Go Back   RC Groups > Aircraft - Electric - General > Electric Motor Design and Construction
Old Nov 04, 2009, 12:14 AM   #1
TLyttle's Avatar
Old motor
A buddy left me an old Simprop Pfalz kit, and I have a question about the motor: does it have internal capacitors, or do I need to add my own? It is a Simprop Speed 280, mounted in a ParcDrive 300+ gearbox. The instructions for the motor are in German... French, maybe; German, no chance!
TLyttle is offline Find More Posts by TLyttle   Reply With Quote
Old Nov 04, 2009, 01:08 AM   #2
I just bought an old Czech kit on sale that has a similar 280 setup. It came with a small bag of 2 caps that I had to solder on.
Even if yours has internal caps, it doesn't hurt to add more. I'd just add them and be done with it.
groundfx is offline Find More Posts by groundfx   Reply With Quote
Old Nov 04, 2009, 04:55 AM   #3
Replikit Designer
vintage1's Avatar
just add three caps anyway.
wont hurt, may help!
vintage1 is online now Find More Posts by vintage1   Reply With Quote
Old Nov 04, 2009, 12:14 PM   #4
TLyttle's Avatar
Thanks, guys, I'll do that. What capacitance do I need? I have a bag of cute little 10s, and a few 221s. Thanks for your help!
Old Nov 05, 2009, 01:38 AM   #5
I tend to use .1 uf (marking would be 104.. how to read cap markings is here http://www.elecraft.com/Apps/caps.htm), but I've been told that in this application size doesn't matter too much and that 0.01 to .1 uf should work as long as they are non-polarized and they have a high enough voltage rating (all ceramic caps you're likely to have will be 50V or more which is fine.)
Your caps are 10 pf and 220 pf respectively. 0.01 uf is 10000 pf. So both are on the small size.
But if you don't have anything else available, I'd still try to 221's and then just do a range test. They might still work.
Old Nov 06, 2009, 07:33 PM   #6
Dr Kiwi's Avatar
Typically .047uF across the terminals and 0.010uF to the case.
Dr Kiwi is offline Find More Posts by Dr Kiwi   Reply With Quote
Old Nov 11, 2009, 12:30 AM   #7
TLyttle's Avatar
Thanks again, guys, electronics are a huge mystery to me: if a hammer and wrench won't fix it, I'm lost...
Old Nov 11, 2009, 12:42 AM   #8
I'm glad to have helped. If you need any of those slightly larger caps, just send me a PM and I'll mail you some for free. I have bunch sitting here and I know to buy just a few can be a pain.
I seem to recall from past posts, you were a diesel guy. Are you taking a turn to the dark (electric) side?
Old Nov 12, 2009, 12:25 AM   #9
TLyttle's Avatar
Guilty as charged... I still am a diesel guy, but I was getting into electrics a couple of decades ago. I still build and fly both when I have the time, but so many projects are on my list, that time is limited. Now that I'm retired, I really do not understand how I had time to work!
I picked up some more caps, and they are in the higher numbers; will check them out against your referenced site. Thanks, groundfx, very helpful...
Old Nov 18, 2009, 10:46 PM   #10
TLyttle's Avatar
Groundfx is a great guy, thanks very much...
Old Nov 19, 2009, 06:54 AM   #11
Replikit Designer
vintage1's Avatar
slight correction, size does matter.
Too big and especially it its a tubular type, and the inherent inductance means that they will be worse than a typical plate type ceramic.
Its important to remember a capacitor ALSO has series inductance and significant resistance in the case of an electrolytic or paper type.
This is the perfect application for disc ceramics. They are lousy on leakage (who cares) lousy on stability and tolerance (who cares), BUT they are very low series inductance. And can take heat that some of the plastic dielectrics cannot. Never use a polystyrene cap!
Self resonance you want up beyond 100Mhz for HF use.
I tend to use 10nF throughout.
Discussion Old Monastery..Old Classic CARS..& Spices Too!..A/P guyg Aerial Photography 3 Sep 26, 2009 04:04 PM
For Sale old stuff-incl. train motor jim e Non R/C Items (FS/W) 3 Sep 06, 2009 06:20 PM
Discussion New guy, old old plane. Jayfrin Fuel Plane Talk 4 Sep 06, 2009 12:43 AM
Sold $old Futaba 9CHP Super mode 2 $old simages Aircraft - General - Radio Equipment (FS/W) 3 Aug 29, 2009 09:29 PM
please help...need to replace old motor..RS-540SH BigBadWolf_TX Power Systems 17 Apr 22, 2001 03:11 PM
Bored? Want to fight?
Join the RCGroups clan!
