| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
OK - 2 Rudders it is - Can I just get another one like above? Also I need to know about the "Push-push" system of servo to rudder(s) - Is there a link to such a set-up? Thanks - Steve
#17 |
Let er Rip
Sterling USS Missouri
Here is mine, lots of work to do for sure to get it to here....
Jim G |
#18 |
That Is Nice Jim! Very Fine Finishing. Is that the kit? Wow - man you are a master modeler. How is it powered?
#19 |
Let er Rip
Here is the engine room....
yes, thats the Sterling kit. There is a lot of photo etched fittings on this boat. I forget where I got them. Jim Last edited by Pilot44; Nov 04, 2009 at 04:02 PM. |
#20 |
GILL
I don't have time today, I will draw youthe linkage tomarrow. The is very simple there are a couple of ways to connect the rudders.
#21 |
Retired for now
Push Push steering
Here is the Push-Push steering setup on my pushboat. Pete
http://static.rcgroups.com/forums/at...g?d=1252539152 This is small so go to my Pushboat thread and see page 10 for a better picture. pete |
#22 |
That's Great Jim - Thanks for the pic.
#23 |
Push-Push set-up
I get it now Pete after checking out your great thread - I remember checking it out before - Very Nifty Boats!
#24 |
Hello Steve,
If you are going to make the Mighty Mo into WW2 configuration,have a look for this nice stuff from Poland ![]() http://www.gpm.pl/eng/index.php?akcja=produkt&edycja=48 |
#25 |
That is some nice stuff Ivan - Thanks - I like the price too- Anyone else familiar with this site's quality and fit? - Thanks - Steve
#26 |
Tubes going in
It's going to be tricky getting the planking in around these tubes when they are epoxied in. But it's the only way to go. I will just tack them in good for now (to the new hardwood parts attached to bulk heads) so If I have to reposition I can. Then when I am happy with the fit, planking etc., I will gum them in permanent. How does that sound guys? You gotta remember - I have only built 2 "scale" boats - the Midwest "Trawler" (wood hull) and the Artisiana "Helena" (plastic hull) so this is a great challenge for me. I really appreciate your help Guys. Thanks-A-Million - Steve - What filler should I get (just bought some "Milliput standard yellow") and is that Rudder OK and shall I get another (Rudder) just the same???
#27 |
Proceeding
OK - Tubes in as shown - Not permanent yet but they look good to me. I will screw down and then later epoxy motors directly to the interior deck for best alignment. Any thoughts guys? - Steve
#28 |
More Pics
This may give you a better idea with a piece of planking (not glued) there will be a fat .25 inch between the hull and the prop. Close enough for me and there should be enough room to set up the dual rudder system in front of the pre-shaped block used at the stern as the props and shafts are 2.75" apart all the way down from motors to prop and props do not extend to below flat hull. Does that sound about right guys? -Thanks - Steve
#29 |
Retired for now
You may want to pull those props in some but maybe Pilot44 would post a picture of his props to give an idea of the spacing of them. You do want to leave as much room for the rudders and linkage as you can so you'll have room in the hull to work. If you can wait till you finish the bottom planking before you epoxy the tubes you should be able to get a better idea of where to position the props and rudders. It will look a lot different with the planking on. Pete
#30 | |
Indeed Pete - I have the tubes firmly positioned and there is some play for adjustment. The tubes themselves are not glued in yet but the 2 parts that have the drilled holes and are attached to the bulkheads are glued in giving me all the play I want - Steve |
| Thread Tools | |
| Discussion Sterling Missouri Build | Steve Hanson | Scale Boats | 89 | Today 07:22 PM |
| For Sale Will trade: Sterling USS missouri for Sterling | waterbuoy | Boats (FS/W) | 2 | Jun 26, 2006 05:47 AM |
| Discussion Sterling BB Uss Missouri | JP Duda | Scale Boats | 18 | Jan 24, 2006 07:38 AM |
| FS: Sterling USS Missouri Kit | twinster2 | Boats (FS/W) | 1 | Nov 19, 2004 08:29 PM |
| FS: Sterling USS Missouri Kit (B17M) | twinster2 | rec.models.rc.water | 0 | Nov 03, 2004 09:08 PM |
