Espritmodel.com Heli Air
Old Nov 01, 2009, 12:10 PM
Ypsilanti,Michigan
Joined Jan 2005
Building Ladders/railing for the Douglas Greg
Hello
I'm having a heck of a time soldering brass together to make ladders and rails for my Douglas Greg tug,any ideas on the best way? Was also thinking of using "G" gauge model rail road ladders and railings,if I knew where to look.
Anyone have any ideas?
Bob
Bob L is offline Find More Posts by Bob L
Old Nov 01, 2009, 01:06 PM
Brought to u by letter "Arr!"
mariner02's Avatar
New Hampshire
Joined Sep 2009
I've lost my patience with this same process before, and have since switched to styrene- a lot less headaches, good-looking results, and quicker.
mariner02 is offline Find More Posts by mariner02
Old Nov 01, 2009, 01:55 PM
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
Bob,
It does take some doing, not a 5 min. project
A Hot soldering iron (I'm using a cheap Hobbico 60watt).
Clean and lightly sanded helps.... alot
Pretinning is a huge help
Heat sinks are a must (alligator clips work great)
premade spacers
clamp all your work (with wood clamps, ie clothspins)
solder in place (protect with heatsinks)
heat & prebend all parts that need it and leave em long.
Hope this helps a little. Harry
H.Lauer is offline Find More Posts by H.Lauer
Old Nov 01, 2009, 03:20 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
A good flux goes a long way toward making soldering quick and easy.
A while back I picked up a canister of "Kester" Self cleaning Solder Past flux.
It came from the local electronic distributor.
I'll dip the ends of a rung in the past, then smear the daub onto the
rail of the ladder at the rung location. The rails are taped or pinned down, and
the rung locations are drawn on a piece of paper. (a jig can also be made by
cutting depressions into a piece of wood...)
I melt a little bit of solder onto the end of a 30 watt soldering pen, then
I touch that bit of solder to the joint. The flux melts, and the solder instantly
flows into the joint.
Sometimes, I will Silver solder three primary rungs into a ladder before
I tape or pin the setup onto my pattern or into a jig. Silver solder uses
a higher temperature solder, and requires a little torch work. But once
the silver solder is done, the other rungs can be worked without fear of
either of the first three silver soldered rungs coming undone.
Let's do a tutorial... shall we?
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Nov 01, 2009, 04:52 PM
If it ain't broke, fix it
Cambridge
Joined Aug 2004
hmmm could explain why i struggled the last tiem i did it. i should of know that standard electrical flux cored soldier wouldn't work properly.
thething84 is offline Find More Posts by thething84
Old Nov 01, 2009, 05:39 PM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Beautiful tutorial, thanks Umi!
Brooks is offline Find More Posts by Brooks
Old Nov 02, 2009, 03:29 PM
Winnipeg, Canada
Winnipeg, Manitoba, Canada
Joined Apr 2009
This is very good information.
Thanks UMI
Doug
Doug James is offline Find More Posts by Doug James
Old Nov 04, 2009, 07:31 AM
Joined Jul 2007
Ladders & Rails
due to size of boat 55" cg47MLB, I want to use either 3/16 or 1/4 " brass tubing. (Rod is a lot of weight). My problem is getting good 90 degree bends etc in the tubing.
Any suggestions.
UMI. The display was great. Keep it up.
H Laur What was the size of your railing on the tug?
GB
gbrobbins is offline Find More Posts by gbrobbins
Old Nov 04, 2009, 10:06 AM
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Umi You make that look too easy,
i tried tat once anmade a horrible mess! Thanks for the tutorial though, my next attempt may actually be neat and clean looking. since were on the topic of brass fabricating, what do you use to cut plates of brass with? i have seen acid etching done, but thats beyond my tools. I used side cutters, and that wasnt very magnificent...
Regards
Travis
Guard-Officer is offline Find More Posts by Guard-Officer
Old Nov 04, 2009, 12:45 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
A good straight edge or template on top of thin shimstock
will allow you to make several scores with a good knife.
The brass will part... And can then be cleaned up using
a file or sand paper block. "junk" scissors work also...
Thicker metals I cut on the bandsaw and then sand back to the line.
For etching, there was this Thread...
http://www.rcgroups.com/forums/showthread.php?t=447591
Old Nov 04, 2009, 12:46 PM
JOHN SCALE BOAT's Avatar
MARYLAND
Joined Feb 2007
Practice, practice, and practice some more. I find it easier if weights are used to hold items in place when soldering and clean the brass with a degreaser. Heat the part you are attaching first then heat the main assembly. This reduces the chance of other parts becoming unsoldered.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Nov 04, 2009, 12:48 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Nice work John,... The soda can must be huge!
Old Nov 04, 2009, 01:41 PM
r/c ships and workboats
bellingham, wa
Joined May 2006
Other thing I like is keep a sponge, q-tip, brush, cloth and some water near by. Once joint is soldered, "tin" it with one of the aformentioned items dipped in the water. Helps joint to stiffen fast and cool the parts so that the heat does not work it's evil magic on a finished item/section.
keith S is offline Find More Posts by keith S
Old Nov 05, 2009, 09:55 PM
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
Aimee great tutorial. I was thinking about making 2 ladders for my Jim Wilder and wasn't really sure how to go about it, now I do.
Scott
laser110 is offline Find More Posts by laser110
Old Nov 06, 2009, 03:25 AM
Joined Aug 2005
Beautiful job on the railings and ladder, H.Lauer!
Thanks for the tips, Umi Ryuzuki!
DT56 is offline Find More Posts by DT56
Build Log Started the Hartman Douglas Greg aka (VICKI ELLEN) crowman17 Scale Boats 128 Jun 21, 2012 09:33 PM
Question Crewman For Hartman Douglas Greg Tug Bob L Scale Boats 10 Jun 20, 2012 07:38 PM
For Sale douglas greg hull for sale/trade dnchvs Boats (FS/W) 2 Jun 03, 2009 10:01 PM
Discussion Finally! The Douglas Greg Haoleman Scale Boats 14 Feb 22, 2009 11:29 PM
Alert Douglas Greg Fittings Bob L Scale Boats 3 Dec 15, 2005 06:38 PM
