Old Mar 29, 2010, 10:26 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
you can do 6S either with a lighter motor, your choice of Hacker A50-14S or 16S, or Scorpion 4024-12 or 4035, or you can just run the same setup I'm running, and do either 6S on 20x10 or 8S on 18x10. You can actually go back and forth with just a prop change on the Hacker 12L.
blucor basher is offline Find More Posts by blucor basher
Old Mar 29, 2010, 10:28 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by theKM View Post
Sooo looking forward to that beastie at SEFF...
Yeah....but we only get to SEE them there.... I want one now (said in my best 4 year old voice).....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Mar 29, 2010, 10:34 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
SteveT
ALL good things come to those that WAIT !
Lonelasso is offline Find More Posts by Lonelasso
Old Mar 29, 2010, 10:35 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
you might can touch it at seff.i plan to
Manta1 is offline Find More Posts by Manta1
Old Mar 29, 2010, 10:51 PM
kygreen229 is offline
Find More Posts by kygreen229
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
Ben,
I really wanna do this on 6s on the scorpion 4025-12 because of cost and seem to be good motors..Ive just heard that the prop adapters are questionable. What do you think? Is there a different prop adapter that you could use on it?
kygreen229 is offline Find More Posts by kygreen229
Old Mar 29, 2010, 10:52 PM
Lonelasso's Avatar
Joined Dec 2006
Originally Posted by Hypersprint View Post
I think I heard the voices, I can just imagine how loud they must be IN your head
You have no idea ! "he's gonna do WHAT with a pre-production ARF...NAH, he's NOT....omg..he IS ! Whoa.....he pulled it OFF...OF course he did....it's Ben at his BEST !"
Old Mar 29, 2010, 11:04 PM
Joined Jun 2003
ky - A steel one is better. Perhaps we can get one from Neu in the right diameter, someone here will know.
Old Mar 29, 2010, 11:11 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Originally Posted by kygreen229 View Post
Ben,
kygreen,
I own SEVERAL Scorpions including 3 4025-12's.
The stock adapter works just fine as long as you take a little time to rough up the shaft with some sandpaper and apply a little blue loctite, tighten it down and let it dry.
The KM also has a technique of tightening it down and twisting it counter-clockwise to lock it down on the shaft. Hopefully he'll come on and clarify.
I like everyone else prefer a bolt-on adapter, but I really like the power and selection of the Scorpions, so I sacrifice the adapter. But I've not had ANY problems with them since I've started sanding and loctiting them.
Also I kinda prefer an aluminum adapter as I would rather bend a prop adapter than a motor shaft (because I seem to crash alot). IMHO.
Fred
RotorJockey is offline Find More Posts by RotorJockey
Old Mar 29, 2010, 11:13 PM
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
ok cool ya if anyone knows if there is one out there that would be awesome.
-Kyle
Old Mar 29, 2010, 11:14 PM
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
Ok that sounds good too. I have a torque motor on my little EF yak. Its a smilar design as the scorpion one correct?
Old Mar 29, 2010, 11:22 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by RotorJockey View Post
kygreen,
Fred
yeh, it came off on me, twice. It took some violent cavitating maneuvers to get it off though. First was roughing and uber tightening, second was blue loctite, and now it has CA on there (red may work too). My motor is the S-4035-380, and the shaft it latches onto is very short. The 4025's have a longer shaft to grip. Either way, I'm now recommending getting quite serious with some kind of adhesive goo the first time around
...fwiw... I still love the power train, it's super smooth.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Mar 29, 2010, 11:26 PM
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
so the blue loctite wasnt holding either? with all the loctite or glue how do you get it off if needed for servicing and what not haha?
Old Mar 29, 2010, 11:30 PM
SteveT.'s Avatar
San Jose, CA
Apply heat (high temp soldering gun or iron) to the prop adapter...that softens the adhesive for easy removal...
SteveT
Old Mar 29, 2010, 11:31 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
can service the plane fine. I don't think I've ever taken an adapter off a motor once it was on unless the adapter itself needed changing. I expect a wrestle if I ever damage this adapter and need to change it. heat helps.
Old Mar 29, 2010, 11:36 PM
kygreen229's Avatar
Boise, Idaho
Joined Jun 2009
why do I always forget the soldering iron heat method!! ha. well cool Im feeling more confident with this motor if the prop adapter will stay on.
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14300 Apr 06, 2016 01:53 PM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 12:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 02:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 08:37 AM
