Old Nov 03, 2009, 12:12 PM
DanL's Avatar
United States, MN, Brainerd
Syren, Brig, SC&H R/C Square Rigger, 1/24 scale
This is a start to a new thread to continue posting info that was previously being posted on a very long thread, "Square Rigger kit-18 Gun Brig-of-war of 1797", at:
http://www.rcgroups.com/forums/showthread.php?t=520465
Another thread with R/C Square Rigger technical/build/operation info is
Design Details for R/C Square Rigger Operating Systems at:
http://www.rcgroups.com/forums/showthread.php?t=1048580
The Syren Homepage is at: http://home.comcast.net/~dplewandowski/site/?/home/
DanL is offline Find More Posts by DanL
Old Nov 03, 2009, 08:41 PM
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Lovely work, Dan! Its always a pleasure to read about your build.
herrmill is offline Find More Posts by herrmill
Old Nov 11, 2009, 01:48 PM
DanL's Avatar
Pics from summer '09
Have a lot of pics from the past season. Here are some...
All these are from a kayak with Syren underway.
Juggle Tx, camera, paddle...oh, cellphone is ringing...
FOR MORE of this type of post, see Jerry Todd's attempt to get a new Scale Sail Model forum approved so that all this type of info will be in one easy-to-find location. Thanks.
Here's Jerry's link to post your support for the new forum: http://www.rcgroups.com/forums/showt...6#post13542656
Old Nov 25, 2009, 11:42 PM
DanL's Avatar
Syren pics from the past
Fleet pic is Beneteau's Pictou, Paratrooper's Surprise and Syren.
Old Nov 26, 2009, 10:22 AM
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Such a fine model that actually works! She a wonderful piece of art and craftsmanship Dan, and a tribute to SC&H as well. You really ought to compile a book on how you super-detailed the kit. It would boost sails, er, sales for Phillip.
JerryTodd is offline Find More Posts by JerryTodd
Old Nov 26, 2009, 11:00 AM
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
Beautiful details Dan! Really a great build. Amazing rope work, You are the master!
LONGBIKE is offline Find More Posts by LONGBIKE
Old Nov 26, 2009, 05:07 PM
Dolores, Colorado
Joined Dec 2007
Guys,
Those are the most beautifull ships I have ever seen.
They look absolute real, you guys are it, no question about it.
Schrott is offline Find More Posts by Schrott
Reply With Quote  (Disabled)
Old Dec 21, 2009, 05:00 PM
Monterey Bay California
Joined Feb 2004
Originally Posted by DanL View Post
Fleet pic...
Dan, you clearly have a different definition of "scale" than I do!
Those ships are STUNNING! Amazingly complete and realistic detail for working models! Absolutely amazing!!!
Aerominded is offline Find More Posts by Aerominded
Old Dec 21, 2009, 11:02 PM
Taking care of the pond.
MILLERTIME's Avatar
USA, CA, Fresno
Joined Apr 2004
Nice ships.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Dec 30, 2009, 01:17 PM
Semper Fi
GreenAmphibian's Avatar
Northern Triaid North Carolina
Joined Jun 2008
EXCELLENT!!! That is a beautiful ship you have constructed.
GreenAmphibian is offline Find More Posts by GreenAmphibian
Old Dec 31, 2009, 12:21 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
Here's a video of Dan setting Syren up for the coming season:
Niagara Rigged and Ready (0 min 56 sec)
Note that no cranes were used - just crew and capstan.
Old Jan 01, 2010, 12:56 PM
DanL's Avatar
New firing carronades
Building the improved larger bore 16-gun system for Paratroopers Surprise got me started in an arms race with myself. I decided to also build a new system of 9 + 9 carronades for Syren.
As I thought about it - scale model guns or working guns? - I decided I had to come up with both: working scale model guns.
Pics show first steps.
I turned 18 brass barrels and prepped breech plugs. Need to add the nichrome ignition element to the plugs - same as built for Ray's guns. To make them "scale", the barrels will fit into the cut-off breech sections of the SC&H cast resin carronades and mounted on the carronade bases. The brass barrels will slide in and out of the bored out resin breech so that the breech section and carronade base can be permanently mounted, wired and rigged on the deck. The brass barrels will have friction contacts to connect to the permanently mounted base. The "negative" electrical connection thru the brass barrel is easy, but still figuring the best way to make the "pos" connection to the insulated contact on the back of the plug.
Another approach may be to make a mold and cast new resin carronade breeches for the brass barrel inserts rather than cutting up all my other scale carronades.
The bigger guns produce much more smoke and sound than the current small bore design, are still in scale (see brass barrel and scale resin barrel comparative pic), are less finnicky with the new hand made igniters vs small glow plugs, and the new fast loading system makes them really much more convenient and practical to operate. The in/out barrel design allowing scale rigging of the breech and base will hopefully work out well.
Old Jan 06, 2010, 11:19 AM
DanL's Avatar
Firing carronades - rotary switch construction
Almost finished with the rotary switch to fire the new 18 carronades, 9 port and nine starboard, each side separately.
Had to make this rotary switch more comapct than previous ones to fit 20 contacts (18 guns plus an "off" position at each end of travel) and still fit inside the Syren hull.
The switch body is a ring cut from a 2" PVC pipe union. The servo travels 180degrees, but has a double ended, double stacked contact arm arrangement that allows use of the full switch body circumference for contact placement. Top row of contacts is for starboard, lower set for port guns. A separate SPDT switch changes the common wire connection between the starboard and port guns, so only a single set of guns fires on one full rotation. Servo travel is slowed down by a NFSD-2 Servo Slow Down module (backordered from Hobby Lobby).
Contacts are small rivets.
Contact layout was done on a computer, printed, glued to the PVC ring, mounted on a lathe chuck just for convenience and drilled by hand.
Terminal strips used have proven to be the easiest and most flexible way to connect the gun wiring to the switch. Only one wire is required per gun. The "common" wires all go to a single ground connection.
Old Jan 06, 2010, 12:37 PM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Very innovative, as usual DanL. Will the resin accept the momentary bulging of the brass as the gun fires? You might want to test before chopping all your nice resin guns.
Brooks is offline Find More Posts by Brooks
Old Jan 06, 2010, 01:47 PM
DanL's Avatar
Scale carronades
Brooks,
Thank you. It has taken over two years of immersion the "cannon hobby" to get the design this far.
So far, I've cut up two carronades and I do regret it. So I am having a friend make a mold for the rear portion of the barrel as shown in the previous posts. The brass firing barrel will be self contained and slip into the scale barrel and carriage. That will allow complete scale rigging of the guns, since they will not need to be disturbed to remove and service the working barrels.
On the matter of pressure etc., I spent a lot of time on cannon and special effects forums and have tested extensively, and my findings are these:
- The carronades use less than 1/4 of the smallest, small-cannon powder charge I can find any reference to.
- The barrel length is extremely short relative to the large bore diameter, limiting pressure build up.
- NO projectile is ever used - only a very low mass, very pliable foam plug to keep powder in place and water out.
- After over two years of firing, there isn't even the slightest sign of barrel swell or damage, even in the smallest thin-wall guns made.
- There is no noticeable gun temp increase after discharge - at all.
- I've tested double loads and see no signs of damage, barrel swell (by micrometer) or blown out glow plugs. (And note that the threads in the barrel are very shallow because of the too large ID vs the proper ID for glow plug threads)
- Guns are fired on the water, well out of range of any person. And I use a homosote board hood as a deflection cover when I test fire.
- The guns are more like very small squibs used for special effects (the bullet burst on an actors chest) than cannon barrels.
- As a test, I put a full powder load with a foam wad into a 1/4" x 1.5" long piece of plastic soda straw. A glow plug was press fit into the breech end of the straw. I fired that straw 7 times and gave up. Absolute truth: NO damage to the straw at all. It could probably have been fired 100 times.
Conclusion:
The soda straw test confirms to me that the pressure build up is minimized by the light load, the low barrel L/D ratio, no projectile and the low mass/low resistance wad. Still, I take precautions not to expose myself within range of firing carronades. I still consider these as cannons and potentially dangerous, but feel I am excercising due caution.
Discussion Syren, Brig, SC&H R/C Square Rigger, 1/24 scale DanL Scale Sailboats 271 May 20, 2013 01:40 PM
Discussion Square Rigger kit-18 Gun Brig-of-war of 1797 Ray C Scale Sailboats 2975 May 14, 2013 10:01 AM
Discussion Sailing SC&H 1/24 scale square rigged ships Paratrooper Scale Sailboats 426 Jan 23, 2013 01:34 AM
Video SC&H Brig - clip C DanL Dock Talk 3 Jul 23, 2008 12:01 PM
Video SC&H 1/24 brig DanL Dock Talk 3 May 27, 2008 11:47 AM
