Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Nov 03, 2009, 07:55 AM   #31
brick
EDF Design Contest for 2010??? you said Design. did i win
  • Name: Assembly1brick.jpg
  • Name: Assembly1brick-1.jpg
space 1 is offline Find More Posts by space 1   Reply With Quote
Old Nov 03, 2009, 08:00 AM   #32
Turbine Mechanic
Joshua Wesley's Avatar
Send a message via AIM to Joshua Wesley
I would like to see a couple different size catagories. Its much easier to build a complex, well finished jet in a larger size due to the thrust to weight ratio. But as for foam, balsa, composit, hybrid, or concrete, who cares.
Joshua Wesley is offline Find More Posts by Joshua Wesley   Reply With Quote
Old Nov 03, 2009, 11:26 AM   #33
Gordo Gone Wild
pdawg's Avatar
Just my initial idea on a few classes that are easy to classify
Scale
Non-scale
Small (2B defined later)
Big (2B defined later)
pdawg is offline Find More Posts by pdawg   Reply With Quote
Old Nov 03, 2009, 12:33 PM   #34
eatond's Avatar
Hi Gene,
I got a design almost ready to go so I'd be in and I know a couple of other RCGroup folks here in Saint Louis with new designs going that would probably enter also.
Dan Eaton
eatond is offline Find More Posts by eatond   Reply With Quote
Old Nov 03, 2009, 01:41 PM   #35
You can't see me I'm a Phantom
EDF Phantom's Avatar
Please keep the Feed Back comming..................
EDF Phantom is offline Find More Posts by EDF Phantom   Reply With Quote
Old Nov 03, 2009, 08:14 PM   #36
Airland Hobbies
Site Sponsor
turbonut's Avatar
Humm ...I have one to try!
turbonut is offline Find More Posts by turbonut   Reply With Quote
Old Nov 03, 2009, 08:14 PM   #37
Lee Liddle
Bronze Member
Sounds like good inspiration to build something new. I`m in.
Knife Liddle is offline Find More Posts by Knife Liddle   Reply With Quote
Old Nov 04, 2009, 01:27 PM   #38
MattinAZ's Avatar
I would suggest 2 classes based on wing span and keep the rest up to the designer. If it looks great, flys great and wins, what does the building material matter. Who really cares what materials it is made of???.
32" WS and under
over 32" WS.
MattinAZ is offline Find More Posts by MattinAZ   Reply With Quote
Old Nov 04, 2009, 03:36 PM   #39
Up and at 'em F-35
Steve C's Avatar
I agree with open construction, but wingspan is not the greatest way to catagorize jets. Think F-104 vs. P-80. If they had the same wingspan, you could fit a few P-80 fuses inside the F-104!
Keep sport jets and scale jets separate, or bonus points for scale?
Steve C
Steve C is offline Find More Posts by Steve C   Reply With Quote
Old Nov 04, 2009, 03:45 PM   #40
I hope this happens, come on all you clever guys get designing!!
Stuey is offline Find More Posts by Stuey   Reply With Quote
Old Nov 04, 2009, 04:24 PM   #41
Go Fast or Go Home!
Tumbler's Avatar
What about just breaking it down by airframe size and/or fan size. Ex. 50-60mm, 70-90mm, and then 100mm+. Obviously a lot more goes into make a 100mm size jet than a 50mm, so it is hard to judge them the same....regardless of what they are made off.
Brian
Tumbler is offline Find More Posts by Tumbler   Reply With Quote
Old Nov 04, 2009, 04:45 PM   #42
Go Fast or Go Home!
Tumbler's Avatar
Oh yeah I am in BTW, so let's finalize the rules and start designing!
I am mostly worried about KnifeLiddle.....you come up with some unique creations with your kit bashes. You have to start from scratch on this one though buddy.
Brian
Old Nov 04, 2009, 05:05 PM   #43
MattinAZ's Avatar
I like the fan size categories.
Have 2 - up to 80mm and 80mm+
Matt
Brian
Old Nov 04, 2009, 05:24 PM   #44
I want to fly everything!
Lance Nordby's Avatar
I agree that the construction shouldn't matter. I personally don't like working with foam but if it looks good and flies well, indeed, why should it matter?
I agree it should be kept simple.
I like Matt's above and below 80mm sizes but I would add belly floppers vs. retract equipped airframes to make four catagories. As far as I'm concerned fiddling with retractable gear is as much work as the rest of the airplane. It wouldn't be fair to pit a flopper against a retracter.
Lance Nordby is offline Find More Posts by Lance Nordby   Reply With Quote
Old Nov 04, 2009, 06:51 PM   #45
Flying for the return of MikeW
Kevin Cox's Avatar
Hmm.
Here is my take on it
2 catergories: Scale and other
Additional point(s) awarded for retractable landing gear (all catergories)
Additional point(s) awarded for cockpit detail (scale only)
Additional point(s) for multi fan models (all catergories)
Additional point(s) for scale features; i.e. parachutes, airbrakes, opening canopies, LE(slats) and/or TE flaps, etc. must have at least 2 operational. If it has swing wings or thrust vectoring, that quailfies as 2 (all)
We can add more...or less
I think it rewards the guys that put in the extra effort but doesn't discourage anyone.
Kevin Cox is offline Find More Posts by Kevin Cox   Reply With Quote
EDF-50 design contest entries zbrubaker Electric Ducted Fan Jet Talk 31 Sep 04, 2004 01:42 PM
E Zone EDF design contest! Shawn Palmer Electric Ducted Fan Jet Talk 48 May 21, 2003 06:40 PM
EDF-50 Design Contest??? zbrubaker Electric Ducted Fan Jet Talk 48 Sep 30, 2002 12:42 AM
What ever happened to the EDF design/build/fly contest. OCModels Electric Ducted Fan Jet Talk 2 May 13, 2002 05:10 PM
EDF design contest deadline - May 1! Andy W Electric Ducted Fan Jet Talk 11 May 01, 2002 09:22 PM
Bored? Want to fight?
Join the RCGroups clan!
