| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Lama V3 Brushless Turning Problem
Hi,
i wanted to make my lama brushless but i have a little problem that my heli when i connect it it works ok but DONT Want to turn left or right when i connect in other way the tail mixer the heli runs and turns left right but dont have power to lift up and the bottom blades are running wild and stop every sec. and again run what can be the problem?? Im using Half of 4in1 esky GWS Vtail <-- Its a strange one flat black 10A ESC from local shop EK2-0704b Gyro Im thinking is it bcoz of gyro ? or mabey the tail mixer is faulty and the esc need to be better ( ill buy normal Trunigy + Prog. Card ) What can be the problem? Ill try to make video tommorow. |
#2 |
Unemployed Engineer
Offhand I'd say it's bcoz of mixer.
#3 |
So you say it may be a mixer problem ? I read a loot about 704b and some people say that are some problems with 704b but tommorow ill but turnigy tail mixer it seems to work ok with lama bl.
Any other sugestions ? |
#4 |
Unemployed Engineer
I haven't tried to brushless my Lama V4, so I can't say.
#5 |
TriC-2
Telebee Gyro with a Dionysus coaxial mixer - this has been reported to work fine here on RCG ...
#6 |
ok but i want to stay with my ek2-0704b gyro i ordered turnigy v-tail mixer should it work with ek2-0704b?
#7 |
Ghetto Web Guy
Telebee gr201 works fine with a Turnigy vtail mixer also. No reason to spend $25 on a "coaxial mixer" and skimp on the gyro. Better to buy a cheap mixer and a good heading hold gyro.
The problem is more than likely your gyro. You may want to use the Esky gyro, but many a person reported problems with using the exact same gyro you have. |
#8 |
so where i can get that gyro ? telebee gr201
#9 |
Ghetto Web Guy
#10 |
many thx man tell me will ek2-0704A will work normally ? I read that it works i can get him from my friend will he work till ill not get that telebee.
Oh and tell me will telebee GR302-AD gyro work as well with it? Bcoz i have him on UK eBay http://cgi.ebay.co.uk/Telebee-Head-L...item1e58d96f9e Can you tell me will he work for 100% ? cheers |
#11 |
Ghetto Web Guy
The GR302 is a bit heavier if I remember right. I'm thinking it was about double the weight of the GR201. No reason to go with a 12 gram gyro when a 6 gram will work.
As far as I know the EK2-0704A was "twitchy" on everyone's chopper who tried it. I'm sure you can get the gyro adjusted down far enough to make it work, the problem then is that the heli will drift rather than hold heading. Btw, what transmitter are you using? |
#12 |
so the telebee gr201 will be the best choice ? Will he work better on my belt than the ek2-0704b ? If yes ill buy 2x
#13 |
Ghetto Web Guy
The telebee gr201 is most definitely a better gyro than the ek2-0704b for this application.
I got to reading your original post more though, and I'm thinking that perhaps you need to hold off on buying a new gyro for a bit till you get both sets of your rotor blades spinning up normally. Did you already order the Turnigy mixer? What about your ESC? You say they are 10a from a local shop. If they're the non programmable 10a that Hobby Lobby normally carries I can tell you that they don't have a high enough resolution to use on a coax, and their end points won't work without a programmable radio. (I've tried them) Last edited by Barak1001; Nov 02, 2009 at 03:50 PM. |
#14 |
yes they should be tommorow or day after now in uk postal strikes
you think mixer may be the problem |
#15 |
Ghetto Web Guy
Just edited my post. I actually think your ESC might be the issue more so than the mixer.
| Thread Tools | |
| Sold Brushless Blade CX2 CX3 Lama V3 V4 Complete Kit | syncronized | Aircraft - Electric - Power Systems (FS/W) | 1 | Oct 24, 2009 01:07 PM |
| Sold Brushless Blade CX2 CX3 Lama V3 V4 Complete Upgrade Kit | syncronized | Aircraft - Electric - Helis (FS/W) | 6 | Oct 24, 2009 12:12 PM |
| Sold Brushless Xtreme modded Lama v3 | malcr001 | Aircraft - Electric - Helis (FS/W) | 3 | Sep 11, 2009 06:33 PM |
| Discussion Selling brushless xtreme lama v3 | malcr001 | Multi Rotor Helis | 0 | Sep 08, 2009 11:21 AM |
| Question lama v3 and the coco lama | Sgt.Squirrel | Multi Rotor Helis | 1 | Aug 25, 2009 01:23 AM |
