| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
zoidburg! (\/)(;,;)(\/)
castle link MM issues.
whenever i try to plug my MM esc into my computer it tries to install the driver software, but fails. i have castle link on my comp, but it does not recognize the esc or says that it is not connected when it clearly is. wth is going on?
#2 |
i am using windows 7, the esc lights up and all. i tried searching and re-installing the drover software but i still cannot get it to work. why is there not just download for the driver on castles site?
#3 | |
Sorry, for Mamba Max controllers, you will need to use a Windows XP machine and update the Mamba Max firmware before it will work with Windows Vista 64 or Windows 7.0. The problem is with the driver on the Mamba Max itself -- it will not work with the new Windows Vista 64/7.0 HID driver. Once the firmware is updated, you will be able to connect to the Mamba Max using a Castle Link -- but the on-board USB will not work correctly with Windows 7.0 or Vista 64. Thanx! Patrick |
#4 |
ok, thanks. i had it on my vista comp and everything worked great. it just stopped working one day. too had of a hit to the MM? idk.
#5 |
also will i run into the same problem IF i get the MMpro? cause if the driver only works for xp i am unsure if i want it.
#6 |
No, the MMPro works just fine on Windows 7 and Vista right out of the box. The Mamba Max works fine too -- just needs the software update on XP before it will work on Windows 7 and Vista.
#7 |
ok, so i updated the driver on my xp comp....now the 3.19 castle link does not run. it says "fatal error and cannot connect to database" this is getting annoying.
and the 3.19 will not reconize it on my winows 7 ether, even after updating the driver. |
#8 | |
You are using a Castle Link right? |
#9 |
ok. i got my mamba max working on the XP computer. still will not work on my windows 7 though
| Thread Tools | |
| Sold Castle Creations Phoenix 45 + Castle Link | joe84780 | Aircraft - Electric - Power Systems (FS/W) | 1 | Oct 11, 2009 10:50 PM |
| Sold Castle Creations Castle Link/PHX-Link | DavidJ | Aircraft - Electric - Power Systems (FS/W) | 0 | Sep 08, 2009 09:48 PM |
| Question Castle Link 3.0 installation/connection issues / workarounds | Patrick del Castillo | Castle Creations | 88 | Apr 14, 2009 02:54 AM |
| Discussion Castle Link 3.0 issues / bug reports (NOT Installation related) | Patrick del Castillo | Castle Creations | 13 | Feb 10, 2008 07:41 AM |
| Discussion Issues with CC HV45 ESC and Castle Link | bp_968 | Castle Creations | 0 | Aug 24, 2007 12:26 AM |
