Old Jan 13, 2013, 05:28 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Glad to hear you are getting your plane dialed in the way you like it. It's always more fun that way!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 13, 2013, 05:33 PM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
Originally Posted by Irg View Post
damnit, I have to stop posting at 6am. I meant maybe they made your tail out of oak...
Haha! You're doing it again! You'll never get to set up the CG for my planes!
(Yes you will! I'm going to enlist your services when it's time to maiden my 72...)
NJSwede is offline Find More Posts by NJSwede
Old Jan 13, 2013, 05:35 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
it's true. the real lesson, for me anyway, is that you should always be open to tweaking your setup. I have a tendency to set it and forget it, but my increasing desire to have the plane flying the same way every flight is causing me to reexamine.
Irg is online now Find More Posts by Irg
Old Jan 13, 2013, 05:46 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
I am running the 4330 on my 72" and I am slightly nose heavy with my 6s 5000 packs.
I am running a 2200 mah 2s for receiver pack though, but I plan on ordering some smaller ones.
When I did the finger test on the plane, I though it was tail heavy also, but I flew it anyways and it was fine.
wamsy55 is offline Find More Posts by wamsy55
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
was out flying today and my canopy flew off and is destroyed ,i forgot the screws for the canopy and relied on the spring catch to hold it on,it is a gasser,shouldn't have flown it but i was already at the field and what the heck right,well was moving and grooving and pop ,there it went.it still flew great even without the canopy so i finished the tank and brought it home, so i am on the hunt for a blue canopy for the red,white and blue extra if anyone has one they are willing to give up please pm me thank you in advance,
lugnutz is offline Find More Posts by lugnutz
Old Jan 13, 2013, 05:50 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
clearly I don't know the tail from the nose.
I stayed local today due to the weather not being ideal, but I'll let you know next time I'm headed to GCA.
Old Jan 13, 2013, 07:58 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
A former member at Floyd Bennett who was known through out the imac scene mentioned early on that it would take close to 100 flights to trim out his airplane before he would fly it in competition. So your right you always have to tweak it.
Where do you have the receiver pack ? On top of the main flight packs.
livinma1 is offline Find More Posts by livinma1
Old Jan 13, 2013, 08:10 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
Behind the main pack, but in front of the wing tube.
Old Jan 13, 2013, 08:21 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Gotcha.. I was also thinking about switching to a receiver pack for additional weight vs using the Castle BEC... I searched some past posts and a lot of guys ended up putting weight since they came out pretty tail heavy also. I will just add the dead weight and fly the blasted thing.
Old Jan 14, 2013, 06:39 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
Mark, if you need weight do the BEC pro and a battery to power it. working well for me, but clearly we have slightly different airframes.
I just watched this all the way through. really fun to watch, wamsy.
3DHS 72" Extra: (7 min 10 sec)
Old Jan 14, 2013, 10:07 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
http://youtu.be/HRUH7iuO-Ds
So de-solder the BEC Pro from my ESC and put on some leads and plug in the receiver pack to the bec pro. And I guess I can then run my hitec 7955s at the 8volts.. What battery pack are you using ?
Old Jan 14, 2013, 11:42 PM
chq28 is offline
Find More Posts by chq28
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
I'm getting ready to throw money down on a Motrolfly 5320. All this talk about needing weight up front, Is it worth getting the carbon fiber x-mount to save weight? Normally I would, but it sounds like this plane cold use a little extra weight up front.
chq28 is offline Find More Posts by chq28
Old Jan 14, 2013, 11:46 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Without the lightened backplate it will not line up with the pre-existing blind nuts. You will have to redrill and use a nut on the inside to lock in your new screws or bolts. In hindsight I should of just kept the entire motor together and just redrill but I have no tools with me since moving.
Old Jan 14, 2013, 11:52 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
Thanks IRG.
I am also running 7955's at 8 volts .. and they are awesome on this plane.
Old Jan 15, 2013, 12:01 AM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Thanks IRG.
Nice.. I will see how much weight I need to atleast get the plane to balance. I might need a 2s 2200 pack..
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14288 Feb 09, 2016 10:57 PM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 01:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 03:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 09:37 AM
