Old Dec 20, 2011, 08:49 AM
Ranfred Radius is offline
Find More Posts by Ranfred Radius
Ranfred Radius's Avatar
Central Point, OR.
Joined May 2002
Originally Posted by bchristensen View Post
I like those big ol' bush tires..
Brian
Brian
Those are Du-Bro 8" wheels. Yes they look sorta cool but they are a bit heavy. Originally I had a 26" two blade prop installed with Du-Bro 6" inflatable tires. Kept experiencing prop strikes! Then I went up to the 8" solids and a 25" Mejzlik three blade. Took care of that problem!
Len
Sharp looking Porter you got there! Looks first class!
Randy
Ranfred Radius is offline Find More Posts by Ranfred Radius
Old Dec 20, 2011, 11:28 AM
bchristensen is offline
Find More Posts by bchristensen
Flying the point of the mtn.
bchristensen's Avatar
Draper, Utah
Joined Sep 2008
I've got the 7" tires and a 27" blade. No strikes yet but it's close! Just got a 26" x 14 pitch 3-blade that I'm going to try. Just haven't maxed out that electric A150-8 yet so I'm still playing with different options. I might need to throw 8" wheels soon.
Brian
bchristensen is offline Find More Posts by bchristensen
Old Dec 23, 2011, 11:09 AM
toberd is offline
Find More Posts by toberd
Tarpon Springs, FL
Joined May 2008
Wing installation problem
Received my 3.2 meter kit a couple of weeks ago. Was very impressed overall with the quality and workmanship. Everything seemed to fit perfectly. However, today I tried to plug in my wings for the first time. Disaster!! The metal spar will not go very far into the wings before binding severely. I can only get it into one wing about 3 inches, the other wing about 4 inches. I have tried everything I can think of, and worked for hours with a file as far into the wing as I can go, with little results.
Has anyone else run into this? Is there a fix that doesn't require tearing the wings apart and rebuilding them? Any help would be appreciated.
toberd is offline Find More Posts by toberd
Old Dec 23, 2011, 03:55 PM
mwgib123 is offline
Find More Posts by mwgib123
Soar Tow 2
mwgib123's Avatar
West Jordan Utah
Joined Jul 2006
wings
Mine was the same way. I was able to plug mine in abour 6 in each. I belt sanded the metal down about 1/16 in to get one in the other I had to taper the end a little more. the only place that needs to be tight is right at the fuse, the wing struts carry the load out to the tip. I also marked left and right on the bar to aid in assembly at the field.
send some pics of the build..
mwgib123 is offline Find More Posts by mwgib123
Old Dec 23, 2011, 04:49 PM
toberd is offline
Tarpon Springs, FL
Joined May 2008
Re: Wings
Was finally able to get the wings on. Went to Home Depot and got a long file (about 15"), and working it in and out of the slot for about 2 hours finally got it to where the spars would go in. Total time on this project (plugging in wings) was about 5 hours. Oh well, everything else has fit so far, so I shouldn't complain.
Old Dec 23, 2011, 05:00 PM
SteveR is online now
Find More Posts by SteveR
New York
Joined Feb 2002
The other approach is to construct a plywood sanding stick the general shape of the joiner blade and face it with sandpaper. That's how I made my wings fit.
Steve
SteveR is online now Find More Posts by SteveR
Old Dec 23, 2011, 08:04 PM
Draper, Utah
Joined Sep 2008
Mine was a little tight, and actually still is a little tight but it did go all the way on. One wing is tighter than the other so I just plug the spar into that wing and then into the fuse. I don't leave the spar in the fuse.
I sanded the metal down a little, then faced some wood and sanded the wing inside. Worked great. I actually roughed up the wing spar itself near the end and used it as a sander in the wing slot. 4 or 5 passes made it much easier to get it all the way in without breaking the wing or pinching the wing so tight you about go through the ultrakote.
It might get tight again when the weather warms up.. I'll probably have to sand more since I hear that many of the planes had this problem.
Brian
Old Dec 23, 2011, 11:26 PM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Wow, Sorry to hear that issue guys, I've had three and never and issue. I guess I was lucky.
Glad to hear you worked it all out. Good luck with the rest of the build. What are your power plant plans? ( say that three times fast )
LEN
rcAerotowing.com
Lbuff1 is offline Find More Posts by Lbuff1
Old Dec 24, 2011, 08:55 AM
toberd is offline
Tarpon Springs, FL
Joined May 2008
Power for mine is currently an existing Hacker A80-10, Castle 160 controller, 12S batteries and a 25x12 prop package (previously 1/2 of a package used on large twin). Will not be used for towing, I have other plans. Will see how it flies on the above.
Old Dec 24, 2011, 05:29 PM
Draper, Utah
Joined Sep 2008
I just put a carbon 3 blade 26x14 on the hacker a150-8 with 12s and I think I've nearly doubled the thrust. Haven't got it in the air yet. Had to do some re-covering so took the time to make a few changes...
Old Dec 24, 2011, 06:40 PM
iflytailies is offline
Find More Posts by iflytailies
aka Schleppmeister
PA
Joined Feb 2006
How many amps are you pulling now?
iflytailies is offline Find More Posts by iflytailies
Old Dec 24, 2011, 07:25 PM
hmarshall is offline
Find More Posts by hmarshall
Been there, Crashed that.
hmarshall's Avatar
Fayetteville, Arkansas
Joined Nov 2006
Steve
Thats what I did as well. Also sanded the metal abit with 600 or about to smooth it... but it was the stick did the trick.
hmarshall is offline Find More Posts by hmarshall
Old Dec 25, 2011, 12:03 AM
Draper, Utah
Joined Sep 2008
Not sure on the amps yet. I can only bench test the plane for now with the weather so cold outside. Next week looks to be good weather so I'll get it out and check the amps. I just know that on a single 6s battery I createded a mini tornado inside my shop room. The 27 x 12 carbon kicked up some wind but nothing like this 3-blade. I've heard disappointed comments on the 3 blade but the added pitch made a noticeable difference and the motor seemed to strain a bit more which is good because there was minimal strain with the 27x12 recommended prop at 12s and the amps were very low.
Old Jan 01, 2012, 08:40 PM
Don VG is offline
Find More Posts by Don VG
Joined Oct 2010
Porter Repaired
Happy New Year Everyone
Got the porter repaired and test flown today. What a great day in San Diego today 75 Deg. Thanks Len for the front Wind Screen. It fit great. We plan to do some towing tomorrow and having a great day of it. Repaired the tail wheel by bonding some G10 board to the top of the carbon. Made for a good repair.
Don
Don VG is offline Find More Posts by Don VG
Old Jan 01, 2012, 08:46 PM
mwgib123 is offline
Soar Tow 2
mwgib123's Avatar
West Jordan Utah
Joined Jul 2006
Nice repair Don, I cant even tell it was repaired.
mike
Estar models Pilatus Turbo Porter build Part 2 Michael Heer Parkflyers 306 Sep 30, 2011 04:15 AM
Discussion 3.2m (126in) Pilatus PC-6 Porter with 12kW fdix Giant Electric Planes 47 May 09, 2011 10:21 PM
New Product Electric Pilatus Porter PC-6 sarg96 Electric Warbirds 64 Aug 26, 2010 05:53 PM
For Sale Pilatus Porter 2.4M New in Box - HUGE ptlpc Aircraft - Fuel - Airplanes (FS/W) 4 Oct 07, 2005 01:33 PM
