Old Sep 17, 2001, 09:50 PM
GMILL47 is offline
Find More Posts by GMILL47
GMILL47
Lakewood, CO, USA
Joined Jan 2001
Robbe Pitts Special
Has anyone out there finished a Robbe Pitts? After ten years, I have finished the kit. I have a Simprop electric motor with belt drive (Model Airtech or something similar) using an APC 12x6 prop. Battery is a 7 cell 1200.
I hooked up a Watt Meter between ESC (JETI) and the battery and only got 90 watts starting out - dropping quickly to 75. I don't have a scale but the instructions predict 1450 grams which I take as 3.2 lbs. Rough ratios of 60 watts per pound would indicate I'm low on power. Or, is ther some false reading in the watt meter?
Will this fly?
GMILL47 is offline Find More Posts by GMILL47
Old Sep 17, 2001, 10:22 PM
JeffD is offline
Find More Posts by JeffD
Joined Mar 2000
I'm flying mine on an Aveox 1406/2y and 10x2000 SCRs. I wouldn't want any less power that I get (about 400 watts) for this type of airplane.
JeffD is offline Find More Posts by JeffD
Old Sep 18, 2001, 12:18 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Greg, if that battery is 10 years old as you've mentioned the kit is, I'd suspect it wasn't quite up to the job. The older 1200's I've seen are the ~same size and weight as the 2400 NICD's available now. It may still work with a few charge/discharge cycles, but I'd replace it with newer stock if it were mine. You could get a ten cell pack of the new CP1700's that would be ~ the same weight as your 1200 pack. Cycle your pack a few times and see what it does.
GregG is offline Find More Posts by GregG
Old Oct 03, 2001, 09:15 PM
GMILL47 is offline
GMILL47
Lakewood, CO, USA
Joined Jan 2001
Robbe Pitts Special
Thanks for the replies. This leads me to more questions.
1. Is it acceptable to hook the watt meter between the battery and ESC?
2. What are the AUW for your planes?
3. Do you leave the wheel fairings off?
4. Where do you get your CP1700's and who makes them?
Thanks in advance for any information.
Herr Engineering Pitts Special crashnburn Sport Planes 9 Aug 16, 2003 12:41 PM
herr pitts special, power system crocket Sport Planes 12 Nov 26, 2001 10:08 AM
Robbe Pitts Special JeffD Aircraft - Electric - Airplanes (FS/W) 3 Nov 13, 2001 06:29 PM
Herr Pitts Special rubber-to-electric conversion mkirsch1 Sport Planes 11 Oct 25, 2001 10:59 PM
Herr Engineering Pitts Special crashnburn Sport Planes 7 Jul 05, 2001 10:06 AM
