Go Back   RC Groups > Aircraft - Electric - General > Electric Motor Design and Construction
Old Nov 01, 2009, 06:26 PM   #1
Scratchbuilds, it's what I do
mattyhawk's Avatar
Mega Motor Damage?
Hello,
I have a Mega 16/15/3 on a Mega 3:1 gear box, and this weekend the front cap on the motor released, causing some issues I need help with.
There was a protective fiberous covering over the stator which partially shreded and went everywhere in the motor windings, and now only part of the stator is covered. First, is the covering required? If it is, how do I replace it? Second, is the fibers in the winding matter? I would guess not, but I am a motor noob.
Also, how do I glue the motor back together?
Thanks, Matt
  • Name: 006.jpg
  • Name: 003.jpg
mattyhawk is offline Find More Posts by mattyhawk   Reply With Quote
Old Nov 02, 2009, 09:24 AM   #2
lutach's Avatar
The wrapping around the rotor is Kevlar. You can use Kevlar or Carbon Fiber to wrap the rotor again. I think it's needed as this could happen:
http://i260.photobucket.com/albums/i...h/DSC01369.jpg
http://i260.photobucket.com/albums/i...h/DSC01372.jpg
http://i260.photobucket.com/albums/i...h/DSC01366.jpg
http://i260.photobucket.com/albums/i.../DSC01364a.jpg
lutach is offline Find More Posts by lutach   Reply With Quote
Old Nov 02, 2009, 04:47 PM   #3
mattyhawk's Avatar
Thanks for the info, I thought it might be needed.
Old Nov 03, 2009, 06:05 AM   #4
Proud to eat Kraut ;-)
Julez's Avatar
Hi!
Buy some Kevlar roving and good laminating resin. Place the Kevlar in the oven at 100°C for an hour to remove the internal moisture. Fix one end of the roving at the and of the rotor with CA glue, and wrap tightly around the rest of the rotor, covering all the surface. Attach the other end of the roving with CA glue, too. Now mix the epoxy resin and apply thickly. Gently heat with a hot air gun, to make it penetrate the fibres better. Then put a length of shrink wrap around the rotor, and shrink, so that excess resin is forced out, and the fibres are compressed. Now put the rotor in the oven at 60°C for a couple of hours to harden the resin.
Remove the shrink wrap after everything has cooled down, and you should be as good as before.
The only thing I have no Idea about is how the balancing is done, and if it is neccessary.
Julez is offline Find More Posts by Julez   Reply With Quote
Old Nov 03, 2009, 10:19 AM   #5
mattyhawk's Avatar
Thank you!!! That is what I was really looking for. You are my favorite person. Thanks!
Old Nov 04, 2009, 02:21 AM   #6
Julez's Avatar
You're welcome.
Old Nov 04, 2009, 05:29 PM   #7
resU deretsigeR
PaulVi's Avatar
you can set up 2 strait blade razors on a board and place the motor shaft on it.. using a dremel or drill remove matirial on the heavy side till it dose not try to rotate when place on the 2 blades
PaulVi is online now Find More Posts by PaulVi   Reply With Quote
Discussion how do i run a mega motor 400/7/16 faster zjoe555 Power Systems 1 Oct 29, 2009 05:59 PM
For Sale Mega 22/30/3 motor Steve H. Aircraft - Electric - Power Systems (FS/W) 2 Oct 27, 2009 11:59 PM
Help! Mega factory, I sent my motor off over 3 months ago and nothing yet mechengineer03 Power Systems 3 Oct 23, 2009 11:07 AM
For Sale Kyosho FV 1000 - Brushless Mega Motor AndyFly01 Aircraft - Electric - Jets (FS/W) 1 Oct 05, 2009 03:33 AM
For Sale Mega Motor 22/20/2 Brushless Motor DavidJ Aircraft - Electric - Power Systems (FS/W) 0 Sep 05, 2009 11:11 PM
Bored? Want to fight?
Join the RCGroups clan!
