Old Oct 31, 2009, 10:09 PM
pathfinder is offline
Find More Posts by pathfinder
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
lipo wire
One of the small wires coming out of the balancing plug, into the batt. pulled out.
tell me there is a fix for this?
jimmy.p.
pathfinder is offline Find More Posts by pathfinder
Old Oct 31, 2009, 10:23 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
jimmy.p.
sure. carefully unwrap the lipo and solder the broken wire back on. just be very careful not to touch any of the tabs together or you'll get a nice shock.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Oct 31, 2009, 10:33 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Remove the pin and crimp or solder the wire back on.
First I would discharge the battery to 10.5V
Look at the top of the JST plug, you'll see the pins side exposed. There will be a little barb sticking up. Push down on that barb and the pin will come out.
After the wire is reconnected, push the pin back in till that barb catches on the inside again.
BE CAREFUL - pins are HOT and should never touch each other..
hoppy is offline Find More Posts by hoppy
Old Oct 31, 2009, 10:35 PM
videocruzer is offline
Find More Posts by videocruzer
videocruzer's Avatar
Victoria BC Canada
Joined May 2008
yahh this is a big problem with the balance tabs they use solid core wire. Dream hobbies sells balance tabs with wire that is made with multi strand wire.
videocruzer is offline Find More Posts by videocruzer
Old Nov 01, 2009, 06:49 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Or take the easy way out and don't charge via the balance connector.
rich smith is offline Find More Posts by rich smith
Old Nov 01, 2009, 08:52 AM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Huh? I have never seen this.
Rick, NOT Rich
rampman is online now Find More Posts by rampman
Old Nov 01, 2009, 09:11 AM
rich smith's Avatar
Joined Dec 2006
Rick, NOT Rich
Hah! That's rich.
It's silly to imagine anyone would try single strand wire. It would not last through one charging cycle.
Old Nov 01, 2009, 09:28 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Agree that it would be foolish but I hazard to bet that it would last far longer than one would think, especially if made of very ductile copper.
100% of every balance tap wire that I have seen break has occurred at the soldered interface where the wire is effectively single strand due to solder wicking up the wire (and precisely why I reinforce them here).
If the wire were single strand buss, it'd be stiffer but not likely a whole lot less durable.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Nov 01, 2009, 09:29 AM
So. Cal.
If the wire were single strand buss, it'd be much stiffer but not likely a whole lot less durable.
Mark
Old Nov 01, 2009, 09:51 AM
rich smith's Avatar
Joined Dec 2006
I was thinking of crimping issues with single strand too.
Old Nov 01, 2009, 09:52 AM
rich smith's Avatar
Joined Dec 2006
Old Nov 01, 2009, 11:42 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
one more time
Old Nov 01, 2009, 04:56 PM
Mach 1
pathfinder's Avatar
Joined Jun 2004
I was thinking of crimping issues with single strand too,.......................
I appreciate the help.I will be carefull trying to fix it.I think I will break out the safety glasses.
I am also going to tape the balance plug, to the side of the batt. when not in use.
jimmy.p.
Old Nov 01, 2009, 08:56 PM
So. Cal.
Good idea. Suggest that you leave the tape there permanently. I put a small piece of tape on mine right where the balance wires exit the pack to immobilize them. 99.9% of the time this is precisely where they break due to work hardening of the wire adjacent the solder joint. Immobilizing them makes it nearly impossible to break.
Mark
Old Nov 02, 2009, 11:00 PM
Mach 1
pathfinder's Avatar
Joined Jun 2004
Thank you gentleman,got it all fixed up.
Now I know how the wires are soldered inside a lipo pack.
jimmy.p.
What is the ideal gauge wire for 1200 mAh 2-S lipo packs ScienceGuy Batteries and Chargers 4 Nov 24, 2004 10:21 AM
Alert AW's PolyQuest LiPo wire failure PerfectStranger Batteries and Chargers 5 Jun 13, 2004 07:36 PM
Third wire hook up on Lipo? Wolfman Batteries and Chargers 2 Mar 11, 2004 03:32 PM
Live Wire..what Lipo's? Flatspin Foamies (Kits) 0 Jul 28, 2003 04:09 PM
Alert LIPO-402 Wire Failure-WARNING MikeBanyai Batteries and Chargers 0 Jun 07, 2003 10:19 AM
