This thread is privately moderated by NoFlyZone, who may elect to delete unwanted replies.
Old Oct 04, 2010, 09:24 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Trying to find a motor to get 1350 grams trust with a 7" prop (space restriction), and no success.
Anyone have a hint ? Three blades welcomed
renatoa is online now Find More Posts by renatoa
Old Oct 04, 2010, 09:42 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
How about the specs on the plane?
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 04, 2010, 09:48 AM
Joined Sep 2007
Should it matter ?
Is the thrust required for a glider different than thrust required for a 3D ?
I tried with webocalc, not able to solve my equation.
Is a big 2800mm glider, 1600 grams AUW, 3s power, and 40A max ESC.
The 7" prop is definitelly the bottleneck, because is a kind of pylon plane, like EZ*.
Old Oct 04, 2010, 09:58 AM
Joined Jul 2006
Should it matter ?
Wing area? Or average width of the wing?
Old Oct 04, 2010, 11:03 AM
Joined Sep 2007
44dmp
Old Oct 04, 2010, 11:37 AM
Joined Jul 2006
Here ya go...
Old Oct 04, 2010, 11:41 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by NoFlyZone View Post
Here ya go...
Wow, is it safe to spin that prop at that required RPM?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Oct 04, 2010, 11:56 AM
Joined Jul 2006
Hi richie,
WebOCalc won't let you pick a prop that is unsafe. It's one of the nice features it has...
Chuck
Old Oct 04, 2010, 11:58 AM
Joined Aug 2009
Thank you, I never would have believed it but there is a first time for every occasion.
Old Oct 04, 2010, 12:03 PM
Joined Sep 2007
Th only thinkg that is different is the top speed, for me was 68hm/hr, as suggested by webocalc, because my chosen model was gentle scale, not unlimited aerobatics.
Even if I switch to fast unlimited aerobatics, the suggested top speed is 87hm/hr.
Why so big top speed in your case? And, isn't it unrealistic for a glider ?
Rev, the RPM is not so big, more than 20k RPM can be found even for EZ* migrated to BL, with 6" prop.
What is the equivalent 3 blades prop for a two blades ? What about the folding props, are they 100% equivalent to a fixed blade prop ?
Old Oct 04, 2010, 12:06 PM
Joined Aug 2009
This is all new to me, Thank you.
I knew EDFs turned some very fast RPMs, but nothing like this.
Old Oct 04, 2010, 12:18 PM
Joined Jul 2006
Richie,
APC Thin Electric, or "E" props have a safe operating rpm of 190,000/diameter.
Let's calculate the safe rpm for an APC 7" E prop then....
190,000/7 = 27,142 rpm
For a 10" APC "E" prop it would be 190,000/10 = 19,000 rpm
See how it works?
Chuck
Old Oct 04, 2010, 12:23 PM
Joined Jul 2006
It is VERY unrealistic for a glider! But the problem is we are working within the 7" prop you said was the physical limit. In order to generate your required 1300+ grams of thrust, we have to spin that 7" prop like crazy. And spinning it like crazy means the plane is going to have a wicked top speed. Very inefficient!
In fact, it's so inefficient, that WebOCalc doesn't even want to compute the combo, and we must rely on manipulating numbers just to get it to work. WebOCalc is a model of efficiency, and when it sees that we want to use a 7" prop on a 110 inch wingspan, it thinks we are absolutely nuts for trying to do so.
Chuck
Old Oct 04, 2010, 12:33 PM
Joined Aug 2009
Richie,
See how it works?
Chuck
Yeap, makes good sense. Thanks
Old Oct 04, 2010, 01:16 PM
Joined Jul 2006
For APC Slow Flyer props, the magic number is 90,000/diam instead of 190,000/diam
For GWS RS props (the ones commonly referred to as slo-flyer), the magic number is somewhere between 40,000/diam and 50,000/diam
A 10" GWS RS prop would have an absolute maximum of around 4000-5000 rpm
Chuck
Discussion Prop selection Dannyrevs Electric Plane Talk 5 Feb 20, 2010 12:32 PM
Discussion Seeking Good E Prop Selection mt_100 Hot Online Deals 12 Oct 14, 2009 08:36 PM
Cool Handy 3M adhesive selection guide djacob7 Foamies (Scratchbuilt) 1 Sep 03, 2009 12:47 PM
Discussion Foamy building beginners guide. jbat35 Beginner Training Area (Aircraft-Electric) 1 Aug 29, 2009 10:52 PM
Discussion Mountain Models Lucky ACE prop selection mumblety-peg Parkflyers 4 Aug 27, 2009 09:51 AM
