Old Jun 20, 2010, 04:44 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
UNGN where do you get these spare Suhkoi parts?
Eagle34 is offline Find More Posts by Eagle34
Old Jun 20, 2010, 07:20 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Spare Sukhois.
Actually, I bought the bellcranks at the LHS for $1.50 each. Part number PKZ3523.
You can also buy them off Ebay for about $3.50 shipped
UNGN is offline Find More Posts by UNGN
Old Jun 20, 2010, 07:41 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
how bout that for an answer
pavcon is offline Find More Posts by pavcon
Old Jun 20, 2010, 07:42 AM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
what do you guys think for what size prop should I use with the park 250 and a 2 cell. I'm leaning towards a 7X6, but a second opinion wouldn;t hurt. Here are the specs:
Type: Brushless outrunner
Size: Upgrade for 180-size
Bearings or Bushings: Two 2 x 5 x 2.5mm Bearings
Recommended Prop Range: 5.5 x 4.5–8 x 6 Slow Flyer
Voltage: 6–8.4V
RPM/Volt (Kv): 2200
Resistance (Ri): .25 ohms
Idle Current (Io): .45A
Continuous Current: 7A
Maximum Burst Current: 8A (15 sec)
Cells: 6 Ni-MH/Ni-Cd or 2 Li-Po
Speed Control: 6A–10A brushless
Weight: 14 g (0.5 oz)
Overall Diameter: 22mm (.85 in)
Overall Length: 23mm (.90 in)
taekwondo is offline Find More Posts by taekwondo
Old Jun 20, 2010, 08:33 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
I found a 6 x 4 and put it on. It seems like it will have more than enough power. What a pain to get the little prop on that prop adapter. Seems kind of flimsy to me. We'll see how she does, if I have to bump up to a larger prop, I will. But the 6 x 4 seems like a good choice for now. Need to check the cg, which I forgot about as well, should have improved drastically. I like this new size motor, don't know how I did without it before.
Old Jun 20, 2010, 08:40 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
the CG is perfect, just slightly nose heavy. sweetness, I can maiden her next saturday.
Old Jun 20, 2010, 08:55 AM
pavcon is offline
Joined Jan 2010
Voltage: 6–8.4V
RPM/Volt (Kv): 2200
Ive worked with a 7x6 on another project. you won't need that much pitch on those planes. only thing you will achieve is more amp draw that will drain your battery faster. I would agree with taekwondo for the prop... 6x4 should work fine
Old Jun 20, 2010, 08:58 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
UNGN man that is some box of busted up planes! Great idea for what you are doing with them though.
Old Jun 20, 2010, 09:48 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
Thanks for the recommendation Pavcon.
Originally Posted by pavcon View Post
Ive worked with a 7x6 on another project. you won't need that much pitch on those planes. only thing you will manage is more amp draw that will drain your battery faster. I would agree with taekwondo for the prop... 6x4 should work fine
Old Jun 20, 2010, 03:09 PM
madmike8 is offline
Find More Posts by madmike8
madmike8's Avatar
USA, TN, Fayetteville
Joined Dec 2004
Hmmm... The Stock motor with stock prop doesn't seem to have too much pull... The 300mah lipo hand launched only had enough power for a power assisted landing... Tried a 800mah pack and seemed to have enough power to fly it... until the prop flew off... I forgot to bring the second prop so, I called it a day... Not sure if it's the brushed motor not broke in, or I need to try a different prop. Either way I'm off to the search button to see what I can dig up.
BTW RC Timer 3.5g servos have a lot of travel. I had set the control rods on the outside hole of the servo and the middle of the stock control horn. I had about 55 degrees of deflection.... Laugh... I set the end points down to 60 percent...
madmike8 is offline Find More Posts by madmike8
Old Jun 20, 2010, 03:30 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Hey Madmike,
I'm gonna build a P-40 that's been under the bed for a couple of years now and I'm going with the stock motor. I'll go back and check the original threads for the information on weight with the stock motor ( as there were guys successfully flyin' 'em that way ) but I'd really like to know what yours weighs with the battery and all.
If I remember correctly you want to be four ounces (maybe it was 4 1/2 ) or less with a stock motor. Weight is a definite issue when using the stock motor.
Also, you may be correct that the motor needs breaking in.
giuseppi is offline Find More Posts by giuseppi
Old Jun 20, 2010, 04:02 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I bought 6 broken Sukhois off E-bay for about $130 shipped & I got 3 usable airframes needing tails, 5 good bricks, 5 good servos, 3 RTF TX's, 3 extra good wings + misc motors gearboxes and chargers.
I also bought 6 Mustangs for $195 shipped which I got 2 DX5's, 2 RTF TX's and enough stuff to make 2 good Mustangs + a P-82 Twin Mustang & have Bricks, servos and P-51 motors left over for My other Micros.
Old Jun 20, 2010, 04:26 PM
pavcon is offline
Joined Jan 2010
ohhh my personal favourite P51
Old Jun 20, 2010, 04:49 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by giuseppi View Post
Hey Madmike,
Make it with Ailerons. I wasn't happy at all with the way my Rudder/Elevator P-40 flew.
It would drop a wing and take 15 feet of altitude to recover.
Old Jun 20, 2010, 08:37 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Originally Posted by madmike8 View Post
Hmmm... The Stock motor with stock prop doesn't seem to have too much pull... until the prop flew off...
I was wondering about the stock motor and how the prop simply pushes on... and that's it! If I was going to use this method I'd put a single drop of CA to help hold it in place.
I've seen these auctions on eBay and looked at them with green envy. I'm in Australia and the shipping makes the deal not worthy.
Surely you must have a spare brick you'd like to sell to me?
Slaanesh is offline Find More Posts by Slaanesh
Discussion Banana Hobby A-10 Center of Gravity aileronjack The Builders Workshop 1 Nov 03, 2009 02:00 PM
Sold Three cox micro-warbirds plus futaba radio for sale burkefj Aircraft - Electric - Airplanes (FS/W) 8 Oct 28, 2009 12:32 PM
For Sale Cox Micro warbirds for sale skyforcecapt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 11, 2009 10:19 AM
For Sale Cox Micro Warbirds for sale skyforcecapt Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2009 10:18 AM
