Old Jan 29, 2013, 06:58 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Nitroplanes has both the RTF and ARF versions of The Diamond 2500 in stock. For some reason the RTF is $5 cheaper at $195.00 than the ARF at $199.00 . any how better grab an extra or two LOL The best damn motor glider i have flown !
fastfwd is offline Find More Posts by fastfwd
Old Feb 05, 2013, 07:59 PM
fastfwd is offline
Joined Mar 2012
WOW ! it has been a couple months since i was able to fly,got out today with the Diamond 2500, first off it was tail heavy (of course didnt check it) was like a porpoise on crack !! wind was blowing around 15mph, i went ahead and flew it for about 9 minutes like this, about 4 minutes in i was up quite high (luckily) stalled her out good and right ! it fell, then tipped then started spinning woohooo hit the throttle ! I was gliding at the time. bringing it in to land was a real treat being tail heavy,wind swirling,hit flaps up down up down up down !!! got her calmed down and on the ground,set the CG correctly (had to add 4- 7G leads in nose) second 10 minute flight was sweet !! But the over turning and jumpy up and down stuff was just as much from not flying ... ohh this is a used diamond 2500 i bought,the guy had it setup for fpv,so the weights were taken out of the nose from what i can tell. anyhow anyone else notice how fast you get rusty when you dont fly ?
Old Feb 11, 2013, 08:51 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Will this pack fit? or too Long?
Dimensions: 162x46x34mm
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Feb 11, 2013, 09:34 PM
fastfwd is offline
Joined Mar 2012
mine is 5 inches long and it is a tight fit
Old Feb 11, 2013, 09:58 PM
rclab1 is offline
USA
Joined May 2010
This Lipo is 6.4 inches long.....
I guess its best to get 2x 4s-4000mah and stack them together?
Old Feb 12, 2013, 12:21 AM
fastfwd is offline
Joined Mar 2012
http://www.hobbyking.com/hobbyking/s...4S1P_20C_.html
or this they will both work
http://www.hobbyking.com/hobbyking/s..._4S1P_30C.html
This is the one i bought,had it delivered in four days
http://www.headsuprc.com/servlet/the...-50C-EZ/Detail
Old Feb 15, 2013, 08:43 AM
fastfwd is offline
Joined Mar 2012
looks like weather may be good enough to fly today ! if so ill get some video .. Having some trouble with COG on this used Diamond, running 4s 2650 lipo 60amp esc and have CG set at 83mm or 3 1/4 inches. You guys running this setup where is your CG set ?
windy day diamond 2500 (11 min 49 sec)
Old Feb 23, 2013, 03:00 PM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
Thanks for you recent PM's Fastfwd.
I collected my Diamond 2500 on Thursday.
A thorough check over of the model, which is brand new and still boxed, revealed broken gears on the servo on the left flap..
All the others seem ok but I'll replace them all with metal gear ones.
Also the hinges are really stiff so I'll need to work those while the servos are out.
The rudder horn is loose and not gripping on to much of the foam so I'm gonna replace all the horns and clevices too.
It was a bargain price from Ebay and a private sale. He is an RC Heli pilot and thought he'd like a go with gliders and got a big one. However poor chap was a bit daunted at the size of the thing
The model also comes with the 4s lipo and 60 amp ESC so I'm very pleased.
I will also upgrade the stock prop to the aeronaut 14x8.
Stunning model.. Will be flying in a couple of weeks after the upgrades, a change in weather and the time to fly due to my shift patterns..
soundcheque is offline Find More Posts by soundcheque
Old Feb 23, 2013, 04:50 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
If you want to upgrade to MG servos, I recommend the T-Pro MG90s's. It's what I've been using, and they've been working great for me.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Feb 23, 2013, 05:29 PM
Bring It On !!!!!
Newmarket, England.
Joined Aug 2006
Thanks Bugman,
These are the one's I've used before.
http://www.ebay.co.uk/itm/1409056431...84.m1436.l2649
I reckon they're the same as you recommend, different label !!
Old Feb 23, 2013, 07:53 PM
Evansville, WI
Joined Dec 2006
Yup, only difference is the sticker
Old Feb 23, 2013, 08:34 PM
fastfwd is offline
Joined Mar 2012
sweet !! I also replaced the clevis,s and control rods. your going to love this plane !
Old Feb 24, 2013, 06:42 PM
jakeg1999 is offline
Find More Posts by jakeg1999
United States, CA, San Diego
Joined Nov 2004
Anybody have an extra NIB they want to part with?
jakeg1999 is offline Find More Posts by jakeg1999
Old Feb 24, 2013, 07:39 PM
fastfwd is offline
Joined Mar 2012
http://www.nitroplanes.com/at-2209e-...0-4ch-arf.html
$199.00 Just need a 60amp esc so you can use a 4s 2500 lipo and two servos so you can cut the flaps in
Old Feb 25, 2013, 09:15 AM
Joined Nov 2004
What esc and servos are most folks using?
Discussion Art-Tech EF2000 any one have it j3tman Foamy EDFs 2 Oct 24, 2009 09:42 AM
Discussion art tech spitfire bomb! (: kieran3008 Electric Warbirds 2 Oct 15, 2009 05:57 PM
Help! Art-tech Yak 54 Center of Gravity Midknight69 Electric Plane Talk 3 Oct 14, 2009 09:21 PM
Discussion art tech spitfire ***** kieran3008 Electric Warbirds 0 Oct 12, 2009 02:21 PM
