Hi Guys!, it's good to hear from everybody, and see some action on our thread again. i will be contributing a little more in the upcoming weeks....in my personal preference for RC thermaling , i like the flaps up. the sailship has a better feel and reaction to wiffs of lift, and is not as slow moving or reacting...of course this is my own flying technique, and you may find that just the opposite works for you. here's a foto with linda and my everyday flyer
Portugal
Joined Dec 2007
so, people, you guys think it is possible to move from one easystar, to a small cessna with 4ch and then to this big glider?
I read it somewhere: "Bigger they are, better they fly" can i buy one diamond without fear? only need a big area to practice? And B.G. I have one volvo too, the S70 (not v70, but big enough) so i can go to the field with this monster
Well, regarding the car: I picked up the box in a Volvo S80 and had big problems to load!
The box is 17x43x157 cm so you can measure... Without fear?! First time you need some fear. But I do not think you need the Cessna in between... But if you have a simulator, flying practice is always valuable... /BG (I did add some tips to my previous post) And Phil: More details on the light. And report from fly-in... |
Flying in thermal winds - my winter training with simulator
Hi, I just uploaded some video showing me how do I train flying in thermal wind with Diamond in simulator. Originally I was not able to fly/to stay there in thermal wind without regular use of engine help. But my skills improved a lot. First, without help of engine at all (only on start to get height), I was able to fly and to stay there in the thermal wind nearly unlimited time, if I used flaps. Flaps helped me a lot to lower the Diamond glider speed, so I had more time to control the Diamond the way that I was able to control/to turn fast enough to be able to stay in the small thermal wind area. I had to also control the glider the way to not loose height much during flight and in fast turns which are needed to stay in the small thermal wind area. I tried to prepare video to show how I fly in the thermal wind and at the same time I trained a lot. Finally my skills improved a lot the way, that I can fly and stay in thermal wind even without use of flaps and I can fly also in the thermal wind unlimited time without single use of engine at all. I am able to make fast turns without loosing much height even without flaps. I would like to share my experiences I observed and learned using youtube video. Hope that it will help.
The video is little long. Maybe it could be little boring after some time. In the first part I fly with flaps on. In the middle part (1 minute) I just show how diamond fly with use of engine and propeller in the simulator. In the last part I demonstrate how I fly in thermal wind even without use of flaps. |
Hi Pavel
I think that seems to be a good program for training. I say the following knowing I am talking with litteraly hundreds of guys around, much more skilled then I am... Looking to your video I got some thoughts: 1. You should train in circling, with and without thermalling. You are flying to much back and forth. Nice constant circles round round round... Start with no thermal activity. Fly up on motor and circle with constant speed and radius. Learn to keep the circle constant with as little stick movement as possible. 2. You do too big stick movement. 3. In the beginning: use only aileron and elevator. 4. Much more banking. Circle with 30-45 degrees angle to learn keeping the constant circle. Small circle, more banking/ angle big circle less angle. 5. Do not loose speed. You are down to 30km/h. That is 8.3m/s stall speed at straight flight. And turning is impossible at that low speed. 6. To see what the thermal wind does to the plane just fly straight through the soaring air, with around 40km/h speed. Then you learn how it looks like when the air is lifting the plane. You can see it in the video several times very clearly. Look on your plane not the arrows in the air! Good luck! your friend BG |
United States, WI, Menomonee Falls
Joined Dec 2009
Keep in mind the Banana Hobby kit that sells for $275-$295 is way better because... Banana hobby includes a 60 Amp speed controller, Nitroplanes is a 40 Amp speed controller. Banana hobby has the 4 cell 2500 mah battery, Nitro planes lists the battery as a 3 cell 11.1 Volt 2200 mah Banana hobby includes the servos for the flaps, Nitroplanes does not. Both of these planes are good value but I've been flying the banana hobby version and love the 4 cell power. I've flown it on a 3 cell and it's not in the same leauge. |
Flying in thermal wind field
Hi BG
Thanks for your advices. But let me try to explain the intend of the video demonstration I did and explain that strange observed style of flaying there. Quote:
As I said. Constant slow circle does not work in this case in this small thermal field which is in the simulator. You need to make fast turns. Even they do not look so majestic. Quote:
It is hard to explain without you try that. I would expect that you on the first try there that you would end with start to help to stay in that thermal field with help of propeller if you would try to fly in this simulator thermal field there. You would need to change tactic to go fast glider turns tactic way to be able to stay in the strongest part of the thermal field as long as possible which helps you get heigher and higher. Hope you understand my clarification. It is really difficult to explain without you try. Guys, anybody has real experience how thermal fields behave how big thermal fields are, how strong are, and how to fly there without help of propeller to stay there for free without help or use of engine at all to get heigher and heigher similarly like I tried in this demonstration video? Are thermal fields large or small area? Strong or weak? Regards, Pavel |
Hi Guys!...we had a club fun fly yesterday and a good time was had by all, warm 78 degrees with only a hint of wind....today i had my Diamond out and got in two battery packs for easily two hours flying time. i do beleive the Diamond thermals better with flaps up, and one of it's best features is the ability to move across the sky searching for lift, without losing any altitude. i had the Diamond inverted for several passes and when entering an outside loop, it tracks straight and comes out right where it started...it's hard to get any plane to do it that pretty and easily. when pointed up towards the white clouds indicting lift, it will reach altitude in moments, and stay up there for an hour. i fly my Diamond from a chair , with a cup of coffee, because i know i'll be up for a while. i am using the flaps for landings, and put her right in front, in the center of the runway...i really like this plane!....PAV, i think some pretty good advice is to trim your Diamond for straight and level flight, keep her moving, and watch for any wings lifting or the glider wandering off course, there is probably thermal air rising. i circle back and feel the diameter of the thermal, holding the wings as flat as i can. hold your elevator stick back as much as you can without stalling her...keep her moving...our Diamond's wing really works with a little forward speed.
Hi All!
Pavel, I only expressed some thoughts I got when looking to the video. Everybody has to learn them self by doing, and I think you do a good job there learning by practising with the simulator. Interesting that they do not have a build in recorder...? I did fly a lot on a good simulator a couple of years ago. Good luck with your training. Maybe the thermals in the simulator is too small. In reality you can not catch too narrow ones. I still think learning to fly in circles is a good training... I practise a lot with motor on on a very low power, just to keep her on same level at a speed just abouve stall. Then it is easier to see small thermals and to stay... Phil, nice to see your fly in. You have perfect wether now. Here we have had som degees abouve freesing some days, but now we got new snowing early morning. I will have breakfast now... take care... BG |
They do not have built in video recorder to the video format to be able to play it with standard video player or to be able to upload it to youtube. There is only recorder which result file is possible to play only with the same simulator.
Otherwise the simulator is pretty good for everything! Gliders, Helis, acrobats, jets, .... I just want to tell that everybody always fly differently if you fly for real and if you fly just in the simulator. If you fly for real, everybody fly for safe, to not to get to dangerous situations by mistake or by intend. You know what is the price of the airplane and what it would take to repair it or to build on buy new. In opposite in simulator situation is different. Flying just circles would be pretty boring soon. Everybody wish to try what you can not simply try with real airplane. You know that crash in simulator means jut to hit some button again and you can start with new airplane always. You know it cost just one hit of the key. So in simulator you fly for extreme which you normally can not afford for real. You do fast movements, extreme situations, fast turns. Also you try slow circles first of course. You just wish to be ready for real best possible way. So you can handle every possible situation best possible and also fast way. The intend of the video was not to show nice circles. But to show that Diamond is able to fly without motor for hours. And to discuss this. I appreciate Phil real testing in this. That he confirmed that with flaps it is good to fly in thermal wind, to get better sensitivity. This is important result from this research, training and testing and video demonstration. I appreciate very all BG and Phil advices, but I have some testing results also to show and to discuss. When I discussed with guys here about thermal flying. They told me that thermal behavior is usually above roads and maybe forest usually in my area where I live. That is why I train in simulator to be able to use this opportunity. In my short rc flying carrier I did not have many opportunities to observe thermal behavior and to fly in there. I started to fly at the end of summer last year. But really I flew mostly on autumn and start of winter. Where thermal wind is not that much observed. Still anyway I concentrated on different things at that moment. So I look forward on summer to try to fly in hot whether, so hopefully my time in simulator will be used maximally. Anyway it is good to train mind and hands in extremes in simulator you can prepare there instead of to try extremes for real. Anyway thanks for advices. Important result is that Diamond is more sensitive with flaps. And that also without use of flaps you can still fly for hours if you are in thermal wind area with Diamond. Quote:
Reunion
Joined Nov 2010
Hi fellows Diamond pilots! Nothing interesting for people like you, just to give news to these who welcomed me in the Diamond world : mine has finally flown (and crashed - depth inverted, you had told me to watch, BG B, but too excited). Repaired, and now no problem, except that today I landed in a sand square (not seen from distance) and the motor "swallowed" some sand... Cleaned and rotating, but I wait for next flight to claim victory.
I glued a block of "ice-cream box" plastic, as support for a GoPro camera, and it works. Thank you for all the interesting things I read from you all, hope to give my tribute, from now... Good flight everyone |
Papangue I know the fealing to be airborne first time!!! It is like hunting first time... The first shoot. Heart beat 200+...
Just a recomendation to your interesting mount: Put a wire in the cam-mount and down secure around the wing hole. If the camera breaks off... I hope you have cleaned the inner of the motor carefully! Good luck. Waiting for pictures... Pavel. Regarding simulator. I did fly simulator very intensively five-six years ago. After several hours with the simulator I realised that I did an error during flying. When I was bypassing myself, from right to left, and then should do a right turn just in front of me I did a dive instead! I pushed the stick forward, in the direction from my point of view that I whanted the plane to go!! It is mixing of different coordinate systems that is the biggest problems with flying, I think! And for that training the simulator is a very good tool. For me, hours of "boring" circling has been a good training. But I think that what ever you do in the simulator is good, especially for this cordinate transformation, to learn to act as sitting in the plane. /BG |
| Thread Tools | |
| Discussion Art-Tech EF2000 any one have it | j3tman | Foamy EDFs | 2 | Oct 24, 2009 09:42 AM |
| Discussion art tech spitfire bomb! (: | kieran3008 | Electric Warbirds | 2 | Oct 15, 2009 05:57 PM |
| Help! Art-tech Yak 54 Center of Gravity | Midknight69 | Electric Plane Talk | 3 | Oct 14, 2009 09:21 PM |
| Discussion art tech spitfire ***** | kieran3008 | Electric Warbirds | 0 | Oct 12, 2009 02:21 PM |
