Old Nov 03, 2009, 09:54 PM
Datsmar is offline
Find More Posts by Datsmar
Datsmar
Gulf Coast of Mississippi
Joined Jun 2006
KMB jet drives
Has anyone bought or used the KMB (Kehrer Modellbau Berlin) jet drives? They look like a durable units. The only other jet drives I can find are the Graupner drives. I have a 54" Island Class fiberglass hull I'm trying to power with something different.
Datsmar is offline Find More Posts by Datsmar
Old Nov 03, 2009, 10:44 PM
col_426 is offline
Find More Posts by col_426
from downunder Downunder
col_426's Avatar
Hobart, Tasmania, Australia
Joined Feb 2008
Hello Datsmar,
I've used one of KMB's 33mm jet drives in a Cen Waveshark rebuild, and was very happy with it. They are very sturdy and well made. KMB were also very good to deal with. The pic shows the jet drive installed in the Waveshark.
Phillip
col_426 is offline Find More Posts by col_426
Old Nov 04, 2009, 12:11 PM
Datsmar is offline
Datsmar
Joined Jun 2006
Phillip
Great looking Waveshark. Looks like a pretty full hull. How does the jet unit mount to the hull? Looks like you have a plate that mounts to the hull that uses mechanical fasteners. Looks like the servos are mounted to this plate. What is the width and length of the hull? It must really run fast with the gas engine.
Lawrence
Old Nov 04, 2009, 05:25 PM
col_426 is offline
col_426's Avatar
Joined Feb 2008
Originally Posted by Datsmar View Post
Phillip
Lawrence
Thanks Lawrence. I've just posted a side shot showing the outboard end of the jet drive, you can just see the KAMEWA steering and reversing bucket on the right. The jet drive inlet is glued to the bottom of the hull, and epoxy resin has been poured around it to seal it and make sure it stays attached. At the rear, there is a 33 mm diameter hole through the transom where the outlet fits, and where the 'outboard' part of the jet drive attaches to the inboard section with screws. If you look at the picture of the KMB jet drive, you can see where the two sections come apart, and the transom of the boat fits in there.
The basic process is to cut the hole in the transom, slide the inner part of the jet drive in place with the flange poking out the hole in the transom, and pour the epoxy around the inlet on the inside (before making a hole in the bottom, saves having the epoxy run out the hole ). When the epoxy is set, then you can make the hole in the bottom and file it to size, and attach the outboard steering and reversing section.
The plate in the hull is just to attach the servos to, the top one is for the throttle, the bottom servo is for the reversing bucket, and the centre one is for steering. The jet drive itself doesn't connect to this plate at all.
The speed is pretty good with the nitro engine, although it probably isn't as fast as a serious prop setup, but I think this is typical for jet drives. I mainly did it for the novelty, and so that it's like a real jet ski. I am thinking of replacing the nitro engine with a brushless setup, partly for a bit more speed, and mostly because it's less messy than nitro.
It's a bit hard to see how the jet drive mounts in the pictures, but I can take some closer pics tonight if are interested.
Phillip
Old Nov 04, 2009, 08:16 PM
Datsmar is offline
Datsmar
Joined Jun 2006
Phillip
I woul appreciate any closer pictures on the drive and the servo mounts. I found a posting from 2007 with info on a dual drive PBR that KMB makes. I just think it would look really unique on the water.
Lawrence
Old Nov 04, 2009, 08:19 PM
col_426 is offline
col_426's Avatar
Joined Feb 2008
No problem, I'll take some pictures tonight and post them tomorrow for you.
Phillip
Old Nov 07, 2009, 09:43 AM
Datsmar is offline
Datsmar
Joined Jun 2006
Thanks for the added pictures Phillip. Nice contruction work. I can see the use of the flex cable for controls works well.
Would assume you don't have alignment problems or water leakage problems using them.
I think the KMB drives are shorter or more compact than the Grapner drives are, but not sure as Grapner doesn't give any details on there units that I can find.
I have written to KMB on which units would fit the best, the 28mm or 33mm, still waiting for an answer. I'll post some pictures after I get whatever installed.
Lawrence
Old May 21, 2015, 03:23 AM
Brian Kidston is offline
Find More Posts by Brian Kidston
Australia, VIC, Chum Creek
Joined May 2015
Hi Phillip, interested in any info you have on jet units, I want to build or buy a unit to suit a hull of about 1.2 mtrs Thanks Brian
Brian Kidston is offline Find More Posts by Brian Kidston
Old May 25, 2015, 02:04 AM
col_426 is offline
col_426's Avatar
Joined Feb 2008
Hello Brian. Welcome to the Forum!
I bought my jet drive from http://www.kehrer-modellbau.de/en/. They had a 28mm, a 32mm (the one I have), and a 40 mm diametre I think, but it looks like they only list the 28 mm diametre jet drive now.
Old May 26, 2015, 04:00 AM
Joined May 2015
Hi Phillip, thanks for your reply I am moving along with my project have got a design of a water jet intake that was on the Tassie cat to Melbourne have scaled it all and have completed the CAD modelling of the intake based on a 50 mm impeller, I have ordered an impeller of that size which I will use for dimensions and pitch etc as a trial unit and then will then machine several different pitches to see the results using a scorpion motor running up to 20000 rpm still have to find suitable bearings and seals.
Will then make the pattern and casting ( I am a patternmaker by trade have just retired have, sand and aluminium die casting equipment and N/C equipment will send you some images of the CAD model if you are interested.
Regards Brian
Old Jun 23, 2016, 02:58 PM
thingz is offline
Find More Posts by thingz
Joined Jun 2016
I am curious would it require 2 28mm jet drives to propel a 36 inch boat(i know i changed measurements)? Also would it be too powerful with 2 jet drives? And what kind of brushless motors would i need to build one. How do you get a reverse bucket to work do you need one of the big airplane controllers and not one of the pistol ones? What would be a good hull for one or 2 jet drives about 3 feet?
Please answer to one question and say which one it is or make it blatantly obvious.
thingz is offline Find More Posts by thingz
Old Jun 24, 2016, 12:19 PM
TomHugill is offline
Find More Posts by TomHugill
Joined Apr 2013
One should be ok, depending on how heavy the boat is. I use a 3ch pistol transmitter that has a button third channel for the reversing bucket.
TomHugill is offline Find More Posts by TomHugill
Old Jun 26, 2016, 07:56 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
I have 2 builds on my blog using the KMB28.....I love them and they are very quiet and reliable when set up correctly.
http://www.rcgroups.com/forums/showthread.php?t=2646784
http://www.rcgroups.com/forums/showthread.php?t=2260256
CaptDH is offline Find More Posts by CaptDH
Discussion Voith drives PSV Captain Scale Boats 11 Oct 13, 2009 03:15 PM
Discussion KMB Typhoon SubNut Submarines 1 Nov 18, 2008 05:13 AM
Discussion Has anyone built a 1/12 PBR with jet drives? Tug Guy Dock Talk 31 Nov 19, 2007 10:37 AM
Jet drives Wing Zero Racing Boats - Electric 16 Oct 02, 2005 05:55 PM
Jet drives Wing Zero Dock Talk 4 Aug 17, 2004 03:16 PM
