Old Oct 30, 2009, 09:20 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
New micro osd
We are developing a new micro OSD (single PCB) and have utilized much of the old Dragon OSD features, but we run out of ideas since the MCU is not even half full so there is room for more.
We just like to see some input from you guys as to what you would like to see in an OSD. So feel free to throw in some ideas. Thanks in advance
John
__________________________________________________ __________________________________________________ ______________________________ ************************** UPDATE **************************
OSD Chart comparison
http://spreadsheets.google.com/pub?k...jg&output=html
DOSD Firmware update method and firmware page:
http://www.forum.tsebi.com/viewtopic.php?f=7&t=67
You will need a cheap USB to TTL converter to do this and the link for this is here: http://shop.ebay.com/i.html?_kw=usb%...&_stpos=&gbr=1
How to make your own current sensor:
Note: 3 resistors must be removed and a solder line/bridge must be placed across the one side as shown in the video.
Current Sensor Mod for Dragon OSD Plus (3 min 25 sec)
DOSD+ Connection points:
http://www.forum.tsebi.com/viewtopic.php?f=7&t=63
JMSTECH is offline Find More Posts by JMSTECH
Old Oct 30, 2009, 09:44 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Integrate a tracker into the osd interfacing with the camera pan and tilt so that you can have your camera aimed at preset or selected gps ponts. Basically reverse of what current antenna trackers are doing. I figure the gps knows where it is and what direction it's heading so it should be possible.
It could be activated and configured via on screen menu. Picture getting your plane up in the air. Activate position hold so that the plane circles a particular point. Then activate camera autoaim and you could keep a location in view indefenitly while circliing it. All sorts of other ways you could use it as well I imagine.
bracky72 is offline Find More Posts by bracky72
Old Oct 30, 2009, 10:22 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
make the OSD without GPS. Include a pitot airspeed, baro pressure and voltage ... that's it. Or try to create a SMART OSD, one that shows information based on the situation of the plane (heading direction on weak RSSI, large distance, in foggy conditions, etc). Or try something new alltogether, such as an entertainment OSD ... challenge the pilot to do certain tasks.
Just don't go into the same direction as all other OSDs - please. The last thing the FPV market needs is yet another OSD. You guys will end up killing eachother. The newest development by FPV vendors seems to be to just pack all the existing features of the homebrew innovators into a single product. Very despicable and cannibalistic behavior.
trappy is offline Find More Posts by trappy
Old Oct 30, 2009, 10:47 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Well pretty good inputs so far and thanks.. keep em rolling. We are not thinking about some kind of killing field and believe me..... the market has room , besides we are replacing the old Dragon OSD which still has demand for but Mark Harris is not delivering any more. 3 dimensional graphics is something we are toying with and a very slick method to intergrate to all Dragon Link users.
Old Oct 30, 2009, 10:50 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
Ok. I just don't want to see another EagleTree OSD come up. The market may have room, but one more provider doesn't make that room bigger
Old Oct 30, 2009, 10:51 AM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
What is missing is an osd with barometric altitude and aispeed and voltage like Trappy said. Also call sign would be nice
VRflyer is offline Find More Posts by VRflyer
Old Oct 30, 2009, 11:10 AM
Dimitris76 is offline
Find More Posts by Dimitris76
United States, IN, Carmel
DragonOSD's feautures (RTL, Volts, Amps, mAhs, sats, alt, speed, heading, compass,etc..)
Plus:
-RSSI
-Video transmitted telemetry (for antenna tracker, laptop, serial alphanumeric LCD)
- true airspeed via pitot, barometric altitude
- Artificial horizon only if it's IMU based (tell Daniel to take out that old project out of the drawer)
- Having IMU (or even thermopiles) onboard, you can also easily do airframe attitude stabilization and coordinated turns.
- Fly waypoints (maybe after a firmware upgrade - to avoid export restrictions)
- Trigger events (photos, drops) at certain waypoints.
- Build in an interface (PPM?) between this new OSD and your Long range R/C receiver in order to cut down the clutter and spaghetti of cables betwenn Rx and OSD. Only PWM outputs from the OSD to the servos!
Dimitris
Dimitris76 is offline Find More Posts by Dimitris76
Old Oct 30, 2009, 11:28 AM
docphi is offline
Find More Posts by docphi
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Was the DragonLink ever released?
docphi is offline Find More Posts by docphi
Old Oct 30, 2009, 02:00 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Caller ID (cell phone)
scrape is offline Find More Posts by scrape
Old Oct 30, 2009, 02:34 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
What the
G-unit is offline Find More Posts by G-unit
Old Oct 30, 2009, 02:37 PM
andrebandre is offline
Find More Posts by andrebandre
andrebandre's Avatar
United States, NM, Clovis
Joined Jul 2006
I would like it to be able to display 4 voltages and 4 cumulative mA.
I'm probably the only FPV'r out there who uses 4 separste sources to power the onboard electronic but since you asked i spoke my peace.
andrebandre is offline Find More Posts by andrebandre
Old Oct 30, 2009, 02:42 PM
docphi is offline
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Originally Posted by G-unit View Post
What the
Reference from post #4 above.
Old Oct 30, 2009, 03:12 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
Color OSD ?
How micro, will be this OSD ?
wallaguest1 is offline Find More Posts by wallaguest1
Old Oct 30, 2009, 03:58 PM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
make it REALLY EASY TO USE
bignose13 is offline Find More Posts by bignose13
Old Oct 30, 2009, 04:01 PM
JohnyGab is offline
Find More Posts by JohnyGab
Joined May 2008
In the next week, The RushOSD will be released, its a plug and fly OSD, 1.2"x2.5", 10hz system, without any configuration menu ....sensor autodetection, everything :P
If you can wait 15days :P
JohnyGab is offline Find More Posts by JohnyGab
Discussion Remzibi OSD (Poor Man's OSD) integration with ArduPilot HappyKillmore FPV Talk 543 Apr 07, 2015 12:27 PM
New Product Silverlit New Micro Acrobat! Its not ir its a rc micro. Now with videos richos Micro Ready-to-Fly 75 May 18, 2011 01:52 AM
Discussion [new OSD + IMU] techFX Motion OSD light drex UAV - Unmanned Aerial Vehicles 33 Jan 25, 2009 07:30 PM
Discussion [new OSD + IMU] techFX Motion OSD light drex FPV Talk 192 Aug 19, 2008 11:49 AM
Discussion My new FPV ground station and first flight with new OSD jonpet55 FPV Talk 7 Jun 04, 2008 03:04 PM
