This thread is privately moderated by wbrannies, who may elect to delete unwanted replies.
Old Nov 02, 2009, 07:22 PM
wbrannies is offline
Find More Posts by wbrannies
Trader Rating: 35
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
Trader Rating: 35
Sold
E-Flite 30-Amp SB Brushless ESC, Price Reduced, For Fast Sale!!!
Here is a used Eflite ESC, works great!
$20.00 shipped
Paypal plzz
30-Amp Pro Switch-Mode BEC Brushless ESC
Key Features
Up to 30-amp continuous current with proper airflow, 35-amp peak
5-volt Switch-Mode BEC circuit capable of 700mAh continuous current on any recommended input voltage
Drives up to 5 analog or 4 digital sub-micro servos with the BEC
3S-4S Li-Po or 9- to 12-cell Ni-MH/Ni-Cd input voltage
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cut-off with settings for 3S Li-Po (9.2V), 4S Li-Po (12V) or 74% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shutdown if signal is lost or there is interference
Programmable timing - 5 user-selectable ranges for use with a larger variety of brushless motors
Heli mode for starting the motor with a low speed ratio
Optional RS232 Serial Link available for programming (EFLARS232)
Pre-wired connectors - E-flite EC3 connectors on battery input and 3.5mm female gold bullets on motor output leads
Overview
E-flite’s 30-amp Pro SB brushless ESC offers up to 30 amps of continuous current with proper airflow and a peak of 35 amps. It drives up to 5 analog or 4 digital sub-micro servos with the BEC on any recommended input voltage. This brushless ESC includes programmable motor braking, soft start for helis and planes, timing, throttle input range, and low-voltage cutoff. It also features auto motor shutdown in case of lost signal or interference. The safe power-arm mode prevents accidental starts.
Specs
Brake:Yes
Continuous Maximum Current:30A
Input Voltage:3S–4S Li-Po, 9- to 12-cell Ni-MH/Ni-Cd input voltage
Input Connector Types:16AWG with E-flite EC3 connector
Output Connector Types:16AWG with 3.5mm Female Gold Bullet Connectors
Momentary Peak Current:35A
Dimensions (WxLxH):28mm (1.1 in) x 51mm (2 in) x 8.7mm (.35 in)
Weight:31 g (1.1 oz)
BEC Voltage:700mA continuous
wbrannies is offline Find More Posts by wbrannies
Old Nov 03, 2009, 01:03 AM
x388s is offline
Find More Posts by x388s
Trader Rating: 13
x388s's Avatar
Trader Rating: 13
I will take it. Please PM me your Paypal address. Thanks
x388s is offline Find More Posts by x388s
Old Nov 03, 2009, 11:41 AM
Trader Rating: 35
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
Trader Rating: 35
Sold
Sold E-flite 30 Amp Pro ESC ggjj Aircraft - Electric - Power Systems (FS/W) 1 Oct 21, 2009 07:44 AM
Sold E-Flite 30-Amp Pro Switch-mode BEC Brushless ESC and PKZ BL 15 outrunner Gravity Dodger Aircraft - Electric - Power Systems (FS/W) 1 Oct 05, 2009 03:47 PM
For Sale E-Flite 30-Amp Pro Switch-mode BEC Brushless ESC RickC2009 Aircraft - Electric - Power Systems (FS/W) 1 Sep 30, 2009 01:51 PM
For Sale New in Package - E-flite 20-Amp ESC $30 shipped jokeane Aircraft - Electric - Power Systems (FS/W) 0 Aug 30, 2009 10:37 AM
Sold E-Flight 30 Amp Pro SB Brushless ESC termite Aircraft - Electric - Power Systems (FS/W) 0 Jul 04, 2009 12:07 PM
