Old Jan 01, 2010, 03:04 PM
ssflylow is offline
Find More Posts by ssflylow
TEAM CANUCKER HUCKER
ssflylow's Avatar
Canada, AB, Medicine Hat
Joined Sep 2003
ssflylow is offline Find More Posts by ssflylow
Old Jan 01, 2010, 04:59 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by blucor basher View Post
gofly - On most gas engines, you have a choice of
stock muffler (small, light and loud)
Pitts style muffler (little bit quieter, little heavier)
Canister style muffler (lives inside fuselage, very quiet)
"tuned" pipe (long, expensive, more powerful, quiet)
We're working to have all of those options for the 72". More details to follow.
the DLE-30 produces about 2500 watts equivalent, about like a good 8S system.
On the canister muffler: If it lives inside the fuse, where doe the exhasut exit.
With the tuned pipe: Is the muffler long and run along side the fuse?
goflyhighrc is offline Find More Posts by goflyhighrc
Old Jan 01, 2010, 05:28 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by Shawnlh View Post
It looks like the motor choice will be the Scorpion S-4035 series. What Kv though, I'm not sure, that will depend on prop choice.
I was looking at the 4035-460, with a xoar 19x8, Hyp. CX 4s 4000's x2, WR Hercules Super bec, and a CC110HV. That should do the trick and get close to 2500 watts at around 85 amps peak.............I think.
I'm running the 4035-380 on 6S in the 65Vyper... this alone could poke the 72 Extra along very well with a 19x8 (I'm using an 18x8 at the moment). With volts from two more cells, means this wattage goes up a bunch as it is... I reckon the low Kv's is what you're after on 8S. I'd rather prop up to get wattage (bigger props rock 3D so nicely) than turn smaller props faster to bring the wattage down on too high a Kv motor.
I really dig the 4035 motor though, a sweet piece of equipment.
theKM is offline Find More Posts by theKM
Old Jan 01, 2010, 08:12 PM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
On the canister muffler: If it lives inside the fuse, where does the exhasut exit.
It makes a U-turn and exits out the bottom of the fuse right behind the cowl in front of the landing gear.
It's long and runs inside the fuse and exits out the bottom behind the wings.
blucor basher is online now Find More Posts by blucor basher
Old Jan 02, 2010, 01:46 AM
jadamian75 is offline
Find More Posts by jadamian75
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Originally Posted by G.P. View Post
I would do alot of ground testing before using the internal BEC on 8s. You'll be pushing both the ESC and BEC to their limits, which means lots of heat. You'll have to choose your servos carefully and make sure that there is absolutely NO binding in your setup. Keep in mind that the internal bec is rated at 5 amps max....and I don't know what input voltage that is rated at. Max bec output goes down as input voltage goes up.
Probably easier and safer to go with an external BEC or seperate Rx pack.
+1
Joe
jadamian75 is offline Find More Posts by jadamian75
Old Jan 02, 2010, 01:54 AM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
goto bed Joe
xsubsailor is offline Find More Posts by xsubsailor
Old Jan 02, 2010, 02:15 AM
jadamian75's Avatar
Joined Oct 2007
Originally Posted by xsubsailor View Post
goto bed Joe
It's 2 AM in New Jersey and only midnight in Colorado.
Old Jan 02, 2010, 06:57 PM
Joined Nov 2006
Not knowing anything about gas, the tuned pipe sounds intriguing. If it exits out the bottom behind the wings it seems like it would keep the plane much cleaner.With the tuned pipe or cannnister is there any cutting or modes that need to be done or is the plane ready to go with them.
gofly
Old Jan 02, 2010, 07:24 PM
cwojcik is online now
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
It depends on the airframe. Go to the extreme flight website and read the assembly manuals for their 50cc stuff and you will be enlightened.
cwojcik is online now Find More Posts by cwojcik
Old Jan 02, 2010, 07:48 PM
Joined Jun 2003
Gasoline doesn't produce goo like glow-fuel engines do. So, not really a concern.
Old Jan 02, 2010, 09:04 PM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
gofly
There are generally separate can or pipe mounts that are installed that hold the can/pipe securely. You generally remove the covering over a couple of bays in the belly which are replaced with vented plates to let air out. A little more work then setting up mufflers, but performance is enhanced with a pipe while sound is dramatically reduced with a can.
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Jan 02, 2010, 09:22 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I finally got to hear some canned planes about a week ago in person.sounded very cool...
Manta1 is offline Find More Posts by Manta1
Old Jan 02, 2010, 09:50 PM
ssflylow is offline
ssflylow's Avatar
Joined Sep 2003
Never mind..................................
Old Jan 03, 2010, 09:16 PM
routemech is offline
Find More Posts by routemech
shredding Ultracote since 2009
routemech's Avatar
Frederick CO
Joined Jul 2009
Scott/Ben,
I know someone has probably asked this... When is it going to be available?
Are you guys flying a prototype yet?
Also I was going to make this my first gas airplane, but now thinking maybe should do a 50cc... how will this compare to one of the current 3DHS 50cc airframes like the 87" Extra?
routemech is offline Find More Posts by routemech
Old Jan 03, 2010, 10:55 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Texas Electric Flight Festival (T.E.F.F.)
Just reminding everyone of this upcoming event ! (forgive me if I've already posted in this thread....my memory is a bit 'fuzzy' )
Ben and Amy are committed to attend ! Here's the link-- T.E.F.F.
Lonelasso is offline Find More Posts by Lonelasso
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14271 Feb 01, 2016 04:08 PM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 01:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 03:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 09:37 AM
