Old Mar 09, 2013, 03:22 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
OK, will do. Thanks again.
racin06 is offline Find More Posts by racin06
Old Mar 09, 2013, 03:27 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
N/P.... I do like them better then stock and makes screwing the wings in a whole lot easier now.
livinma1 is offline Find More Posts by livinma1
Old Mar 09, 2013, 05:54 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
They certainly do....for most of my planes, I Loktited the shaft into the nut, but for the 70 Velox, it definitely works best to Loktite the shaft into the wing.....This is just how I like to do it...YMMV...
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
SteveT.'s Avatar
San Jose, CA
Originally Posted by livinma1 View Post
Was too busy editing....LOL.. But at least we agree which ones are good replacements.
Yes sir we certainly do...
SteveT.
Old Mar 13, 2013, 04:13 PM
chq28 is offline
Find More Posts by chq28
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Man, this plane takes some long screws to mount the motor(v1). I had some M4 at 75mm, still not long enough. Just ordered some 80mm, I think those should do it. If not, I'm not sure what to do. I couldn't find anything longer.
chq28 is offline Find More Posts by chq28
Old Mar 13, 2013, 04:27 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
get stevet or some other machinist to make you some nice standoffs. then you can use four short bolts and if you have to pull the cowl off at the field your buddies will all compliment you.
Irg is offline Find More Posts by Irg
Old Mar 13, 2013, 04:32 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Your running into the same issue I did. Ended up with some 80mm.
Which are hard to find...
Update: Just checked I have 85MM and those are what worked for me. Using the 5320 & the light backplate.
This is what I ended up with in regards to spacing and needed a few washers to get that.
Old Mar 13, 2013, 06:38 PM
chq28 is offline
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
That's the same set up I'm running. Where did you find 85mm at? The biggest I can find are 80mm. It will be close, I'm hoping they work.
Old Mar 13, 2013, 08:37 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Ironically there is a place down here that had them in stock for a railroad project. An he had to buy it by the thousands and unfortunately stuck with them.
call Fastenal in Tucker.. I think its 85 or 90mm. Ask him which one he purchased for a train project and thats the one you need.
http://www.fastenal.com/web/products...l.ex?sku=35401
I have so many different sizes on my work bench that I may of measured the wrong one. To give you a better answer I will have to take the cowl off. Which I have no issue with since I need to swap out to a 19x8 this week.
Old Mar 13, 2013, 09:16 PM
SteveT.'s Avatar
San Jose, CA
I can do that....
SteveT.
Old Mar 13, 2013, 09:47 PM
chq28 is offline
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Originally Posted by SteveT. View Post
I can do that....
SteveT.
So what do these standoffs look like and how do you get your hands on them
Old Mar 13, 2013, 10:07 PM
SteveT.'s Avatar
San Jose, CA
Like these, (in any length needed) and I make them on my lathe... (That's how I get "my" hands on them)...as to how "you" get your hands on them, is to give me the exact length you need, and then you pay me a nominal fee via PayPal and I make them for you....
SteveT.
Old Mar 13, 2013, 10:25 PM
chq28 is offline
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
SteveT.
Those look like the ticket. Finding the right screw is proving hard. Time for some measurements
Old Mar 23, 2013, 03:07 PM
chq28 is offline
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Got my first two flights out of the way. It flew perfect and Motrolfly 5320 just sounds mean in air. That motor has some crazy power! Overall very happy and can't wait to take it back out again.
My only complaint, the wing bolts. Those ara a pain to get in out. I need to find something different.
Old Mar 23, 2013, 03:56 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
double check size, but get you some of these
http://store.aztechaeromodels.com/st...product_id=129
i just maidened my first plane with those, and they are amazing. i really like loctite-ing the threaded shaft into the wing, slide the wings on, then just tighten the head and you are good to go. works amazing better than the stock wing bolts, and they have very very thick rubber washers on them which compress and make sure you get a good tight fit
rcbirk21 is offline Find More Posts by rcbirk21
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14319 Jun 14, 2016 06:25 PM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 12:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 02:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 08:37 AM
