| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
You can't see me I'm a Phantom
EDF Design Contest for 2010???
I want to know if there is any interest in an EDF Design Contest... It has been a while since we had one, and i was lucky enough to win the last one.
Lets bring back some good times on here with a Contest........ I would like 3 classes of pure EDF, class 1 Foamy and class 2 hand/bungee launch, Class 3 Gear/Retracts. no pushers since EDF means EDF. Whats your feed back guys, or is the forum soo far out of wack that nobody want's to do it. Gene Last edited by EDF Phantom; Nov 08, 2009 at 12:29 AM. |
#2 |
Sounds like a good idea Gene!
I have something in the works and would be willing to throw my hat in the ring. Whether I finish it in 2010 is another story .Paul |
#3 |
Up and at 'em F-35
Sounds like a good idea. Most don't finish, but a few do and it ends up producing some neat stuff. I'm still out of wack though!
![]() You'll have to define "foamie", since most like to put glass on them and then they're not much different than an all glass plane. Last contest I tried was an all wood class. Remember when planes used to be made from wood? ![]() Steve C |
#4 |
maybe define "foamie" a little better then. LOL. since foam covered with glass would tehnically be a composite, maybe that should be included in the composite section, if there is one. I suppose that would be under class 3, cause most would put retracts on a more expensive jet.
I'de deffinitely be interested though, since I've got a few ideas up my sleeve for the off season. I'M IN! ! ! ! ! ! ! LOL. Rich |
#5 |
Hey Now
Sounds good to me. But I am not much of a designer so I will watch.
Foam could be limited to wing, tail cores only. I would rather see a well made and crafted all wooden model than a CNC milled foam job anyday. -Scott |
#6 |
Foamy is foamy. If you cover it in glass it is still a foamy.
Foam core wings on a balsa or fiberglass fuse is not considered a foamy. But a foamy can be under class 3, gear/retracts. Then it won't be in the foamy class. Foamy class is basically depron type EDF I will come up with some rules for the contest eventually. I don't know if I will run the contest or not. I will be talking to a few people about it. I was thinking of having a panel of judges as well as having an online voting system split 50/50. This contest will probably be called the 2010/2011 EDF design contest. That way people can get their maidens done in the spring time of 2011. This should be plenty of time. Last edited by EDF Phantom; Nov 02, 2009 at 12:54 AM. |
#7 | |
150mph 90mm JHH COUGAR 3.5KW:D
hatin' on the depron. what if you can make it look better than a balsa model? you know we can.
#8 |
how bout best duct tape construction EDF! lol
think its the same stuff they use to make dil**'s |
#9 |
Not another MONSTER !!
Gene,
Subcribed.
What constitutes "design"? Shape?, Details?, Kitbashed, or scratch built only? Are dwgs to reproduce it necessary, or can it be a "one off"? |
| EDF Phantom |
This post is temporarily hidden while EDF Phantom edits it.
#11 |
deltas are cool
Can it be a scale airplane or are you looking for sport type EDF?
#12 |
#13 | |
My project: FAIREY DELTA 1
![]() Great contest Gene! I have been thinking to go underground for my current project, but a contest is a nice twist. Still I am at the start of the learning curve of composite moulding so I am not too sure I am able to speed the pace up within this timespan. I was planning composite fuse/foam cored wings. I already cut 39 formers for the fuse. |
#14 |
Claus at Area 52
LuvEvolution7.
You are absolutely right on that glass covered foam is a composite construction, but try to get the moderators here understand that! what is the difference in making a negative mold or a possitive mold for the epoxy/glass composite? It is still "composite" Tecnically a balsa-covered foam core wing is also a composite construction. Wikipedia says: Composite materials (or composites for short) are engineered materials made from two or more constituent materials with significantly different physical or chemical properties which remain separate and distinct on a macroscopic level within the finished structure. Claus |
#15 |
Claus at Area 52
But that said .. I am in for that contest.
Claus |
| Thread Tools | |
| EDF-50 design contest entries | zbrubaker | Electric Ducted Fan Jet Talk | 31 | Sep 04, 2004 01:42 PM |
| E Zone EDF design contest! | Shawn Palmer | Electric Ducted Fan Jet Talk | 48 | May 21, 2003 06:40 PM |
| EDF-50 Design Contest??? | zbrubaker | Electric Ducted Fan Jet Talk | 48 | Sep 30, 2002 12:42 AM |
| What ever happened to the EDF design/build/fly contest. | OCModels | Electric Ducted Fan Jet Talk | 2 | May 13, 2002 05:10 PM |
| EDF design contest deadline - May 1! | Andy W | Electric Ducted Fan Jet Talk | 11 | May 01, 2002 09:22 PM |
