Old Oct 28, 2009, 07:36 PM
fuelsguy's Avatar
Seattle
Joined Dec 2001
Making scale pilots and replicating them.
Glenn Moore an I have been going down a very similar path on how to make pilots from light weight material and to be able to make multiple copies of the same pilot.
Since we have independently reached the same skill level it seemed worth while sharing this with the Forum.
As a sample here is my 1/9th scale pilot for a Hellcat I'm building
(http://www.rcgroups.com/forums/showt...6#post13417086)
The hope here is to describe a build of another master pilot, probably an RAF pilot and encourage other people to join in and share their ideas.
The foam pilot shown in the photos is 3" high and 2.5 inches wide across the arms for 1/9 scale.
The weight of this guy is 5 grams, or 0.17 oz.
The attractiveness of this is twofold, you get a pilot that meets your scale needs and is light enough to be used in any airplane and is reproducible for the next model or for a friend.
I have standardized on 1/9th scale for my WWII fighters as they are large enough to fly and look reasonably scale and they fit my Subaru.
Doing a 1/12 scale or a 1/4 scale pilot or crew member is the same process.
I will start on the build and paot photos tomorrow all being well.
Ivor
fuelsguy is offline Find More Posts by fuelsguy
Old Oct 28, 2009, 09:07 PM
WTFLYR's Avatar
West Central PA
Joined Dec 2008
Nice job Fuelsguy. For the most part, if we want decent pilots, we have to make them. I was at the LHS yesterday, and saw a new vintage pilot there from great planes, which appeared to be the perfect scale for the WWI plane that I am working on now. At closer inspection, the Elton John sunglasses killed the whole thing. Vacuum and silicon molding are the 2 things I really need to do.
WTFLYR is offline Find More Posts by WTFLYR
Old Oct 28, 2009, 09:54 PM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I just get mine from Sparky, parkflyer plastics.
portablevcb is offline Find More Posts by portablevcb
Old Oct 28, 2009, 10:33 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
This will be an interesting thread and fills a void. I have trouble finding pilots for my big planes. 1/9th is getting close though.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Oct 28, 2009, 10:55 PM
CarreraGTSCS's Avatar
Grovers Mill, NJ (Where the Martians landed. There are still a few around. Really!)
Joined Jan 2004
I'm in.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Latest blog entry: My Favorite of Favorites
Old Oct 29, 2009, 12:57 PM
Caracas, Venezuela
Joined Oct 2008
Me too!
Guerrero is offline Find More Posts by Guerrero
Old Oct 29, 2009, 01:28 PM
glenn7e's Avatar
leicestershire uk
Joined Sep 2006
here is my contribution, one thing we have found is that the material for making the moulds is quite expensive but once you have a mould the pilots
can be produced at a very reasonable cost and the moulds should last a long time.
more later,
Glenn
glenn7e is offline Find More Posts by glenn7e
Old Oct 29, 2009, 02:15 PM
fuelsguy's Avatar
Seattle
Joined Dec 2001
OK, First, here's an overview my approach for the people who like to see the big picture before anything, here is what the process looks like speed-ed up.
1, Make a clay pilot figure and bake it, or if its air drying clay, let it air dry until it’s hard
2, Make a silicone mold of the figure. This is done by cutting a cup like shape to fit around the figure, mixing some silicone mold material and filling the cavity between the figure and the cup and waiting until the silicone hardens.
3. Make sure you can extract the figure from the silicone mold. The silicone is very flexible and can be pulled a lot to help extract the figure. (Glenn uses a two part mold which is more complicated to do, but is a little easier to deal with once it’s made, but you have a parting line on the final model to correct.)
4. Put the figure back in the mold and make a plaster of Paris support around the silicone mold, making sure you can pull the mold out of the support. The support is just to hold everything in place when casting a pilot.
5. Take the silicone mold out of the plaster of Paris support, remove the master figure and replace the mold in the support.
6, Mix up a small amount of expanding foam and pour into the mold and wait until the foam expands and hardens.
7, Remove the silicone mold from the support and then remove the pilot figure from the silicone mold
8, Paint to suit
9, install in your model or make another pilot.
I hope all this make sense,
I'll start getting into the nitty-gritty of making the master figure next post.
Ivor
Old Oct 29, 2009, 02:52 PM
Prunner
prunner's Avatar
Auburn, KS
Joined Oct 2008
What is the expanding foam called? Where did you get it? Cost? I've always wanted to try making a whole pilot or even a bust, but am afraid I'd go all OCD w/ the carving. I'd really like to extend one of the Petes Pilots busts into a full figure. Thanks
prunner is offline Find More Posts by prunner
Old Oct 29, 2009, 03:25 PM
fuelsguy's Avatar
Seattle
Joined Dec 2001
The basic material I use for making the master figure is stuff called Super Sculpey. There are lots of other clay materials around so visit your local art supply store and chat to them.
I like Sculpey because it’s easy to mold in your fingers and stays soft until you bake it for 15 minutes.
The clay is relatively hard when you take some out of the box, but if you knead it for a few minutes it becomes pliable.
For the mold making I use a Product sold by TAP Plastics although there are lots of other suppliers.
The Silicone mold material is their Platinum Silicone System, it’s a two part easy to mix product. Expensive by my standards, but you can get two molds from a 1lb kit.
http://www.tapplastics.com/shop/product.php?pid=494&
The Plaster of Paris is available everywhere.
The expanding foam is again a TAP Plastics product. A two part mix, A and B, used in equal amounts and it produces approximately 30 times the liquid volume as foam. For these pilots the trick is to make just enough or you have foam expanding all over the shop!!! My 9th scale pilot is roughly 30 cc’s in volume so I only need 0.5 cc’s of each part. That down in the less than a teaspoon range. The foam is quite hard once it has set so taking the figure out of the mold is easy. The surface sets to a good skin that just needs a few touch-ups here and there.
http://www.tapplastics.com/shop/product.php?pid=79&
As far as making full pilot figures, this approach works just as well, all you need to do is make up master figures for the head/torso and then the hips and legs. It's not a big deal, just needs some practice in making the master figures. Sculpey is nice in that regard as you can make up a figure and if you don't like it you can mash it back into a ball and start again. Quite satisfying actually, and good practice.
All for now,
Ivor
Old Oct 29, 2009, 03:53 PM
Skylakes Airport
Joined May 2009
Here are some of my foam pilots I have been making, and selling on my website smaller than yours mine are around 1/20 scale to fit my line of free flight models. I have a new set of WW2 pilots coming soon.
I have found the mold support is not needed using silicone molds, have you tried it without ?
skylake is offline Find More Posts by skylake
Old Oct 29, 2009, 04:58 PM
fuelsguy's Avatar
Seattle
Joined Dec 2001
Skylake,
Nice models, look very much like mine as far as finish and foam is concerned.
I built the support so I could try various pour compounds before settling on one. Foam is the best by far for the weight and the finish is OK. Glenn has been putting a coat of latex rubber on his two piece mold before the foam. It gives a slightly better finish but, IMHO, is not worth the effort in a full mold as it takes forever to dry the latex. I've seen commercial examples that seem to use a thick rubber compound but I haven't figured out what it is, but it still several time heavier than foam.
I'll try the no-support method this afternoon and report back.
Ivor
Old Oct 29, 2009, 05:09 PM
Skylakes Airport
Joined May 2009
I have been spraying a coat of Zinnser BIN primer on mine before painting it really helps a lot, strange stuff BIN primer. Get it at ACE hardware or Home Depot.
Old Oct 29, 2009, 05:48 PM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Guys, thank you so much for this thread. I buy Pete's and JustPilots busts, but for many of my planes I would like to have separate arms and longer torsos. My foam carving skills can best be described as marginal, so this looks like a great solution.
Cheers,
Jeff
jhspring is offline Find More Posts by jhspring
Old Oct 29, 2009, 06:44 PM
fuelsguy's Avatar
Seattle
Joined Dec 2001
Skylake,
I tried the no-support method and it looked OK but the result when I took the pilot out of the mold was a decidedly tubby pilot. There must be just enough give in the silicone rubber to let the foam push the mold out a little, or maybe its just gravity on the mold. Looks like I need the support, at least for the bigger figures.
Jeff,
Glad for the support. Tomorrow I'll get to the modeling the master pilot stage. I have thought about full body pilots, it's just a little more complicated to make the torso longer and create a lower body as a separate master and mold.
All of this does get you to the reproducible stage so you can have pilots for lots of models of the same scale.
Ivor
Making scale pilots from action figures Bomberguy Scale Electric Planes 31 Feb 01, 2012 04:57 AM
For Sale 1/8 scale koran war pilot(BOOMERs pilots) corsair nut Aircraft - Electric - Jets (FS/W) 2 Oct 16, 2009 01:20 AM
Mini-Review 1/4 scale pilots from Premier Pilots. suirendoujin Scale Sailplanes 6 Oct 03, 2009 11:11 AM
Cool New Stuff ,lights and making them look pretty garyg4rc Slope 13 Sep 26, 2009 05:54 PM
Help! Scale/Life-Like Pilots 4 1/5-1/8 Scale Electrics...WHERE 2 GET THEM?? bighank13 Trader Talk 3 Nov 23, 2008 09:00 AM
