Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Oct 31, 2009, 08:00 PM   #1
Setting Up a New Sailplane Trailer. Custom Build
Well, As with everything in life, I have out grown my 12' Carmate trailer and have purchased a new Covenent 14' dual axle trailer as its replacement. The Carmate trailer has been with me for 8 years and unfortunately sat around while I build my full scale airplane, patiently waiting for me to use her again. It was a good summer, but its time to step up.
The primary concern for this new trailer was to have a little larger size and dual axle. Traveling across the country this summer, I found out what I need in a trailer and how I want it set up. The Carmate worked well and is for sale if someone needs a real nice unit. The new trailer is going to incorporate a well thought out design and some custom metal fabrication. Most of the metal has already been fabricated to my drawings and there will be a few other pieces made as we see how it all fits.
This trailer has a drop down gate, which will prove helpful for me since I have a large glider box on wheels. It can now be rolled down the ramp vs having to be lifted and lowered. ( thanks to all that helped me with it this year )
I will post as many pictures as I can to show the progress. I started out today with grinding down the welds and cleaning up the pieces first. After getting them ready, a coat of primer and then topcoat paint was sprayed on. I used gloss black.
This trailer is divided into area's. There is a raised platform at 29" off the floor. This is for the two tow planes I carry, along with a home for the 8 meter Duo Discus when it arrives. This platform is mounted on 1" square thick wall steel tube, welded to a Jr Channel which acts as a leg, runs down the wall and sits on the floor. The tube is very strong and there are three running across the trailer to make up the 8' platform from the rear to tword the front. This is considered a 6' wide trailer, inside dimensions are 14'3 long and 5'9 wide by 6' high.
The quirk about the drop down rear door is that it leaves a 3" space on each side where the rear of trailer meets the drop door. This space limits the clear door opening to 5'3 wide, but more importantly, the space virtually unusable unless you slide in the box and then push it over t the wall. This is not what I wanted to do. The initial problem for me worked out to be a blessing. I was able to design a space on each side where the wings for the tow planes will store. Access is from the top and the front.
Construction started today. The paint was dry enough to handle and I once again, dragged out my dad and dusted him off. I love to work with him and cherish the time I get to spend together. From the photo's you can see the progress made in a half day. The center panel has cutouts so I can access the area if I need to. The area to the left under the platform will have an 8' full out shelf / platform which will store tow sailplanes in cradles and two more will be in the front section of the same shelf, access from the front side door.
The space on the left will also have a 3' wide x 14' long compartment for the Duo Discus wings, or whatever I need to store there.
There will be an area in the front accessed from the side door, this area will house steel tube framed shelves on the front wall of the trailer along with some drawers and bins for spare parts and accessories needed, Chargers, batteries, transmitters, etc.
There will also be room for the chairs and tent.
All said and done. I should get 11 large sailplanes and tow planes onboard with everything secure and safely mounted for travel.
I may need to mount some granite slabs on the floor, under the big box in order to get the weight up on the trailer for a smooth ride. Time will tell.
What about the wings???? where will they store???? ,
More on that later.
thanks for looking.
LEN
  • Name: DSCN1148.jpg
Description: The New Trailer, 14' x 6' x 6' Dual axle, drop down gate with side door and interior lights. The New Trailer, 14' x 6' x 6' Dual axle, drop down gate with side door and interior lights. 128.0 KB · Views: 123
  • Name: DSCN1149.jpg
  • Name: DSCN1150.jpg
Description: This is the one thats being replaced. 12' x 6' x6'
Single axle and side door, two swinging doors in rear. This is the one thats being replaced. 12' x 6' x6' Single axle and side door, two swinging doors in rear. 138.5 KB · Views: 75
  • Name: DSCN1151.jpg
  • Name: DSCN1152.jpg
Description: Kinda cramped now, Of course I made it look this way for the photo, but its not too far off. Kinda cramped now, Of course I made it look this way for the photo, but its not too far off. 85.4 KB · Views: 158
  • Name: DSCN1154.jpg
Description: Front of the trailer. Front of the trailer. 80.9 KB · Views: 107
  • Name: DSCN1155.jpg
Description: My Dad, Len also, fitting the first custom steel supports for the platform. My Dad, Len also, fitting the first custom steel supports for the platform. 69.0 KB · Views: 123
  • Name: DSCN1156.jpg
Description: This is the middle support, notice its 4" off the wall, thats the area where the tug wings will store. This is the middle support, notice its 4" off the wall, thats the area where the tug wings will store. 39.6 KB · Views: 77
  • Name: DSCN1158.jpg
Description: All three supports in place and ready for the dividers. All three supports in place and ready for the dividers. 92.5 KB · Views: 80
  • Name: DSCN1160.jpg
  • Name: DSCN1164.jpg
Description: Compartment divider, 3/4 ply with access holes cut out. Compartment divider, 3/4 ply with access holes cut out. 69.7 KB · Views: 77
  • Name: DSCN1161.jpg
  • Name: DSCN1167.jpg
Description: Putting the help to work Putting the help to work 87.0 KB · Views: 84
  • Name: DSCN1170.jpg
Description: Here is the other side, where there is another space for tow plane wing storage or whatever. Here is the other side, where there is another space for tow plane wing storage or whatever. 77.8 KB · Views: 80
  • Name: DSCN1169.jpg
Description: Getting close, the problem is it got darka nd the trick or treaters we coming. I get scared easy. Getting close, the problem is it got darka nd the trick or treaters we coming. I get scared easy. 67.7 KB · Views: 93
  • Name: DSCN1166.jpg
Description: Side panel to keep the wing compartment closed off. the curved part sticks up above the platform as a "guardrail" for the opening. It will all make sense later when I post completed pictures. Side panel to keep the wing compartment closed off. the curved part sticks up above the platform as a "guardrail" for the opening. It will all make sense later when I post completed pictures. 71.3 KB · Views: 83
Lbuff1 is offline Find More Posts by Lbuff1   Reply With Quote
Old Oct 31, 2009, 08:26 PM   #2
Is this the Nascar forum!!!
Next Year You will need a bigger trailor so dont go crazy
I think Jeff Gordon's is for sale!!
creeve is offline Find More Posts by creeve   Reply With Quote
Old Oct 31, 2009, 08:32 PM   #3
I figured the first response would be from you. Don't forget, I've been to your house, I've seen your garage and shop. You make me seem like a newbie, Remember, those that live in glass houses, should not walk naked.
LEN
Old Oct 31, 2009, 08:36 PM   #4
LEN
That would be scary
Signed on, Look forward to see the progress
Old Oct 31, 2009, 09:30 PM   #5
Len's trailer is so big it's got its own zip code!
SteveR is offline Find More Posts by SteveR   Reply With Quote
Old Oct 31, 2009, 09:40 PM   #6
Should weigh in around 18,000 lbs loaded
He should put retrac's in and spoiler's maybe flaps like them there Nascar Folks
Len will whip it into Cumberland 50mph around the hairpin turns slide into that parking spot , Door opens automaticly and all those awesome planes fold out put togther and ready to burn up the sky!
Sorry Len , Steve started it!!!
Old Oct 31, 2009, 09:52 PM   #7
I would love to have a trailer where the planes could be kept all together. I think at that point we need to look into a tandem tractor unit.
See you tomorrow at the field Steve.
Old Nov 01, 2009, 12:02 AM   #8
Build-fly-crash-repeat...
SPasierb's Avatar
Location: Norwalk, CT aka the Nutmeg State -- I just can't seem to find any %$#@! nutmeg here?
I've already booked space for the JR aerotow. Only third class was still available.
SPasierb is offline Find More Posts by SPasierb   Reply With Quote
Old Nov 01, 2009, 07:37 AM   #9
I have you on Standby Steve, It might be an overbook situation,
len
Old Nov 01, 2009, 08:25 AM   #10
SPasierb's Avatar
Story of my life. I'll be in a hog trailer connecting through Tulsa.
Back to the serious side, the trailer looks FANTASTIC! Can't wait to see the next round of photos of the racking and progress. Len & Len do nice work!
Old Nov 01, 2009, 11:17 AM   #11
cooper998's Avatar
First class work Len & Len, definitely the way to travel with the sailplanes.
Any consideration to adding in a portable generator? When I was drag racing motorcycles back in the 80's I shared a 14" trailer with a friend and we fabricated a small door to the bottom right of the side door just for a portable generator. We set it up on a slide out shelf so we could run it and gas it up without having to carry it around, I'll look to see if I can find some pictures,
Tony
cooper998 is online now Find More Posts by cooper998   Reply With Quote
Old Nov 02, 2009, 02:27 PM   #12
Len,
What are you asking for the replaced (old) trailer?
Gordon
PM me at gordonpearson@chartermi.net
Gordon Pearson is offline Find More Posts by Gordon Pearson   Reply With Quote
Old Nov 02, 2009, 07:38 PM   #13
Hi Tony.
Great Idea. I am absolutely going to go with a generator. I have looked at the little Honda units, they're nice and small. The big issue I discovered this year is having a place to anchor everything in that works every time. As you know, I bring out many gliders and tow planes for the events. I wanted something that can carry the planes and not worry about damage. Or spend an hour packing it up. With the slide out platform and the forward access, it should be easy to secure the planes for travel. The other thing I plan to do next year is make all the batteries in the planes easy to access and label them clearly for each plane. When the plane gets taken apart at the end of the day. I can pull the battery packs out and charge them without taking out all the fuselages. This will be a MAJOR help. Same with the Tow planes, although that will prove to be a little more difficult due to where they are in the body.
LEN
Old Nov 03, 2009, 07:39 AM   #14
Len , Do you have charge plugs on the outside of the fuse in the tow planes
Old Nov 03, 2009, 06:09 PM   #15
No, I keep all that stuff internal. I am to nervous to charge the batteries in a plane and REAL nervous to charge them in a plane and in a Trailer. I did some arithmetic and found it would not be wise to have a trailer fire.
len
Discussion Setting up spoilerons on my 9 Cap yellowcolorado Video Piloting (FPV/RPV) 3 Oct 27, 2009 02:26 PM
Discussion Graupner/JR MX-22 setting up gliders... skyzking Radios 0 Oct 22, 2009 07:52 PM
Discussion I need help setting up my dx7 as a master trainer of my dx6i lazer155 Radios 14 Oct 14, 2009 12:53 PM
Discussion Need help setting up Spektrum DX6i with FS one Phil Madren Simulators 1 Oct 11, 2009 06:01 AM
Discussion How to make custom airfoil templates and setting up a hotwire cutter? GreenAce92 Sailplane Talk 0 Mar 02, 2009 09:22 PM
Bored? Want to fight?
Join the RCGroups clan!
