Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis
View Poll Results: What would you want in a Brushless MSR
Main Motor 35 25.55%
Main and Tail Motor 82 59.85%
All In One Converter / ESC 57 41.61%
Seperate Converter / ESC 12 8.76%
Carbon Fiber Mounts for Main Motors 28 20.44%
Carbon Fiber Mounts for Tail Motors 21 15.33%
More Thrust Shortened Flight Time 13 9.49%
Long Flight Time Standard Thrust 43 31.39%
Lighter Weight than Stock, Standard Performance 10 7.30%
Equal or slightly more Weight, Great Performance 53 38.69%
Multiple Choice Poll. Voters: 137. You may not vote on this poll
Old Nov 04, 2009, 07:32 AM   #1
Yes I looped the MSR post 5388
EatAtJoes's Avatar
E-Flite Blade MSR Brushless Upgrades
Guys, I thought about starting a thread just for Brushless Upgrades to the E-Flite Blade MSR.
The reason is I didnt want to do this in the main thread was to keep this type of chat away from any of the Newbies attempting to dramatically modify this already perfect little Heli.
This is just for us Hard Core Tinkerers that simply love the challenge.
I am sure as we go along we will find many way to better the brushless setup
EatAtJoes is offline Find More Posts by EatAtJoes   Reply With Quote
Old Nov 04, 2009, 07:33 AM   #2
EatAtJoes's Avatar
My First Setup
Parts List
$15.99 AP03 7500KV 3.1g Motor
$11.40 Turnigy TGY DP3A 1g ESC
$14.00 TheSteve Main Motor Converter
$ 4.50 Walkera Tail Motor (the pinion is what you need of the HM-4#3-Z-26)
Plus a little postage and some discount from HK depending on your member level
Some 10min JB Weld (To secure the mount to the frame)
Some plastic square tube (for the engine mount)
A little enamel wire
and regular tools
And the above will get you a brushless setup that produces at least 15 - 20 grams more thrust than the stock motor of the MSR
If you watch how you do things you may even come in at around the same weight as the stock MSR perhaps even lighter
Elias
VIDEO BEING EDITED
Old Nov 04, 2009, 08:19 AM   #3
Jim
Send a message via AIM to Jim_W Send a message via MSN to Jim_W
I'm considering which heli to buy for my first single rotor. Would it not make more sense to get say a CB100, verses trying to mod a mSR to brushless? Any advise will be greatly appreciated!
Jim
Jim_W is offline Find More Posts by Jim_W   Reply With Quote
Old Nov 04, 2009, 08:34 AM   #4
EatAtJoes's Avatar
Jim
Jim
The CB100 is already brushless, but that heli is a handful to fly in comparison to the MSR. Crashes will cost you, I think someone did a sum and worked out the cost was 10x the cost of his MSR for the same amount of fights.
If you can fly heli's and simply want a brushless heli without the hassle of upgrading then go with the CB100, but you need to use Walkera Radios and electrics which always have short falls.
But if you want one that is Spektrum based and one to learn on (that wont cost much in repairs) then go the MSR.
One thing to remember the CB100 will act a little more like a larger heli than the MSR.
Elias
Old Nov 04, 2009, 08:35 AM   #5
I would love to see a brushless msr. The only thing that is stopping me from getting a msr is that it is not brushless.
altronpower is offline Find More Posts by altronpower   Reply With Quote
Old Nov 04, 2009, 08:44 AM   #6
Jim
I have a cb100. It is pretty stable for a sub micro sized fp helicopter but its stability is nowhere near the msr (based on videos I've seen. I don't have a msr)
I still can't get the cb100 to hover hands free. Had a couple of crashes and the rubber O-rings on the feathering shaft kind of got crushed by the e-clips. It still flies well but starts having random movements now. The cb100 is pretty durable other than the 0-rings.
Old Nov 04, 2009, 08:45 AM   #7
EatAtJoes's Avatar
I am uploading video to youtube now
Check back in around 1 hour and you will see it in action.
The thrust is unreal, I flew it outside and boy she is wild, power to weight ratio is excellent.
25g heli with almost 60g thrust
Stock MSR struggles to lift 6 grams, my brushless MSR can lift an entire 2nd MSR under it.
Old Nov 04, 2009, 08:48 AM   #8
EatAtJoes's Avatar
Yep and parts on both helis are single digit dollar amounts, so it's cheap, heck my gyro alone for my 450 heli cost me more than the entire MSR setup....
Old Nov 04, 2009, 09:01 AM   #9
Can't wait to see it. 25g with 60g THRUST!!!! That's like a rocket.
Old Nov 04, 2009, 09:34 AM   #10
EatAtJoes's Avatar
Some Pictures
Here are some pictures of my Brushless Setup
  • Name: Brushless_Setup.jpg
  • Name: Connections_01.jpg
  • Name: E-Flite_Blade_MSR_Brushless.jpg
  • Name: Front_Of_Mount.jpg
  • Name: Motor_Mount_Brace.jpg
  • Name: Motor_Mount_Brace_02.jpg
  • Name: MSR_Brushless_Motor.jpg
  • Name: MSR_With_Canaopy_Brushless_Motor.jpg
  • Name: Pinion_Meshing_Not_Exact.jpg
  • Name: Side_View_Pinion_Main_Gear.jpg
  • Name: TheSteve_Converter_On_DP3A_ESC.jpg
  • Name: Top_Of_Mount.jpg
  • Name: Yellow_Wire_Connection.jpg
Old Nov 04, 2009, 09:45 AM   #11
Me in my FP-101
livonia bob's Avatar
Jim
Elias
I have both and if you do the fixes on the mSR list before you fly it you will have a good but flighty heli for tearing around the house and outside on more or less calm days.. The CB100 is a better more hobby like heli and flies more like a real one would.. So really depends on your skill level, what you are looking to be able to fly scale like tearing around.. They are about the same price and the CB I think gives you more for your money. And I think flies more to my way of wanting a heli to fly. Both really need a upgrade in the TX the mSR you can go with a DX6i or 7 and with the CB you really need to get the 2801pro I just ordered a CB100 and 2801Pro for my son for his birthday for about $270.00 A BNF mSR is $150 and a DX6i is $150 so $300 for both.. The batteries on the CB100 last about 8-9 minutes for the stock 500mAh and you can get the new 600mAh 20c for $7.50 and this one gives me 10-11 minutes of flight time. The 150mAh battery for the mSR costs 14 bucks and lasts 6-7 minutes but you do get a 4 cell charger with the mSR and only a 1 cell with the CB. With the mSR if your flying and get to LVC it just about falls out of the sky and sometimes will thresh around on the ground.. The CB lets you know will in advance that it's getting low and you have time to fly back to yourself and set up for a scale like landing.. All the above is just from my personal experiences...Bob
PS I'm still flying both of these because they are really two different flying experiences. And I often just take turns with them.. And the 4#3... And even throw some flights in with the S300 and CX2 as all are fun and different..
livonia bob is offline Find More Posts by livonia bob   Reply With Quote
Old Nov 04, 2009, 10:05 AM   #12
Jim
Thanks for all the help! I guess I need to go with the mSR. I have 2 mCX heli's, and a CX2 now. Makes sense to stick with Eflite I suppose, since I have 8 batt's for the mCX already. Will they work in the mSR?
And now I will leave this thread to it's intended purpose! Sorry if I hijacked..wasn't intentional.
Thanks again fellows,
Jim
Old Nov 04, 2009, 10:13 AM   #13
4G3,4#3b,BMSR,TREX250,450 ,500
sNstRflyEr4G3's Avatar
subscribed
sNstRflyEr4G3 is offline Find More Posts by sNstRflyEr4G3   Reply With Quote
Old Nov 04, 2009, 10:19 AM   #14
It has been more than an hour already. The video?
Old Nov 04, 2009, 10:21 AM   #15
Chris Burton's Avatar
Man, don't let that keep you from buying one. These coreless motors used in the mSR are powerful and durable, very much unlike brushed Walkera motors which have led many - including me - to believe that everything brushed sucks and dies after 20 or so flights.
You will get many, MANY happy hours out of your mSR and it can sustain endless crashes before breaking anything!
Back on topic: this is awesome, it will be interesting to see how this develops. Like I said, a 100% happy with the stock setup but since I love brushless conversions like this one I just might get a second mSR for christmas and convert the first one by the time the stock motors wear out ;-)
Chris Burton is offline Find More Posts by Chris Burton   Reply With Quote
Mini-Review MIA UPGRADES - E-FLITE ***mSR ***FLIGHTS- REVIEW-MODS-TECH NOTES-HOW TO's MarioIArguello Micro Helis 248 Jan 23, 2010 06:00 AM
For Sale E-Flite Blade 400 w/ Upgrades and aluminum case HighNear90 Aircraft - Electric - Helis (FS/W) 6 Jan 10, 2010 12:03 PM
Wanted E Flite Blade MSR rocky79 Aircraft - Electric - Micro & Indoor Airplanes 2 Nov 01, 2009 09:57 PM
Sold E-Flite Blade mSR $120 Drivinfast247 Aircraft - Electric - Helis (FS/W) 9 Oct 18, 2009 11:52 AM
Congratulations SimpleM!
