Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
Old Nov 03, 2009, 02:56 PM   #1
Bird of Time
Mauihiflyer's Avatar
Twin motors, twin batteries, twin problems
Here's the problem. I have a Hangar 9 B-25 with two E-flite 46 motors pulling about 47 amps each at full static power. That's 94 amps total. I set up two 4 cell 5000 ma. batteries into two Deans parallel plugs so the the current from the two batteries is pooled together and then re-split to the two motors (see photo). This allows both motors to have equal voltage and amps all the time, and should prevent one motor from running out of power before the other. It also aids in both motors running at the same speed (harmonics). The problem is that further research in to the Deans parallel plugs indicate that they are limited to 50 -60 amps, meaning that I am not getting full power, or they are going to get hot. Anyone have any ideas of a different parallel hook up that will supply full power.
  • Name: Picture 3.jpg
Mauihiflyer is offline Find More Posts by Mauihiflyer   Reply With Quote
Old Nov 03, 2009, 03:06 PM   #2
Southern Pride
everydayflyer's Avatar
Why not go to 5 mm bullet connections?
Charles
everydayflyer is online now Find More Posts by everydayflyer   Reply With Quote
Old Nov 03, 2009, 03:20 PM   #3
Bird of Time
Charles
Explain how to interconnect them like the above photo
Old Nov 04, 2009, 02:38 AM   #4
Bombs away! Err...landing
Ira NZ's Avatar
No reason you need to them paralleled through a deans. You could have each battery connected to a Deans but the actual parallel point be simply the wires twisted together and soldered.
Ira NZ is offline Find More Posts by Ira NZ   Reply With Quote
Old Nov 04, 2009, 02:58 AM   #5
Ira NZ has beaten me to it. If you do it his way, each Deans will be passing only 47 amps or thereabouts, and the only part of the circuit that'll be taking 94 amps is the wire parallel connection with the soldered joint.
abenn is online now Find More Posts by abenn   Reply With Quote
Old Nov 04, 2009, 01:44 PM   #6
Bird of Time
Though I agree that that might work, I lose the flexibility of two seperate batteries tht I use in other aircraft.
Old Nov 04, 2009, 01:58 PM   #7
Retired CFI Helicopter
Hughes500Bob's Avatar
http://www.castlecreations.com/media...03-Mar2006.pdf
Pages 2 and 3 are great!
http://www.robotmarketplace.com/prod...onnectors.html
Note what is says for the Ultra Plug "A tight-fitting and small-size (13 x 8mm) connector with very low loss. Rated number 1 by R/C Car Action, The Ultra Plug actually has less resistance, including the solder joints, than an equivalent length piece of 12 gauge wire."
IMO Use what you have or go for a bigger connector taking up a lot more room.
Bob
Hughes500Bob is offline Find More Posts by Hughes500Bob   Reply With Quote
Old Nov 04, 2009, 02:01 PM   #8
Ira NZ's Avatar
Uhhh...No you don't.
Battery-DeansDeans-\_/--ESC
Battery-DeansDeans-/ \--ESC
Assuming that worked right, it has no effect on the batteries. It ties together after the deans you use to plug into the system and each deans will only be seeing about 47 amps and the point both sides are wired together after the deans will be the only place seeing 94 amps.
Old Nov 04, 2009, 03:28 PM   #9
Pirouetting flip master
off topic question..
is it important to run it in harmonic?
if you run it separately, and in case one battery run out of juice, you still have another motor running?
lyclyc is offline Find More Posts by lyclyc   Reply With Quote
Old Nov 04, 2009, 04:42 PM   #10
Bird of Time
Loss of one motor in a twin engine RC plane is a MAJOR challenge to maintain control.
Old Nov 04, 2009, 04:45 PM   #11
Real Time Recon
Loss of 1 Eng.on a C-47 (full sized) and it will fly for ever.
Been there did that twice...RTR
realtimerecon is offline Find More Posts by realtimerecon   Reply With Quote
Old Nov 04, 2009, 04:49 PM   #12
Bird of Time
Lost a few in full scale also. RC is quite a bit different. Not sitting in the cockpit gives a different perspective.
Old Nov 04, 2009, 04:52 PM   #13
Bird of Time
[quote=Ira NZ;13504695]Uhhh...No you don't.
I'm having a visualization problem. Can you explain further?
Old Nov 04, 2009, 10:17 PM   #14
Ira NZ's Avatar
Two Batteries females deans plug into the two male wire harness deans. You have two negatives coming off those. You also have two negatives going to each ESC. You take the two negatives come from the male deans, you twist them all together with the two negatives going to the ESCs and solder them together and insulate as appropriate. It's like a big X.
Then repeat for the positive wires.
Old Nov 05, 2009, 03:17 AM   #15
Does this help? The only bit taking the full 94 amps is the two wires between the soldered connections. They can be as long* or as short as you need.
* Edit: Don't make them too long, otherwise you have other problems, which are covered in other threads about "long battery leads".
  • Name: Parallel connection.gif
Discussion problems with Twin Eflite 4200kv and Eflite 25amp escs larspronne Foamy EDFs 4 Oct 23, 2009 07:24 PM
Help! problems with a motor one of a twin guitaramp68 Power Systems 1 Sep 16, 2009 08:16 PM
For Sale Scorpio Do-328 Twin Prop c/w motors and prop and batteries chrisc Aircraft - Electric - Airplanes (FS/W) 0 Feb 01, 2009 06:32 PM
Help! Setting up twin motors, twin esc, twin batteries fly-r-die Electric Warbirds 8 Oct 11, 2008 08:25 PM
Twin brushless motor and ESC problems - how do I get the motors "in sync" Jason M Electric Ducted Fan Jet Talk 8 Jul 17, 2002 07:35 PM
Bored? Want to fight?
Join the RCGroups clan!
