Old Jun 24, 2010, 05:37 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I run the 10 gram, 18=11 2000kv motors on a number of planes. Very tough, reliable motor.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jun 24, 2010, 07:24 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I ordered 2 10 gram and 3 5gram motors..
I ordered the 3 5g at first and then I saw that the 10g came back in stock so I could only ordered 2 with the remaining bonus money.. unfortunately this month I'm short... so 1of the 3 warbirds I got it's gonna run on the 5g.
Which one do you think it should be? FW190, P51 Mustang or the Corsair?
Gord.. you are running on 2S, correct?
pavcon is offline Find More Posts by pavcon
Old Jun 24, 2010, 07:39 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yep, 2 cell 360s. I also solder together my own 240 ma 2 cell Zippy packs from HK. At $2.32 a piece they're hard to beat. Also very light.
Gord.
Old Jun 24, 2010, 10:32 AM
pavcon is offline
Joined Jan 2010
I got 4 turnigy single cells 360mah so I will create 2 of them
Old Jun 24, 2010, 11:01 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Are you attaching balance connectors to the homemade 2 cell packs? If so, where are you getting them?
giuseppi is offline Find More Posts by giuseppi
Old Jun 24, 2010, 11:13 AM
pavcon is offline
Joined Jan 2010
my lhs has them..
I still got an unanswered question
Is the main wing detachable with the stock plastic clips???
Old Jun 24, 2010, 11:33 AM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
I believe the answer is yes.
But what I intend to do is something similar to flypaper's method. I'm going to have to remove the foam where the front clip goes in order to fit my battery in the nose. It won't fit horizontally like vicarious'. After the foam has been removed I'll make a hole in the wing saddle on each side of the battery slot to accomodate dowels glued into the wing mount.
I'm going to tap some threads in the rear clip for a small nylon machine screw to hold the wing in place.
Did you ever figure out how to scroll through the pictures?
Old Jun 24, 2010, 11:37 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
No, no balancers on the 2 cell packs. They're 2 yrs old and still going strong.
Yes, the wing is removeable. That's how I replace the batt. If it's ugly to pop off, I pry it off with a broken propeller blade.
Gord.
Old Jun 24, 2010, 11:49 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Here's a couple of pics of the beat up P47 with the lip on the front of the wing and the button still on the back of the wing. Poor mans ails installed that works well believe it or not. Just wanted to see if it would work. Now I can clean it up a bit. P47 didn't fly wirth a sh## with rudder and el. Not enough rudder area. Mustang flies much better with R. and E.
Gord.
Old Jun 24, 2010, 04:19 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Nylon Wing Mount Screw
This is a female wing mount button adapted for a nylon screw. CA glued a piece of 3/16" dowel in the button and drilled and tapped for a 6-32 nylon machine screw.
Old Jun 24, 2010, 05:34 PM
pavcon is offline
Joined Jan 2010
the last one is even better...
Old Jun 24, 2010, 09:26 PM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Originally Posted by giuseppi View Post
The best thing to do is make a spinner out of bluefoam.
That sounds like a good way all right. But since I don't have any blue foam I was thinking of filling the inside of the original one with clay to close the openings for the stock prop and use it for a mold to Vac-U-Form on one of these little machines.
What do you think?
Good Lord!, that is an old piece of gear! I have one sitting on a shelf in the closet here. You must have been a plastic modeler who made his own parts back in the day.
(Or, have they started manufacturing them again and I just didn't know?)
Pete Miller is offline Find More Posts by Pete Miller
Old Jun 24, 2010, 09:50 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Hi Pete,
No they don't make 'em anymore. And the one I had as a kid was probably given to Goodwill after I grew up. I got it from eBay a short while back for small projects like this. There are a couple of guys making the sheets for 'em. Or sometimes an old plastic container might get cut up used.
Anyway as you can see it comes in handy for small parts.
Old Jun 25, 2010, 03:00 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
This place has them. Haven't dealt with them before but I've heard good things. One man shop, guy works out of his garage, very friendly, and fast shipping.
Or you could get the extentions from here and cut them to the size you need. I have these for both 2S and 3S and they work really good plus they come 10 to a pack. As usual shippping is kinda slow.
Eagle34 is offline Find More Posts by Eagle34
Old Jun 25, 2010, 05:42 AM
pavcon is offline
Joined Jan 2010
for those interested.. they are back in stock http://www.hobbyking.com/hobbyking/s...idProduct=4318
Discussion Banana Hobby A-10 Center of Gravity aileronjack The Builders Workshop 1 Nov 03, 2009 02:00 PM
Sold Three cox micro-warbirds plus futaba radio for sale burkefj Aircraft - Electric - Airplanes (FS/W) 8 Oct 28, 2009 12:32 PM
For Sale Cox Micro warbirds for sale skyforcecapt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 11, 2009 10:19 AM
For Sale Cox Micro Warbirds for sale skyforcecapt Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2009 10:18 AM
