Old Jan 11, 2011, 11:54 PM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Originally Posted by b-29er View Post
do they still sell the p51 anywhere?
Hi b-29er
There are loads of suppliers here in the UK, just depends if you want one so bad that you're willing to pay the shipping. Also you could always PM William at Turbofan Electrics, because I recently bought some spares from him for my Mustang and Spitfire, and he had some left. http://www.rcgroups.com/forums/member.php?u=8907
Hope that helps
Andy
http://www.galaxymodels.co.uk/detail...32&rootid=1|22
http://www.brentfordrc.co.uk/scripts...idproduct=2453
http://www.elitemodelsonline.co.uk/P...F-24GHZ-MODE-2
http://www.rcwarbirds.co.uk/prop-dri...2.4ghz-rc.html
Aero Andy is offline Find More Posts by Aero Andy
Old Jan 12, 2011, 08:42 PM
festus105 is offline
Find More Posts by festus105
United States, NC, Sherrills Ford
Joined Dec 2007
Problem with p51
Okay... I was able to locate a NIB erc p51... took it out of the box to test it... found out that the motor is reversed... ailerons and elevator work properly... motor spins backwards... hard to fly a plane in reverse
I'm not electronics wiz... do I simply need to switch the motor leads? How do I access the guts of the plane to get at it?
Ken
festus105 is offline Find More Posts by festus105
Old Jan 13, 2011, 01:13 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi Ken
Yes you're correct, you just need to swap the wires. To get at it without cutting the cowl open, Look at the propeller face on, just under the prop shaft there is a small screw located behind the gear cog. You can see it if you look through the holes in the cog. Undo that screw and pull the whole gearbox and motor assembly out. It's a bit fiddly and you'll need some long nose pliers to plug the motor back in.
Regards
Andy
Old Jan 13, 2011, 03:33 AM
Ultra_Spitfire is offline
Find More Posts by Ultra_Spitfire
Super Man's cousin! No cape!
Ultra_Spitfire's Avatar
Australia, New South Wales, Wangi Wangi
Joined Sep 2010
I have experience with these UM spitfire's. I own 2, most of you would probably see my repaint into Mk XVI FU P which is owned by Temora Aviation Museum. I got a new one, and before flying I gutted my old Vapor, and took the brick out of her. I wired up ailerons over rudder, which is the way the plane came. I got a E-flite brushless ESC and motor out of the Beast for $45 AUD. Then repainted her into the previous paint job on my old one. She is the best flying plane I have, the best battery for mine is the E-flite 500 mah, but I oftenly fly with a 160 hyp. When I get my new camera, I will post a flight video with the new set up.
Ultra_Spitfire is offline Find More Posts by Ultra_Spitfire
Old Jan 13, 2011, 06:59 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hey Michael
Have you got any video of your new set-up flying?
Regards
Andy
Old Jan 13, 2011, 10:06 PM
Joined Dec 2007
Thanks Andy... I found some pics in this thread and from the Hobby-Lobby forum.. pulled the motor and found that it was plugged in wrong... whoever assembled it must have been color blind and couldn't match corresponding colors...
Old Jan 13, 2011, 11:18 PM
ExPat
Aero Andy's Avatar
Joined Apr 2010
That's great Ken, glad you got it sorted.
Andy
Old Feb 15, 2011, 01:34 PM
tgg61 is offline
Find More Posts by tgg61
St.paul, MN
Joined May 2005
About those pins!http://static.rcgroups.net/forums/images/editor/attach.gif
So how would i go about testing the pins for
power
polarity
signal
etc
simply
(like with a LED)
TIA
Tom
tgg61 is offline Find More Posts by tgg61
Old Mar 07, 2011, 04:52 AM
Joined Sep 2010
Andy, I had a video on my old hard drive. It still flies, but as it is a 1s brushless set up, I need alot of room to fly her, and nobody flies with me anymore. I will try when I attend my first indoor flight.
Old Aug 10, 2011, 08:13 AM
tgg61 is offline
St.paul, MN
Joined May 2005
I've been trying to get the 4th channel...
anybody have a spare micro linear servo to send me?
Old Aug 10, 2011, 01:00 PM
tgg61 is offline
St.paul, MN
Joined May 2005
Could I use a cox cs 6 servo from a warbird without damaging the rx board?
Old Aug 15, 2011, 02:27 AM
Joined Sep 2010
I am going to get a new one in september. My spitfire was ritten off by a mischievious husky that was being walked while I was flying it. I am going to do the following;
Add a AR6400T (Out of my mosquito which died )
dual aileron servo's
3 bladed prop
UM P-51 motor
Retracts (I figured them out, so I am going to do them)
They are sweat flyers when they are modded, but are terrible box stock.
Old Aug 17, 2011, 01:34 PM
tgg61 is offline
St.paul, MN
Joined May 2005
Ultra Spitfire,
Do show your retracts!! I am very interested.... Lots a pics too!.
I've had good luck with the stock version and the outdoor props.
Still looking for answers to my earlier questions though....
Tom
Old Sep 07, 2011, 06:32 AM
crtaylor is offline
Find More Posts by crtaylor
AMA 685483
crtaylor's Avatar
Beaver Falls ,Pa
Joined Oct 2006
finally installed the parkzone p-51 motor and this little cheapo plane makes me smile again
crtaylor is offline Find More Posts by crtaylor
Old Sep 07, 2011, 06:41 AM
Joined Sep 2010
Originally Posted by tgg61 View Post
Ultra Spitfire,
Tom
Will very shortly mate, the RCG thread has details about them and I have the thread in my subscription threads.
Alert Parkzone Ultra Micro P-51 LVC pulses the motor before it should modfly Micro Ready-to-Fly 1099 Jun 02, 2011 08:48 PM
Discussion Hobby Lobby Micro P-51 and Spitfire Petefoss Scratchbuilt Indoor and Micro Models 3 Oct 25, 2009 04:38 PM
Sold Parkzone Ultra Micro P-51 RTF PatternFlyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Oct 07, 2009 06:09 PM
New Product Parkzone Ultra-Micro P-51 BNF tallflyer Foamies (Kits) 5 Sep 05, 2009 11:20 PM
New Product Parkzone Ultra Micro P-51! 4ch DSM2 control! BNF and RTF! all4smallrc Scratchbuilt Indoor and Micro Models 2 Aug 29, 2009 02:16 PM
