This thread is privately moderated by derekshep, who may elect to delete unwanted replies.
Old Oct 31, 2009, 12:29 PM
derekshep is offline
Find More Posts by derekshep
Trader Rating: 4
Joined Aug 2009
Trader Rating: 4
For Sale
FEW things for sell NOS stuff 40% off retail
Ntimidator™ Illuminated LED Nitrous Purge Kit (X2)
http://www.jegs.com/i/NOS/741/16033/10002/-1
$169 brand new for jugs....both i have are brand new never opened...
will sell for $100 shipped OBO (each)
Features
<LI class=feature>Unique Kit Uses Bright Blue, red, green or white LED <LI class=feature>(you pick the color)
Illuminates a 4 ft. Plume of Nitrous
Strikes Fear into Nighttime Competitors
Install Easily w/Common Hand Tools
Fits All Nitrous Kits w/-4 AN Feed Line
Programmable Progressive Nitrous Controller
http://www.holley.com/15834NOS.asp
Price: $626.73 brand new.... the one i have is brand new.... willing to sell for $400 shipped OBO
Programmable Progressive Nitrous Controller (Kit #0050NOS required) – This top–of–the–line unit can be programmed to control both the amount of nitrous that is flowed to the engine (from 20–100%) and the time desired to “ramp up” from first hit to full flow. For example, you can program the controller to flow 25% of the nitrous 1.5 seconds into the run and increase it to 75% nitrous at 5.3 seconds. Or, it can go all the way to 100% much sooner. This enables a racer to “fine tune” the power curve of an engine to best utilize prevailing conditions. It can also be used to activate a retard box or 2nd stage of nitrous.
Installation Notes
Kit #0050NOS Required. All NOS controllers are safe to use with all production NOS solenoids. Other manufacturer's may have excessive draw. Nitrous Solenoids should not exceed 10 amps. Fuel soleniods should not exceed 5 amps.
Features
<LI class=feature>Control Nitrous Amt. To Engine
Control Ramp Up Time Desired
Fine Tune Power Curve
Sophisticated and Progressive
Very Easy To Use
Launcher Progressive Nitrous Controller with LCD touch screen (X2)
http://www.holley.com/15975NOS.asp
price $824.94 each....brand new...never opened...will sell each for $500 shipped OBO[/SIZE]
Any racer will tell you it''s easy to make horsepower…getting it to ground is the hard part. Since making runs on the knife–edge of traction is essential to get the win light, serious nitrous racers utilize methods to soften the "hit" when they squeeze the juice. If it's too violent, the run goes up in tire smoke; too soft and E.T. is left on the table. Until now, taming a nitrous system involved a dizzying array of dials, switches and relays. Those days are gone
Nitrous Oxide Systems is proud to present the Launcher. It combines all the functions a nitrous racer could ever want into a single, easy–to–use controller. This handy device can be programmed to independently control up to 4 stages of nitrous from a laptop computer or via an available full color 3.5” LCD touch–screen. Easy to use graphical software makes the Launcher a breeze to program. The launcher is available in 3 basic configurations. It is available as the launcher controller only; the Launcher controller with 3.5” color LCD touch–screen (Includes stylus and mini SD card for data–logging); or the Launcher controller with the handheld tuner for data–logging and quick changes in the staging lanes.
Nitrous control has just been taken to the next level
Launcher Progressive Nitrous Controller with full color touch screen LCD
Features
Fully Programmable via laptop
Compatible with Windows 2000, ME, XP, and Vista
NEW innovative NOSbus 2-wire network interface for seamless integration with other Holley/NOS supported products
Free software and firmware updates updatable by the user, downloadable off i-net.
Available with a Handheld controller with SD card slot and USB interface for quick changes in the staging lanes and data-logging without laptop in the vehicle
Available with a 3.5" Color, touch screen LCD for the ultimate in programming and looks. (No laptop Required)
3.5" Color, touch screen LCD also features a SD card slot for saving configuration files and data-logging as well as a USB interface.
Full data-logging capability for easy reviewing of past runs through laptop, handheld controller (SD card) or LCD touch screen (SD card)
Ability to save configuration files for easy set-up at different tracks or for weather conditions.
Handheld controller or LCD touch screen allows changes in the staging lanes without laptop.
Fully programmable 2 stages of nitrous control and with the optional slave controller you can add two more stages for a total of 4 fully programmable stages of nitrous control.
Can be programmed to add or take away nitrous at any point to compensate for track or weather conditions.
Integrated TPS for use on fuel injected or drive by wire vehicles without the need of a separate WOT switch.
Two programmable activation inputs.
Activation of nitrous can be provided from a power input, ground input, or a Falling or Rising TPS signal.
Features an internal MAP sensor for nitrous ramps based on boost PSI
Solenoid control channels with a load capacity of 40 amps for use with large solenoids
1st gear lockout to prevent the nitrous from being triggered until the RPM cutoff has been hit the first time
Two 1 amp general purpose outputs for timing retards, purge, or any activation switch (two additional on the optional slave controller)
Use WBO2 controller p/n 15979NOS for rich or lean nitrous cut off. Requires Holley WBO2 sensors p/n 534-198 Bosch or p/n 534-194 NTK (NTK requires a 534-199 extension harness)
Customer has the option to enable lean and/or rich nitrous cutoff with a programmable delay time up to 1 second. Richest/Leanest AFR data is also logged along with the nitrous data for advanced analysis.
Pause Enable Option - when retriggered, (pedaling event) the ramp will continue where it left off (rather than starting over from scratch)
Nitrous pressure sensor input for data-logging
derekshep is offline Find More Posts by derekshep
For Sale For Sale - House of Balsa P-51 D .20 stand off scale, kit K-40-price reduced Pilot_Tony Aircraft - Fuel - Airplanes (FS/W) 3 Feb 07, 2010 02:42 PM
For Sale few things forsale derekshep Non R/C Items (FS/W) 1 Oct 27, 2009 08:07 AM
Off Site Some Radio carbon art DVD's for 40% off interplanet Aircraft - Sailplanes (FS/W) 1 Sep 30, 2009 11:43 AM
For Sale Spektrum Stuff, Servos, Futaba Stuff. Single guy Sell-off. Curt S Aircraft - General - Radio Equipment (FS/W) 8 May 05, 2009 07:26 AM
For Sale A few things for sale with FREE STUFF!!! laughingstill Aircraft - General - Radio Equipment (FS/W) 3 Nov 10, 2007 03:56 PM
