timer have a second channel to control a dethermaliser.
*jj is offline Find More Posts by *jj   Reply With Quote
Old Nov 05, 2009, 10:52 AM   #12
scrubs's Avatar
Originally Posted by skyline223 View Post
Nope more like this (2nd one down, N20 motor):
http://www.kenwaymicroflight.com/motors_etc.htm
And a timer similar to this (pink one):
http://www.kenwaymicroflight.com/batterieschargers.htm
And a single cell lipo and charger. If you don't want the expense you could also use the 50 mah Nicads he sells (3). Then you charge after every flight and don't need a timer. I think there are still field chargers available that use D cell batteries for charging the Nicads for only a few bucks.
Down side of the Nicad setup is they are harder to find now and weigh more. Three nicads are about 11 gms in a pack, the lipo maybe 3-5 gms.
BSD micro will steer you right as will Kenway.
bill
Old Nov 05, 2009, 11:03 AM   #13
Gee Bee Fanatic!
skyline223's Avatar
Thanks a ton scrubs. I will look into those
Old Nov 05, 2009, 05:18 PM   #14
jj had the best advice for ya, atomicworkshop.co.uk their systems are free flight specific setups
skootertrash74 is offline Find More Posts by skootertrash74   Reply With Quote
Old Nov 05, 2009, 05:24 PM   #15
Intermediate Multi
Trisquire's Avatar
Does Hi-Line still make the little gear drives for two nicads? They just ran until the power was depleted. Don Srull did a few construction articles on Hi-Line powered planes in MA magazine.
Tom
Trisquire is offline Find More Posts by Trisquire   Reply With Quote
Discussion Electric Free Flight.Com freeflightguy Hot Online Deals 0 Oct 01, 2009 11:29 AM
Discussion free flight safety feature question? stegla DIY Electronics 15 Sep 04, 2009 11:38 AM
Alert EBAY; a bunch of 40+ year old free flight, rubber powered, kits. old_dude Hot Online Deals 4 Aug 29, 2009 01:13 PM
Discussion Electric Free Flight Supplies freeflightguy Hot Online Deals 0 Aug 28, 2009 01:12 PM
Bored? Want to fight?
Join the RCGroups clan!
