| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
GILL
As promised rudder linkages. I have used a number of methods over the years. The easiest is with collets or the adjustable servo mount. The great thing about the collets is you don't have to worry about the length +/- an inch or 2 is OK.
All ways keep the linkages as short as possible. The longer they are the more chance of problems I would suggest that you make the rear part of the deck removable or a hatch to service the rudders. Last edited by GILL RC; Nov 05, 2009 at 09:04 AM. |
#32 |
Great Help Gill - Thanks
#33 | |
Since I don't have the PE set of the mighty Mo I can't comment on that PE set. But I got another PE set from GPM for their 1:200 IJN Shikishima that you may refer to. Their PE are easy to use in my view, but you may need some modification since it is designed for their paper model. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Ivan |
#34 |
Amazing Ivan - Thank-You - Steve
#35 |
Sides On
I got the 4 side pieces on and will commence planking - Bit rough - as I am no carpenter and a bit impatient to say the least - But I figure it's nothing a little filler can't cure and a few coats of Finishing ZPoxy well sanded. (or whatever else you guys suggest) - Steve
#36 |
WooHoo!
Lookin' good. Here's a couple of shots of a dual rudder set up I did. Worked out well. Dumas tiller arms.
#37 |
Thanks Bob - That grey stuff has got to be a waterproofer or like that eh? (Canadian) - Steve
#38 |
WooHoo!
It's a fiberglass hull, just gray primer.
#39 |
GILL
Thats a nice tiller set up, very short links, no slop. Rudder posts are well braced and no metal to metal contact. You can check the airplane control horns, thier used for ailerons and nose wheels. Look for ones with set screws. I have had the double nut sandwich come loose.
You can also see why I suggest that the rear deck be removable. |
#40 |
Hello
Hello Steve. GOOD Job !!!!!!!! I just back to the boards. Been busy and have not had the time to get back to this one.
YOU Hit it lucky on those small parts I was hoping you would get them with that one when you were talking about it. Looks like it did not take you all that long to build it. I was looking at the props and I know you had it up side down but from what I can tell and i will amit I could wrong. Looks like you have the props on the wrong side. I was looking at cutting edge of them. Like I say it just be upside down . ONE way you can tell if you are right . When you pull on the radio and it is going forward out on the work bench see if the props are pushing air when you pull on your radio . I am sure you know about that but I thought I would just throw it at you. Well I am building an 1.350 kit a world war 2 revell kit. About 31 inche long and bout 2 inche wide. I am converting it to the montana class. But I like the work you did on yours. So when you get it in your pond you will have to show us . By the way did you glass the hull or resaon it . KEEP Up the good work. So do you have plans of it doing any of the tricks with it that we all talk about a wile back? DON YOUR Portland Rustbucket . |
#41 |
Hi Don - Thanks for the kind words - I will make sure the props are correct - I am going to coat the hull with ZPoxy Finishing Resin only - I think a few coats should make it strong enough for my purposes - I don't plan on anything fancy - If I can just get it reasonably finished and running on the water I will be delighted - Steve
#42 |
Hi Steve, Take your time with the placement of the shafts/struts/props. Remember our models spend more time on the shelf than in the water. I used 1/8 diameter shafts and I kept the stuffing boxes (tubes) inside the hull and made my own rudders. Best of fun building the MO. Ed
#43 | |
Let er Rip
Regards, Jim G |
#44 |
Jim: Send me a PM with your email address and I'll send them to you. I don't want to snipe someone's build log with my pictures. Thanks, Ed
#45 |
GILL
Ed I don't think that it would be a snipe. Our builder here and I'm sure others would love to see your work. I have in person and it is exceptional. It would give him look and possibly ideas on the detail.
| Thread Tools | |
| Discussion Sterling Missouri Build | Steve Hanson | Scale Boats | 89 | Yesterday 07:22 PM |
| For Sale Will trade: Sterling USS missouri for Sterling | waterbuoy | Boats (FS/W) | 2 | Jun 26, 2006 05:47 AM |
| Discussion Sterling BB Uss Missouri | JP Duda | Scale Boats | 18 | Jan 24, 2006 07:38 AM |
| FS: Sterling USS Missouri Kit | twinster2 | Boats (FS/W) | 1 | Nov 19, 2004 08:29 PM |
| FS: Sterling USS Missouri Kit (B17M) | twinster2 | rec.models.rc.water | 0 | Nov 03, 2004 09:08 PM |
