Old Oct 30, 2009, 07:45 AM
Truman40 is offline
Find More Posts by Truman40
Melbourne
Joined Jun 2009
6mm depron for 24" Parkflyer Pete??
Ive searched everywhere for the tiled A4 plans for a park flyer Pete but all I could find was tiled plans that were in US legal format. I dont have that paper so when I print it out part of it is cut off so I had to reuce the images by arond 85% to fit on A4.
It's made the wing span around 20" but I added 2 inches to that.
Can I make this plane with 6mm depron both the fuse and wing? I stumbled across another post where a 20" version of this plane was made and the 6mm depron was too thick for a wing. I do have 3mm depron but am worried it would be too flimsy for this.
Would appreciate some suggestions here.
Truman40 is offline Find More Posts by Truman40
Old Oct 30, 2009, 08:43 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Truman , we've even done a Mini Pete @ 17" WS... It flew much faster than the 36" one.. not nearly as Floaty ... 6mm should be just fine !!! Maybe somebody here could make a tiled set of plans for A4... or you could just do as I do and freehand in the missing bits on the larger version ...
gpw is offline Find More Posts by gpw
Old Oct 30, 2009, 10:30 AM
Truman40 is offline
Melbourne
Joined Jun 2009
GPW, Thanks for the reply. Ive spent hours reading through the Parkflyer Pete threads 1 2 and 3, still going though them all but have learnt heaps from you and Gene and other talented people on here.
I didnt mind that I had to reduce it down to fit A4 as I wanted something a bit smaller anyway.
I want my 9 yr old son to be able to just throw it and fly it.
Ive ended up with a 22" fuse and a 28" WS. Do you think this will be okay? I have this motor and was thinking of putting it on this plane.
http://www.hobbycity.com/hobbycity/s...idProduct=5482
Not sure what prop to use though, any suggestions?
Thanks once again.
Old Oct 30, 2009, 12:19 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
IMO This: is a Better Motor http://www.hobbycity.com/hobbycity/s...trunner_2900kv
OR this: http://www.hobbycity.com/hobbycity/s...trunner_1700kv
Bare is offline Find More Posts by Bare
Discussion Help?? Looking for Parkflyer pete PDF Truman40 Foamies (Kits) 3 Oct 31, 2009 08:29 AM
Help! unwarping old 6mm Depron? maukabud Foamies (Kits) 0 Sep 16, 2009 11:37 PM
Discussion Funtana E400 parkflyer (6mm Depron) Appie 3D Flying 2 Dec 20, 2006 06:33 AM
Help! Good Source for Laser Cut Plywood Control Horns for 6mm Depron? Bajora Electric Plane Talk 5 Mar 14, 2006 09:37 AM
Depron 6mm For Sale , HB CA area hotairflyer Aircraft - Electric - Airplanes (FS/W) 0 Dec 30, 2003 02:34 PM
