Old Mar 24, 2010, 08:26 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Len, photos tomorrow. Just glued the plywood tongue into the fuse.
Charlie, I'm using HS-985MG servos on all surfaces. I think they offer a great combination of speed and torque: 144 oz inches/.16 sec. 60 degrees on 4.8 volts. You could use the digital versions (7985) but I don't think there's any real advantage in this application.
Steve
SteveR is offline Find More Posts by SteveR
Old Mar 24, 2010, 08:30 PM
creeve is offline
Find More Posts by creeve
Corner Ketch, DE
Joined Sep 2005
Steve I was going to use 645mg do you think these are good enough
creeve is offline Find More Posts by creeve
Old Mar 24, 2010, 08:43 PM
SteveR is offline
New York
Joined Feb 2002
Charlie, I'm sure they'll do a fine job. I just prefer more speed (.16 vs. .24) and more torque (144 vs. 107) at 4.8 volts.
Are these differences truly noticeable? Ask 12 guys and you'll get 12 different opinions. Of course running at 6 volts you pick up more speed and torque.
My 2 cents,
Steve
Old Mar 24, 2010, 08:51 PM
Lbuff1 is online now
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Charlie, My tug has 645mg's throughout the plane except the throttle and choke, they are standard 821's
I would recommend upgrading the flap servos though, I plan to upgrade the flaps servos in mine this week.
hope this helps.
len
Lbuff1 is online now Find More Posts by Lbuff1
Old Mar 24, 2010, 08:55 PM
creeve is offline
Corner Ketch, DE
Joined Sep 2005
Steve your 2cents are worth $1000.00 to all of us
Thanks for the input
I am changing to the 985mg hopefully G-Force will not mind my order change
I called Tony today to place the order so it should not be a big deal
My AMR 50 gasser is ready to go , 80zdz with a Mez 24 /10
Nice power , Will test on tow Sunday
Charlie
Old Mar 25, 2010, 12:20 AM
MadCap231ex is offline
Find More Posts by MadCap231ex
Go Oregon Football!
MadCap231ex's Avatar
Talent OR
Joined Nov 2007
Servos
We use 5955's for rudder and elevators, 5985's on the ailerons, 5625's for flaps, and a 5645 for the throttle. The tow release will be a DS20-UMD Hyperion.
I really like the roll authority and with 5955's at the tail, we should not get too much feedback from the tow line.
Matt
MadCap231ex is offline Find More Posts by MadCap231ex
Old Mar 25, 2010, 09:42 AM
Go Oregon Football!
Talent OR
Joined Nov 2007
Flaps
Originally Posted by Lbuff1 View Post
I would recommend upgrading the flap servos though,...
len
Len,
What problems are you having with the flaps using the 645's?
Ours seem to hold well and that is even having them fully deployed at about 60 degrees down. I am using a the 5625 that has lower torque than your 645.
I programmed in 29% down elevator with flaps at or past 45 degrees to keep the Porter from ballooning up after flap deployment.
Matt
Old Apr 01, 2010, 10:38 PM
Ranfred Radius is offline
Find More Posts by Ranfred Radius
Ranfred Radius's Avatar
Central Point, OR.
Joined May 2002
These babies should keep my prop out of the rocks!
Randy
Ranfred Radius is offline Find More Posts by Ranfred Radius
Old Apr 01, 2010, 10:40 PM
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Will the Axle be long enough?
Old Apr 01, 2010, 11:21 PM
Central Point, OR.
Joined May 2002
Len
Why don't you think of these things for me before I go and make a fool of myself?!
Randy
Old Apr 02, 2010, 05:25 AM
SteveR is offline
New York
Joined Feb 2002
What about sleeving the axles with the appropriate metric size brass tubes to extend the length, then drilling a cross hole to secure the wheel with a cotter pin, a technique used in some scale applications. This assumes you just need a small extension to the axle to get the job done. Comments?
Steve
Old Apr 02, 2010, 08:07 AM
Central Point, OR.
Joined May 2002
Thats what I thought of(the concept anyway)while staring at the ceiling at 3AM..! Thanks Steve, for the how to!
I probably only need about a half an inch more...
I guess I did not think through, all the things that would have to be modified on the Porter when hanging a bigger engine on the nose...
Randy
Old Apr 02, 2010, 08:17 AM
SteveR is offline
New York
Joined Feb 2002
Randy, I think one of the aspects that makes this hobby so engaging is the willingness for many of us to try new things, to stray off the beaten path and be willing to risk creating new problems to solve in the pursuing new ideas, then to stay up to til all hours figuring out a good solution.
My wife never understands why this hobby offers me so much enjoyment as I spend so much time figuring out new solutions to lots of building/fling problems. Sometimes I don't either!
Can't wait until my Porter is airborne, too.
Regards,
Steve
Old Apr 02, 2010, 10:14 AM
mwgib123 is offline
Find More Posts by mwgib123
Soar Tow 2
mwgib123's Avatar
West Jordan Utah
Joined Jul 2006
now that is a big tire wow. now the porter will look like an Alaska tundra plane. my six inch (im talking about tires now) were almost too wide, now 8". send some pics so I can see what it looks like, I might want to do the same thing.
MIke
mwgib123 is offline Find More Posts by mwgib123
Estar models Pilatus Turbo Porter build Part 2 Michael Heer Parkflyers 306 Sep 30, 2011 04:15 AM
Discussion 3.2m (126in) Pilatus PC-6 Porter with 12kW fdix Giant Electric Planes 47 May 09, 2011 10:21 PM
New Product Electric Pilatus Porter PC-6 sarg96 Electric Warbirds 64 Aug 26, 2010 05:53 PM
For Sale Pilatus Porter 2.4M New in Box - HUGE ptlpc Aircraft - Fuel - Airplanes (FS/W) 4 Oct 07, 2005 01:33 PM
