Old Mar 27, 2011, 02:50 PM
Tail Spin1 is offline
Find More Posts by Tail Spin1
Zach
Illinois
Joined Feb 2004
Wow Joe, you're a little more high tech that the rest of us. Sounds nice though.
Josh, I use a mix of Sculpey Firm and Super Sculpey for most of my pilots. All types of Sculpey are compatible so you can mix and match to find the mix that's just right for you.
You are right about Super Sculpey being to soft for small scale work though. At small scale it's like sculpting with chewing gum, except it doesn't taste as good.
Zach
Tail Spin1 is offline Find More Posts by Tail Spin1
Old Mar 27, 2011, 03:02 PM
Zach
Illinois
Joined Feb 2004
I want to warn anyone working with Sculpey not to leave it set on furniture or anything plastic for a long period of time. There is a solvent in the clay that will dissolve varnish and some types of plastic.
I found a piece of Sculpt stuck to the bottom of my keyboard a few days ago and it had been there for well over a week and had started to dissolve the plastic under and around it.
A few weeks back I dropped a small piece of Sculpey on the floor and stuck it to the side of my computer desk without thinking. I didn't notice it for about another week and it had dissolved the varnish under it.
I know most people probably aren't as forgetfully or absent minded as me but it is something to be careful of. It does seem to take a long time to do any damage.
Zach
Old Mar 27, 2011, 05:28 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
My latest. For Hammerd's 1/6 scale DVa Albatros:
warhead_71 is offline Find More Posts by warhead_71
Old Mar 27, 2011, 05:36 PM
joshlindsay is offline
Find More Posts by joshlindsay
USA, TX, Fort Worth
Joined Sep 2004
Joe, since I mostly work with clay and a toothpick, that all sounds pretty cool.
Beautiful work Warhead.
Josh
joshlindsay is offline Find More Posts by joshlindsay
Old Mar 27, 2011, 06:06 PM
hammerd is offline
Find More Posts by hammerd
Las Vegas, NV
Joined Mar 2008
Very nice, warhead_71.
You are an artist.
hammerd is offline Find More Posts by hammerd
Old Mar 27, 2011, 06:50 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
beautiful job. he will look right at home in the Albi.
trumps is offline Find More Posts by trumps
Old Mar 27, 2011, 07:53 PM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
Nice! Will the lower legs even be seen? Or is the extra weight negligible? Looking forward to seeing it painted up and in the plane.
bdshort is offline Find More Posts by bdshort
Old Mar 27, 2011, 09:59 PM
mistairjoe is online now
Find More Posts by mistairjoe
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
Very nice.I like the contrast between the different colors.The figure has a nice Snidely Whiplash look about him.I am reading a very good book called Chasing Icarus, The seventeen days in 1910 that changed american aviation. The first Balloon and Airplane races in America.Your pilot looks like he stepped off the pages of the book.Joe
mistairjoe is online now Find More Posts by mistairjoe
Old Mar 27, 2011, 11:25 PM
Zach
Illinois
Joined Feb 2004
That is insane!
There are even treads on the bottom of his shoes.
I know how hard it is to sculpt a bust. It makes my head spin to think how hard it is to sculpt a full body and get the proportions just right.
How many parts will you cast him in?
Zach
Old Mar 28, 2011, 05:42 AM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
It never ceases to amaze me the amount of talented people this hobby has.
Great work!
Buzzkill2 is offline Find More Posts by Buzzkill2
Old Mar 29, 2011, 10:50 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Originally Posted by Tail Spin1 View Post
That is insane!
Zach
He is built in 7 pieces: 2 arms, 2 legs from the knee down, torso with lap, head, goggles. The most difficult part to cast will probably be around the coat collar... there is a lot of recessed area behind the lapels and collar that might need to be filled a little to prevent voids in the silicone mold.
Old Mar 29, 2011, 12:36 PM
Zach
Illinois
Joined Feb 2004
You may be OK for the most part. It's a little hard to tell from the pictures though.
I'm always surprised at the undercuts I'm able to get away with when using silicone. The only thing I worry about is silicone getting trapped under something deep It won't pull out from or if it will pull out but is going to produce a section of the mold that is so thin it won't last but a few castings before it tears off.
Zach
Old Mar 29, 2011, 12:49 PM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
Do you guys cut your molds or make them in two parts?If you cut them vacuming the silicone helps eliminating air bubbles. Joe
Old Mar 29, 2011, 02:00 PM
Zach
Illinois
Joined Feb 2004
Originally Posted by mistairjoe View Post
Do you guys cut your molds or make them in two parts?If you cut them vacuuming the silicone helps eliminating air bubbles. Joe
I use all two part molds. The only cut mold I made was when I forgot to spray my mold with a release agent before pouring the second part. That was quite a surprise when I tried to separate the two halves.
I use Oomoo 30 from Smooth On which is a thinner silicone that doesn't require vacuum degassing.
I'm sure degassing would still help and I have looked into it but the vacuum chambers and pumps are expensive even on eBay.
If you have a large air compressor you can buy a relatively inexpensive vacuum pump that is driven from compressed air but it takes a large compressor to drive it.
I have herd of people making their own vacuum chambers from old pressure cookers and fitting them with 1/2" thick lexan lids but I have also herd of some of those chambers failing when the lexan gives way because of stress fractures from repeated use.
I really wouldn't want to be around something like that when it failed because an implosion can be as bad as an explosion.
Good advice though for people who want to get into this a little deeper.
Zach
Old Mar 29, 2011, 02:04 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Alumilite brand doesn't require de-gassing or release agent. I got the large starter kit... it works as advertised. I rotation-cast my pilots so they are hollow like Williams Brothers pilots.
Making scale pilots from action figures Bomberguy Scale Kit/Scratch Built 31 Feb 01, 2012 04:57 AM
For Sale 1/8 scale koran war pilot(BOOMERs pilots) corsair nut Aircraft - Electric - Jets (FS/W) 2 Oct 16, 2009 01:20 AM
Mini-Review 1/4 scale pilots from Premier Pilots. suirendoujin Scale Sailplanes 6 Oct 03, 2009 11:11 AM
Cool New Stuff ,lights and making them look pretty garyg4rc Slope 13 Sep 26, 2009 05:54 PM
Help! Scale/Life-Like Pilots 4 1/5-1/8 Scale Electrics...WHERE 2 GET THEM?? bighank13 Trader Talk 3 Nov 23, 2008 09:00 AM
