Go Back   RC Groups > Aircraft - General > Simulators
Old Oct 30, 2009, 12:28 PM   #1
kenduc999's Avatar
DX5e Help!
I have the flight sim cable for my DX5e I got off of Ebay, and it works awesome with a Hitec laser 4 (it came with all the adapters). but when I plug in my DX5e and open the game controllers folder in windows (I have Vista) the controls all work, but the axis are all wrong, like all of the motions of the stick do something, but they all do the wrong things. how can I reconfigure what stick movements control what axis? I dont know if that makes much sense. any help would be appreciated I would love to use my DX5e with Clearview, thanks for your help!
kenduc999 is offline Find More Posts by kenduc999   Reply With Quote
Old Oct 30, 2009, 05:18 PM   #2
AD.
Whatever it takes
Not too sure as I don't have Clearview but in there if you open the settings for controls and there should be settings for mapping in most sims it is like this so hopefully it will work.
AD. is offline Find More Posts by AD.   Reply With Quote
Old Oct 30, 2009, 06:40 PM   #3
If you see movement of more than one channel when you move a stick then chances are the transmitter is in CCPM mode or has some other mixing set. I'm not familiar with your TX so can't advise if this is a feature that can be disabled, or if you can change the programming of the models so that you have a straight 4 / 6 channels without any mixing.
Malc C is offline Find More Posts by Malc C   Reply With Quote
Old Nov 01, 2009, 10:44 AM   #4
Take these broken wings...
I'm having mapping problems with the DX5e in other sims but I have it working well in Clearview. I ignore the vista "game controllers" control panel and go right into the Clearview
Settings>Controller Setup
Throttle = x axis
Rudder = x rotation
Aileron = y axis (reverse)
Rudder = z axis
Calibrate
Done
I haven't figured out how to correct this problem in SSS but then again I haven't taken the time to look around the forums yet
trees is offline Find More Posts by trees   Reply With Quote
Old Nov 04, 2009, 09:45 AM   #5
kenduc999's Avatar
thanks!
Old Nov 04, 2009, 10:05 AM   #6
No problem, have fun.
Discussion DX5e and AR500 help coupe-r Electric Plane Talk 4 Oct 07, 2009 08:59 PM
Discussion Help Binding AR6110e to DX5e transmitter Mario Pinheiro Banana Hobby 2 Oct 01, 2009 08:36 PM
Help! Need Help From Someone With A DX5e Rickochet Radios 11 Dec 28, 2008 09:17 AM
Discussion Need a little help with my DX5e and AR500 leonr Radios 6 Nov 27, 2008 08:15 AM
Discussion Problem with Phoenix and Spektrum DX5e (please help!) alloeric Simulators 5 Nov 04, 2008 05:52 PM
Bored? Want to fight?
Join the RCGroups clan!
