Go Back   RC Groups > Vendors > Hacker Brushless
Old Oct 30, 2009, 08:00 PM   #1
"Do it with batteries"
DavidN's Avatar
Motor choice
I have an alfa spitfire. weighing of components I am at 14.5 oz.
My choice is A20 30M or 26M
ESC hyperion 20
Battery TP1320 but could save an oz with 910.
Prop suggestions?
DavidN is offline Find More Posts by DavidN   Reply With Quote
Old Oct 31, 2009, 06:17 PM   #2
Oly crap.. Deese ease not gud!
hpapilot's Avatar
Send a message via AIM to hpapilot
You might want to go with the 26M for a little more speed for that airplane. I've run that motor extensively with an APC 9x6 slow-fly prop and it performs very well with great flight time on a 3S 1320. I suspect the 910 would work very well too. You may want to experiment with a smaller prop for speed, my motor was on a foamy so I can't say for sure what would work best for your Spitfire.
Almost forgot, that foamy was about 16 oz and had ballistic vertical... your plane should perform VERY well.
RJ
hpapilot is online now Find More Posts by hpapilot   Reply With Quote
Old Oct 31, 2009, 09:04 PM   #3
DavidN's Avatar
Thanks for the info. Do you recall the amps on the 9x6. I am wondering if Hyp 20 is enough or maybe an 8x6 would be betterfor the spit since it might spend more time at higher throttle.
Old Nov 01, 2009, 03:09 AM   #4
hpapilot's Avatar
Never checked the amps, but I was running a Hacker X-12 ESC, so a 20 amp should be way more than enough.
RJ
Edit... Actually... now I can't remember if it's a 12 or a 20. Either way though, 20 will be plenty.
Old Nov 01, 2009, 11:47 AM   #5
DavidN's Avatar
Old Nov 02, 2009, 05:24 PM   #6
GWRIGHT's Avatar
I used to run the 26M with an 8X8 prop in a little foamie coarsair of the same size (the one from electrifly). 83mph on radar. The 1320's are taxed a bit with that setup, needs slightly larger cells. I used 1320's but they came down a bit too hot.
GWRIGHT is offline Find More Posts by GWRIGHT   Reply With Quote
Old Nov 02, 2009, 09:50 PM   #7
DavidN's Avatar
Thanks Gary
Maybe the new generation cells will handle the amps better
Help! Envee and tornado 3615: need help with motor choice Synergy1 Sport Planes 10 Oct 30, 2009 06:17 PM
Discussion Motor choice for standard AVA marc 540 Thermal 15 Oct 14, 2009 11:40 AM
Discussion Best receiver choice, motor and speed controller? atari7202 Video Piloting (FPV/RPV) 4 Sep 28, 2009 08:58 AM
Motor choice for my X250 Brushless or Stock??? Joe Elston Electric Plane Talk 6 Sep 06, 2001 01:10 AM
motor choice for LMH potifar Electric Heli Talk 4 Aug 05, 2001 11:01 PM
Bored? Want to fight?
Join the RCGroups clan!
