Old Jul 31, 2011, 09:03 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
we fly a little harder than most . Mine is set at 6. I had it at 7 but hit LVC when I was pushing it really hard so I put the 6 to be on the safe side.
losifanatic is offline Find More Posts by losifanatic
Old Aug 01, 2011, 11:11 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
7 minutes here.i usu have about 18-25% left in the packs depending on what I am working on
Manta1 is offline Find More Posts by Manta1
Old Aug 01, 2011, 11:29 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
I just did a few searches and I did not find any good info on this subject so I figured I would ask.
What openings do I need to make for a electric setup for cooling? Do I need to cut out the back of the tunnel to stop a air dam effect. What cut outs on the bottom do I need to make?
Pictures would probably help. Can someone point me in the right direction.
Enterprise7 is offline Find More Posts by Enterprise7
Old Aug 01, 2011, 11:34 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
I cut out the two pannels with the slots on them and was using those for awhile. I was recently experimenting with trying to find a way to bring motor temps down. I started with baffles and they helped a ton. I also cut out the 2 slots right behind the last plate i screwed on and it also helped a lot.
I will try to go get a picture.
joesmith285 is offline Find More Posts by joesmith285
Old Aug 01, 2011, 11:40 PM
Game on
Joined Nov 2008
Pic
Old Aug 02, 2011, 06:49 AM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Need to clean up my bench... Misplaced the screws that hold on my spinner to the backplate. Anyone know what size screws are used in the Extreme Flight 3 Inch spinner. I know a couple of you are using that same spinner.
Regards
livinma1 is offline Find More Posts by livinma1
Old Aug 02, 2011, 12:23 PM
USA, NH, Manchester
Joined Jun 2010
Thanks for the pic Joe. It appears that you cut out the back of the tunnel. Is this correct?
Old Aug 02, 2011, 12:28 PM
USA, NH, Manchester
Joined Jun 2010
On another note I was just outside playing with the watt meter with different props on my Motrolfly 310kv motor. I know from my slick that it is very nice on 8s with a 19x10 xoar. It puts out 2400 watts on a fresh battery and quickly went down to 2200ish on Sky Lipo 4000 40c.
I was also playing with the idea of occasionally running 6s for the bigger prop and torque. I tried a 20x10 and a 21x10 xoar. The 21x10 was putting out roughly 1600 watts of power at 60ish amps. Has anyone tried a 22 inch prop with 6s. I think I will try to fly with the 21x10 at some point but I wondered if it was worth even looking at a 22 inch prop.
Old Aug 02, 2011, 12:30 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Can someone tell me exactly which, what, and where I can get the extra spacers/bolts/hardware needed to mount a motrofly on the V2 kit?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Aug 02, 2011, 12:37 PM
prozac is offline
Find More Posts by prozac
prozac's Avatar
USA, TX, Grapevine
Joined Sep 2008
I wound up going with 6" of all thread (8-32). with washers and nylock nuts I bought at lowes. I used some of the spacers included in the kit along with some aluninum spacers I already had. I would like to add a second X-mount in the middle of this setup, becuase I don't like how long the span is. Sorry, I can't tell you exactly how long it is, i just played with it till it fit well and I'm at work currently.
That being said, it has held up for a couple of flights now. I tried this with 6s and a 19x10 and 8s 18x8. I like the 8s myself on this particular motor.
I forgot to say, cutoff the extra all thread once you have your distance worked out.
prozac is offline Find More Posts by prozac
Old Aug 02, 2011, 12:43 PM
USA, NH, Manchester
Joined Jun 2010
I just used three different spacers on the 8/32 threaded rod just like the post above. I had some extra spacers from my 71 slick so I used the long and short one from the extra and another from the slick. I agree with the idea of adding another x-mount as I had not thought of that.
Old Aug 02, 2011, 01:43 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
I used a hacker motor but I had to go to Ace hardware and picked up 1/2 inch diameter spacers.
Old Aug 02, 2011, 01:52 PM
DFflyer is offline
Find More Posts by DFflyer
DFflyer's Avatar
Joined Mar 2010
What do you guys think is the best motor for an 8s setup? I've been happy with my A40-10s and it would be nice to get some reward points by buying a hacker, but if there's a better choice I'd be willing to give something else a try also.
DFflyer is offline Find More Posts by DFflyer
Old Aug 02, 2011, 01:56 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
You can certainly go with a Hacker A50-12L on 8S swinging a 18x8 or 18x10. That is what some of the guys here were using.
Old Aug 02, 2011, 02:51 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Or an A50-14L, which was suggested to me by the folks at Aero-Model...but you would have to use a larger prop with the 14L as it is a lower KV.
And.... I just got off of the phone after talking to Mike Donovan, at Aero-Model... If you are going to use an A50-12L, do NOT go larger than an 18X8 or possibly an 18X10,and stick with the Xoar props, not APCs, as larger or APC even in the 18X10 is going to eventually cause you problems. If you read Aero-Model's "set-up page, they actually call for a 14x10!!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14271 Feb 01, 2016 04:08 PM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 01:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 03:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 09:37 AM
