Old Jul 14, 2010, 10:06 PM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Eeeew leeches!
Ok, in the case of squares, the leeches are the sides of the sail. British and American warships seem to have favored straight leeches - ie, a straight run from clew to earring. Every French image I've seen of topsails (attached) have scalloped leeches, ie, an inward curving cut from clew to earring.
This will obviously put tension on the leech and stiffen it.
Your other option is working bowlines.
BTW: Is the main bracing as far as the fore when braced hard over? If it's as far as it will go, you could cause the fore to brace a little less.
Also, your fore-n-aft sails will hold wind up into the 45-40 area while the squares are working up to around 55-50 at best - closer to 60. That means you can ease the jibs and stays'l and still be good close hauled - especially that stays'l.
JerryTodd is offline Find More Posts by JerryTodd
Old Jul 14, 2010, 11:23 PM
tbarjohn is online now
Find More Posts by tbarjohn
tbarjohn's Avatar
aurora, il.
Joined Aug 2009
Dan, I'm not sure on the material of your sails, I use Dacron sails and use heat on the leech to tighten it up after a couple of years of sailing, you have to be careful not to much heat just a little at a time, I use a monocoat iron
John R.
tbarjohn is online now Find More Posts by tbarjohn
Old Jul 16, 2010, 08:10 AM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
Good advice on easing the staysail - it needs to be set before sailing and I will try a much looser set.
Good idea on the heat. I'll try that. But since I have bolt ropes, I might have to do some "surgery" to change the leech length.
May get out again next Mon or Tues. Need to mod the sail before then.
Thanks for the thoughts.
DanL is offline Find More Posts by DanL
Old Jul 16, 2010, 03:47 PM
Paratrooper is offline
Find More Posts by Paratrooper
Paratrooper
Paratrooper's Avatar
Eubank Kentucky
Joined Nov 2007
Dan--I really loosened up my stays'ls so none of them are forcing the tops back. I doubt mind do any good at all for sailing--I just like the looks of them.
The problem I have had with stuns'ls has been they are only good running with the wind. If I have to attempt to tack at all with them it is useless. They look great in a photo but for working sails they are mostly useless.
Paratrooper is offline Find More Posts by Paratrooper
Old Jul 16, 2010, 04:03 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
The fellow that figures out how to remotely set stuns'ls will get rich
They aren't the simplest things to set in real life.
Old Jul 16, 2010, 05:10 PM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
i`m finding out more and more about sailset with my little brig somers.
And one thing i found is that the headsails need to be a lot less tightly sheeted in when beating with a square rigger than sloop headsails, also getting them too tight will prevent your head from coming up into the wind. Dan of your pic from above the headsails look very tightly sheeted. The same is true with the staysails. i`m always trying to imagine where i would like to have the boom on a sloop on a comparable course and set my F&A sails accordingly. so with the 1 maybe 1 1/2 points we get on the wind your F&A sails should still be pretty loose to set for best performance.. my observation
meatbomber is offline Find More Posts by meatbomber
Old Jul 17, 2010, 09:41 AM
DanL is offline
DanL's Avatar
sail trim
paratrooper, meatbomber,
Good advice. Next time out I'll keep the F&A sails much looser.
I'm re-doing the foot boltrope to shorten the leeches on the main topsail.
Too many chores to sail today, but I amy try to do a quick backyard video of a broadside.
Old Jul 17, 2010, 10:15 AM
Paratrooper
Eubank Kentucky
Joined Nov 2007
Today might have been a good day on the lake but only early this morning. It is now poking holes in 84 degrees headed for 90 plus--but the winds were nice.
Tell you what--I might load up in the backyard as well and see what happens. With a little windage and a tad more powder I might be able to send shot and shell in your general direction.
Old Aug 11, 2010, 01:02 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
LINK to a vid of a fellow with a little cannon shooting up his house. I think it ends when he takes out the video camera.
I thought it might give you an idea of Syren's potential next hunting season.
Old Aug 11, 2010, 03:10 PM
Paratrooper
Eubank Kentucky
Joined Nov 2007
How do you find stuff like this?
Well I was amused for 2 minutes--back to work.
Old Aug 11, 2010, 09:21 PM
DanL is offline
DanL's Avatar
Ray,
If you hang some lightbulbs on Surprise, can see if I can take them out.....
like the song says...."seeee yooouuuuuu in Septemberrrrrrr...."
Old Oct 07, 2010, 01:39 AM
lucc is offline
Find More Posts by lucc
belgium,limburg
Joined Sep 2009
Crossover jib tension
The sheets, attached to the clew of a headsail, work as a pair - one moves forward as the other one moves back. The length is adjusted so they are just a little bit tight. As they move, not much slack develops, even with no wind in the sails. With any wind at all, the sheets are taught.
So to keep the sheets on the drum, no elastic is necessary. The flanges of the drum are big enough to keep he lines in place.
Dan, a question?
How much larger must the minimum diameter of the CD "to the servo" to ensure that the lines have not come down.
lucc is offline Find More Posts by lucc
Old Oct 07, 2010, 08:49 AM
DanL is offline
DanL's Avatar
winch servo drum for headsails
lucc,
Does this drawing answer the question?
I'm really amazed at all your detail and how good it all looks on a big model.
Old Oct 07, 2010, 11:47 AM
lucc is offline
belgium,limburg
Joined Sep 2009
Nothing compair to your work and level off detail
Yes Thx Dan.
Did you glued this new winch-servo on top of the old servo ,our did you do something else ??
Old Oct 07, 2010, 08:10 PM
DanL is offline
DanL's Avatar
winch drum side view
lucc -
side view might answer more questions.
Dan
Discussion Syren, Brig, SC&H R/C Square Rigger, 1/24 scale DanL Scale Sailboats 377 Dec 11, 2015 10:50 PM
Discussion Square Rigger kit-18 Gun Brig-of-war of 1797 Ray C Scale Sailboats 3007 Nov 27, 2015 10:14 AM
Discussion Sailing SC&H 1/24 scale square rigged ships Paratrooper Scale Sailboats 434 Nov 25, 2015 08:50 PM
Video SC&H Brig - clip C DanL Dock Talk 3 Jul 23, 2008 12:01 PM
Video SC&H 1/24 brig DanL Dock Talk 3 May 27, 2008 11:47 AM
