| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Must Fly!
CopterX 4 Bladed
Been considering getting this 4 bladed head
http://www.ehirobo.com/shop/product_...oducts_id=8480 from Ehibro for my CopterX. If I am reading the description correctly I am gathering that I will not need a gyro. Is that correct? Sincerely, Karl in Colorado |
#2 |
No. This type of rotor head eliminates the flybar, and usually doing that requires some other piece of electronic stabilization equipment to compensate. The tail gyro is still necessary. And actually, the link is for the 4 BLADES only, I don't think this is for the actual 4 bladed rotor head.
Here is the link to the head: http://www.ehirobo.com/shop/product_...vifs4qfnok0933 |
#3 |
Must Fly!
Yea sorry about that link. Mine was to the blades for that 4 bladed head. yours is the correct one.
Now if I did get that 4 bladed head (with gyro of course) will it be more or less stable that the stock two bladed head? Sincerely, Karl in Colorado |
#4 | |
I'm waiting on parts
You may get more answers over in the scale heli section where many have already done this setup http://www.rcgroups.com/scale-helicopters-43/ |
#5 |
Must Fly!
OK, I think I will just stick with my two blades.
Thanks so much for you input. Sincerely, Karl in Colorado |
#6 |
#7 |
so Xrayted .. the claim "Light weight aluminum construction with floating blade grip design to elimate the need for 3D gyro system"
is BS? Can i fly one without a flybarless electronics or is it going to be like a moose on a steroid overdose? |
#8 | |
I know RCG member SidneyW has set up many multiblades using no stabilization so maybe he will chime in here |
#9 |
well im going to try ordering one and a fuse .. i already have a copilot II system sitting in a box i never got around to using if it is too squirrely and cant be flown easy with expo i'll try the cp2 system .. my curiosity has been sparked
.. if it works out and flys ok i may then go onto trying to source a 3-4 blade tail .. no promises on when this project will complete though looks like alot of work and trial and error testing
#10 |
Team Mulikow
Keep us posted on the CopterX Black Angel thread. I was wondering about this 4 rotor head myself.
#11 |
Since Xrayted mentioned my name here
![]() I started to fool around multi bladed head earlier this year. Many thanks to Super-Hornet and Hoverup, they helped greatly. I am no expert AT ALL, remember! ![]() Coptex flapping hinge head is similar to Super Hornet's design back a year ago. I took his advise and did or modded the quad head myself. Takes a couple of hours of fooling around and less than $10 of bolts, nuts and O-rings from local hardware store. I don't use stabilization or gyro assist or mixers .... 1) I am cheap, 2) I don't think the cheapo 450 class today really worth the price of spending $300 on a least cost of SK360. Of course, when I am ready to go big and invest on $1,000 upward, I will for sure use HeliCommand Rigid. Back to the topic, in my opinion, and trust me there will be many who will disagree instantly. ![]() 1) Understand mechanical set-up, the 90° phasing. This sounds complicated, rather, it is a simple setup. No matter the number of blades, 3-4 or 5 the same 90° phasing is needed. For 4-bladed head, it is very easy since each main blade is 90° to each other. 2) The choice of blade is very important to me, since there is no scale blades for the 450 class available I mod them myself. Heavy blades are good for stability and taming the cyclic; but they are bad for power system especially when I came across the use of 5-bladed head. I use plastic flex blades trimmed down to 25mm cord, added weight near the blade tip. 3) Many will advise you to go slow on HS. I don't keep it too low for two reasons; 1) tail authority; 2) flight characteristic with a little breeze. I like it to be around 2000-2200 depending on the number of blades; example 2200 on my Tri-bladed AS350 and 2000 on the bladed MD500e. I don't upgrade ESC or motor neither; from 30A Dynam (Xrayted paid for one ) to Align 35A, Esky 3800kv, HDX 3500kv and Tonix 3000kv. I could only use 25C or higher C rating Lipo because it gets hot otherwise.IMO, flapping hinge (design from Super Hornet allows different stiffness) allows a smoother flight transition from hover to forward or backward flight/movement. I also notice the use of less EXPO comparing the rigid head. However, the modded narrow blades reduces sensitivity some what to my liking. Narrow cord scale blades are coming to the market finally. In a few weeks, Flying-hobby.com will be offering them. Good news. In summary - I don't use stabilization, although it does not hurt (other than your wallet). Understand phasing, and why it is important. Multi-blades on scale looks better; sounds different. It looks silly IMO to fly scale 3D heli. Oops, I couldn't believe I said that. BTW, I use Gino's highly recommended G401B for a year now; three of them and not a single issue. Can't believe I wrote all these. 90° phasing on quad head
#12 |
they sell some blades at ehirobo specifically for the 4 blade angel head looks like .. guess i'll go for those to .. phasing? you lost me
3D with a multi head and a fuse? hell yes ![]() *will do Gino if nobody beats me to it .. give it a month or so
#13 |
Thanks for the input Sidney....I knew you I could summons your expertise into the thread :-)
#14 | |
2) Phasing is done as shown in the photo above ... look at the links. 3) Yes, you could do it. Gino, There are several members at scale forum have flown the Coptex quad head. Xrayted, Glad to put in my 2 cents. |
#15 |
Team Mulikow
Oh I'll have a look. You got links? I can put them up on the Black Angel Thread for reference.
| Thread Tools | |
| Sold 4 bladed head off TT E-620 | neverhappy | Aircraft - Fuel - Helis (FS/W) | 0 | Oct 12, 2009 11:11 PM |
| Sold Schluter 4 bladed head reduced to 175 with CF blades | neverhappy | Aircraft - Electric - Helis (FS/W) | 7 | Oct 12, 2009 08:48 PM |
| Sold 4 Bladed Main Rotorhead by Lightning heli (450 size) and 6 bladed tail | hs748 | Aircraft - Electric - Helis (FS/W) | 1 | Oct 10, 2009 10:57 AM |
| For Sale For Sale - 3 and 4 Bladed Head and Cascading 4 Bladed Tail for Scale Project | Peter Walker | Aircraft - Electric - Helis (FS/W) | 1 | Jul 19, 2009 08:59 AM |
| For Sale 3 and 4 Bladed Head and Cascading 4 Bladed Tail for Scale Project | Peter Walker | Aircraft - Electric - Helis (FS/W) | 5 | Jan 28, 2009 10:09 AM |
