Has anyone ever seen this model? I have been looking everywhere for a glider with the same type specs as the 2500 only not in foam and I found this one. It doesn't have the same tail so it wouldn't be quite as stable, but I like the wing loading and materials. Thoughts anyone?
http://www.hobby-paradise.com/en/pro...ct_detail.html |
OK models Mace video
Here is a video of the plane I was talking about. I wonder if I could put a V-tail on it???
Joined Aug 2006
So after some searching about my 3720-1 ArtTech motor i've seen that there is some speculation regarding it's Kv (RPM/volt) Rating. this post states a speculative 700kv.
does anyone have a true number for this motor? or am i going to have to get in there and measure it myself? thank you for your help, Brian |
The Villages. Florida
Joined Jan 2005
Doesn't look all that bad in the video and at least it has a sharp t.e on the wings. Is it still availble in the US? Will your friend let you have a turn on the sticks?? Can't agree re cruciform tails. Looks like the Mace has an all moving tailplane which is nice --- low drag. I flew many a competition with both cruciform and vee way back when the world was simpler!! Grand Esprit, Challenger, Bird of Time, Cumulus etc and any of them could win if things went right. One good reason for vee tail was that it didn't catch in the grass on landing. There is supposedly less drag (parasitic mainly) I suppose as there is less tail assembly surface area. Flew in scale with a Slingsby T-53 which had a swept forward wing and tee tail but it was, like the 2500, a lead sled.
Joined Aug 2006
That means that we're probably looking at a 37-20 600kv (Chinese claim) motor. Cheers, Brian |
I tink you shall not go for a too low Kv. The ESC transforms the power from the battery to the motor. The original motor is working but weak at 3S. I have no experience in choosing Kv but if I would buy and try I would go for a little higher. Maybe 800rpm/V...?
37-20? Does that mean 37mm in diamerer and 20 turns of cupper wire in the motor? That is an important factor coil turns, or what it is called in English. If we increas Kv to 800 That means 800/600*20=27 turns. That means much thinner Cu diameter and higher resistance... Maybe the 600kv is best anyway!... Opsh I think I was to fast here! It is the opposite. Kv is rpm/V not V/rpm. That means that the turns goes down with higher Kv. If 20turns gives 600Kv then 800Kv is 600/800*20=15 turns. And that is a lower resistance. Maybe I would try 800 anyway!... Anyone else with experience? No one here have turned the original motor down. We all fell happy with it. /BG |
Hi BG, well spoken....i have found the stock motor puts out plenty of power for near vertical climbs, outside loops, and positive rolls. a couple factors that could increase a little performance is higher C lipos, larger stiffer props....something to consider, when increasing the speed of this aircraft, higher loads are imposed on the servos, on the flaps, elevator, ailerons= servo failure....after i inserted a carbon fiber rod into the stock aluminum spar, i put my Diamond into a couple speed dives to check for wing flex....the Diamond is limited in it's ability to achieve a high speed because of it's inherent design and limitations....i enjoy it for what it is, a fun, slightly aerobatic, stand-off scale looking electric sailplane that cost very little and is made of foam. Hey BG, we're heading to the lake for about a week!
Hi Phil! Nice to here from you. I have had a very long vacation now! 7 weeks. But back to work on monday... My Diamond is still flying but need some hours to refresh. The wing is not tight anymore to the fuse. I am thinking of implanting plywood in fuse fore the two pins, to stiffen up...
But hey! It must be midnight in Oregon?!?? |
Yes, it is after midnight, linda and i have been busy packing up our RV. i'm sure you enjoyed your vacation, because i am aware of how hard you work. i'm glad your Diamond is "loosening-up", as that means you're flying it!...let us know what you do for your wings...i have been enjoying my helicopter, and linda and i have a couple RC sailboats....and last weekend i won a 4WD modified race
| Thread Tools | |
| Discussion Art-Tech EF2000 any one have it | j3tman | Foamy EDFs | 2 | Oct 24, 2009 09:42 AM |
| Discussion art tech spitfire bomb! (: | kieran3008 | Electric Warbirds | 2 | Oct 15, 2009 05:57 PM |
| Help! Art-tech Yak 54 Center of Gravity | Midknight69 | Electric Plane Talk | 3 | Oct 14, 2009 09:21 PM |
| Discussion art tech spitfire ***** | kieran3008 | Electric Warbirds | 0 | Oct 12, 2009 02:21 PM |
