Old Jun 09, 2012, 08:36 PM
ERIC123 is offline
Find More Posts by ERIC123
France, PACA, Gassin
Joined Jun 2012
The very first new Diamond 3500 maiden flight in St Tropez ......
http://www.youtube.com/watch?feature...&v=WUalmI-GfYY
http://modelisme-xtreme.forums-actif...0-glider#12068
ERIC123 is offline Find More Posts by ERIC123
Old Jun 09, 2012, 09:22 PM
dev367 is offline
Find More Posts by dev367
dev367's Avatar
United States, PA, Gettysburg
Joined Apr 2008
+1 meter mod?
We'll be requiring detailed construction photos now, thanks.
dev367 is offline Find More Posts by dev367
Old Jun 10, 2012, 12:16 PM
ERIC123 is offline
Joined Jun 2012
Old Jun 14, 2012, 05:01 PM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
Can this plane handle a gopro mounted on the wing if some ballast were applied to the opposite wing? If anyone has done this I would be interested in seeing photos.
LTChip is offline Find More Posts by LTChip
Old Jun 14, 2012, 10:11 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
I did a few flights with a JAZZhd. I usually just put some velcro on a piece of athletic tape (this goes on the wing and is removable) then do final securing with a rubber band or 2 around the entire wing chord
IMHO i would use another plane for FPV and/or video
coolboarder is offline Find More Posts by coolboarder
Old Jun 15, 2012, 10:09 AM
TooSLow2Care is online now
Find More Posts by TooSLow2Care
insert witty phrase here
Joined Aug 2006
I put my GoPro in a custom coro housing I made about 300mm out the right wing. I put my FPV cam & vid tx on the left wing.
The GoPro is great, but I plan on getting the Replay due to it's more aerodynamic form factor.
I,ll take some pictures shortly.
Cheers,
Brian
TooSLow2Care is online now Find More Posts by TooSLow2Care
Old Jun 30, 2012, 05:11 AM
crabtrap is offline
Find More Posts by crabtrap
Joined Jun 2012
Painting diamond 2500
i have read many threads about painting EPO foam....you guys are over thinking this. i painted my DA2500 with rustoleum primer and rustuleum professional spray paint. there was no foam"eating" or damage of any kind and it adheres very good. the problem is must people don't know how to spray paint!! the PROPELLENTS CAN DAMAGE YOUR FOAM!!! BUT, if you hold the can 12-18 inches away and do dusting coats...you will have ZERO problems. the propellent disperses at that distance and does not concentrate on the foam. just remember that paint add weight. i did the scale "air cadet" red stripes so wt was no a concern.
REMOVING THE DECALS: use a good quality masking tape. rub it on top of the decals....let it sit for a minute to adhere......rip it off like a bikini waxing.....repeat as necc. takes about 10mins to clear those chucky cheese decals off.
crabtrap is offline Find More Posts by crabtrap
Old Jun 30, 2012, 05:19 AM
BG Bengtsson is offline
Find More Posts by BG Bengtsson
BG Bengtsson's Avatar
Sweden
Joined Jul 2010
crabtrap Welcome! Any Photo?
/BG
BG Bengtsson is offline Find More Posts by BG Bengtsson
Old Jun 30, 2012, 05:33 AM
crabtrap is offline
Joined Jun 2012
Easy upgrade!!
this is a must to save your servos from over work and to keep your flaps/ailerons intact.
buy a package of "great planes CA hinge fabric" (little squares of tuff and CA glue wicking material). gentle cut out all your foam hinges with a NEW exacto knife blade. ALL EXCEPT RUDDER HINGES( the rudder has a nice silicone hinge set-up). the fabric hinges are applied by slicing into the flap edge and wing edge just big enough to slide in the fabric hinge=(about the size of a postage stamp).
space out the hinges so you have 4 hinges per flap/ail. once you have your 4 hinges in place and the flap mated to the wing....apply a small amount of CA glue to the hinge material....it will "wick into the wing/flap providing a secure mount. MAKE SURE TO LEAVE A 1MM or 2 gap between wing and flap....this give the hinge a good flex point. after about 1 min of CA dry time,flex your flap back and forth 80 degrees for approx 5 mins PER flap to "break it in". READ THE HINGE PACKAGE DIRECTIONS on hinge alignment and cutting flap.
THIS MOD WILL TRIPLE YOUR SERVO LIFE SPAN AT THE VERY LEAST, compared to the pressed foam weak hinge. i had a nonflapped 2500 loose a flap on a fairly smooth landing! it just "popped" off. so looseing a aileron is not to far fetched in flight. PLUS that buzzing sound you hear when you hold full aileron or elevator,is your servo fighting with the foam hinge"spring back"...this drains battery power as well as taxing the servo. the hinges are about $3 for 24.
Old Jun 30, 2012, 05:46 AM
crabtrap is offline
Joined Jun 2012
thx BG. im fighting with my tachyon cam right now to edit down AF (films in .mov files which sux!) but i'll take a few pics this weekend and post'em. i should probably write up a article on easy no BS mods. man i searched for 2 weeks on painting EPO until finally i gave up on all the witchcraft special latex this and airbrush acrylic that... finally i decided the internet is about 80% full of numbskulls, so i guinea pigged my rig. the 2500 is a great aircraft IMO. geez just read up a few comments,there is a guy claiming the "2500 is not a good FPV glider" HUH???!! this bird has some serious lift capability and wing area and it glides like a dream! so i figured i'd better sign up here and drop what ever tested tips i have.
Old Jun 30, 2012, 06:24 AM
crabtrap is offline
Joined Jun 2012
here is some pics. the color is "safety red" and is an exact match to the 2500's nose cone
Old Jul 05, 2012, 08:08 AM
X3n0 is offline
Find More Posts by X3n0
United States, MI, Pontiac
Joined Jul 2006
I dont know if i missed this but where is the cg with the nose and wing weights taken out. Does this change for the one with flap servos and without.
X3n0 is offline Find More Posts by X3n0
Old Jul 05, 2012, 11:15 PM
crabtrap is offline
Joined Jun 2012
i'll chime in; i plucked my wts out and just readjusted the battery(2200mamp in my case) forward to balance out to the factory suggested CG, it should'nt matter about the flap servos...80mmCG is 80mmCG (its 80mm right? : )
Old Jul 05, 2012, 11:32 PM
X3n0 is offline
Joined Jul 2006
ty...yes mm ...cm would be wayyyyyy off
Old Jul 06, 2012, 04:37 AM
crabtrap is offline
Joined Jun 2012
oopsy! thats the great thing about the diamond,it doesn't care!
Discussion Art-Tech EF2000 any one have it j3tman Foamy EDFs 2 Oct 24, 2009 10:42 AM
Discussion art tech spitfire bomb! (: kieran3008 Electric Warbirds 2 Oct 15, 2009 06:57 PM
Help! Art-tech Yak 54 Center of Gravity Midknight69 Electric Plane Talk 3 Oct 14, 2009 10:21 PM
Discussion art tech spitfire ***** kieran3008 Electric Warbirds 0 Oct 12, 2009 03:21 PM
