Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Nov 04, 2009, 12:55 AM   #1
Hooked and loving it!
Tonystott's Avatar
FlyFly DG1000 wing joiner diameter
I seem to be the only person who got a stainless steel joiner which is only 4.45mm thick for my DG1000. The expanded diagram "manual" shows it to be 6mm carbon, and I have only read anywhere of it being 6mm diameter, whether steel or carbon.
My question is... should I just accept this to be the new specs for this aircraft, or should I try to get a replacement airframe and wings from HobbyKing, if 4.45mm won't be strong enough?
thanks in advance
Tonystott is offline Find More Posts by Tonystott   Reply With Quote
Old Nov 04, 2009, 09:27 PM   #2
L-Spatz's Avatar
4.45mm?? WOW!! I get a fair amount of wing waggle with a 6mm rod made from tool steel(Drill rod)that is much more ridgid than normal steel. My mind can't imagine how much flex will be in a 4.45mm rod. You pull into a loop and the wing tip's a going to touch and stay threre.
I would box it up and keep it as it may incease in value in time, kinda like a coin that only got stamped on one side.
Ken
SSP #6
L-Spatz is offline Find More Posts by L-Spatz   Reply With Quote
Old Nov 04, 2009, 10:14 PM   #3
Tonystott's Avatar
Thanks Ken
Discussion Replace steel wing joiner with carbon rod? edfardos Electric Sailplanes 7 Oct 31, 2009 08:02 AM
Discussion Secure Aluminum Wing Joiner to Fuse jasbury1 The Builders Workshop 6 Sep 03, 2009 11:42 AM
Question Source for Graupner or Flair wing joiner sets? SPasierb Scale Sailplanes 7 Aug 28, 2009 08:02 PM
Wanted Aspire Wing Joiner Mauihiflyer Aircraft - Sailplanes (FS/W) 0 Aug 23, 2009 08:14 PM
Discussion Mini Blade wing joiner diameter Fledermaus Slope 5 Apr 20, 2008 07:24 PM
Bored? Want to fight?
Join the RCGroups clan!
