Old May 02, 2010, 04:39 AM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
I myself have been hearing people use eiher a 5 gm or 10 gm motor for these, with most using the 10g from hobbyking. Since 8gm is the one your thinking about, it should be very doable. I'm no expert, but these guys here are and I will post the specs of your motor, I think its a good choice. if you built the plane to be auw up around 4 ozs. you should have a thrust/weight ratio of l to 1 which will make for an excellent flyer. Opinions gentlemen?
Tested with AEO E-Power 5A ESC
7V: 0.25A @ 14550RPM
8V: 0.30A @ 16740RPM
10V: 0.35A @ 20850RPM
Weight: 8g
Max Power: 4A or 40W
Dimension: 17.8*20mm
Length of shaft: 5mm
Diameter of shaft: 2mm
Tested with GWS 4.5x4 Propeller
Volts Amps Watts RPM Pitch Speed (m/s) Thrust(g) Thrust(oz) Efficiency(g/W) Efficiency(oz/W)
7 2.0 14 9300 15.75 76 2.68 5.43 0.19
7.5 2.2 16 9720 16.46 82 2.89 5.13 0.18
8 2.3 18 10170 17.22 89 3.14 4.94 0.17
9 2.6 23 11040 18.69 108 3.81 4.70 0.17
10 2.9 29 11640 19.71 121 4.27 4.17 0.15
11.1 3.3 35 12210 20.68 135 4.76 3.86 0.14
Tested with GWS 5x3 Propeller
7 1.9 13 9930 12.61 91 3.21 7.00 0.25
7.5 2.0 15 10320 13.11 99 3.49 6.60 0.23
8 2.2 17 10800 13.72 108 3.81 6.35 0.22
9 2.5 22 11730 14.90 129 4.55 5.86 0.21
10 2.8 28 12480 15.85 145 5.11 5.18 0.18
11.1 3.1 33 13110 16.65 163 5.75 4.94 0.17
Tested with GWS 6x3 Propeller
7 2.4 17 8250 10.48 111 3.92 6.53 0.23
7.5 2.6 19 8430 10.71 120 4.23 6.32 0.22
Originally Posted by Lilbanks96 View Post
Sorry for the double post but i was wondering if this motor would be ok for one of these birdshttp://www.hobbypartz.com/88e-mm201-...or-2100kv.html
taekwondo is offline Find More Posts by taekwondo
Old May 02, 2010, 02:04 PM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
Hey rotatorus, here's one to go with your Spitfire on floats. Page I found it on is in the picture description.
thewildweasel is offline Find More Posts by thewildweasel
Old May 02, 2010, 02:48 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
It's odd, but with the size of those floats, I cant imagine this plane flying well. How much do they weigh in comparison to the plane?
Old May 02, 2010, 03:21 PM
Rotatorus is offline
Find More Posts by Rotatorus
Rotatorus's Avatar
's-Hertogenbosch, The Netherlands
Joined Apr 2006
Hi Wild Weasel,
You had to show me.. Now I need to make another one. I have not seen this version before. It does seem as if it's pylons are very long. Other than that, it is certainly a nice one to put on the to do list. I'll look some more for additional information on this bird.
The floats itself look pretty OK. They are not much different as on the spitfire.
I have another project on my mind now and I'm not going to tell what it is... Ok, one thing I'll say... It has two engines .
Robert
Rotatorus is offline Find More Posts by Rotatorus
Old May 02, 2010, 03:24 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
what size are your floats robert? How many inches or centim.
Old May 02, 2010, 04:01 PM
Rotatorus's Avatar
Joined Apr 2006
The ME109W is a hoax. As far as my short research has shown, the plane never existed. I did find another build that could take it's place. A French prototype... Dewoitine HD780.
Does anybody have images of this plane? I see two floats, a F4U wing and a P-40 fuse... .
Robert
Old May 02, 2010, 04:06 PM
Rotatorus's Avatar
Joined Apr 2006
Hi teakwondo,
The floats I used are aproximately 35 cm / 14 inch tall. Are you thinking of bashing a kit into a floatplane as well?
I made two movies today but both were to big for upload... I need to find some time to do it once again and leave out even more. Otherwise you could have seen the plane in the water with the waves and wind and all.
Robert
Old May 02, 2010, 06:54 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
I might if they had a plane more conducive to floats, such as a beaver or J3. Maybe one day when I get my j3 flying, I can use that.
Old May 03, 2010, 06:55 AM
tgg61 is offline
Find More Posts by tgg61
St.paul, MN
Joined May 2005
Just a quick add-on to Roberts post
tgg61 is offline Find More Posts by tgg61
Old May 03, 2010, 10:28 AM
Rotatorus's Avatar
Joined Apr 2006
Hi TGG61,
Thank you for your additional 3 view. It will come in handy when I give this one a try.
Robert
Old May 03, 2010, 12:10 PM
skywarp1 is offline
Find More Posts by skywarp1
Long live the Nuge!!!
skywarp1's Avatar
South Central......Kansas
Joined Oct 2007
I did a little research and found that the Me 109 on floats was reported to have been considered, but never acutally built. Plans were made for it. I found this link to a site, it is all in Japanese, but if you scroll down you can see some of the plans.
http://home.catv.ne.jp/kk/galland/bf109w/bf109w1.html
skywarp1 is offline Find More Posts by skywarp1
Old May 03, 2010, 01:26 PM
Rich11111 is offline
Find More Posts by Rich11111
Corpus Christi, Tx
Joined Jan 2010
push rods
Is the use of carbon fiber rods a good alternative to the wire provided in the Gravity Hobby Kit?
Hoping to avoid epoxy and rod tubes as in some of the builds of the Atomic Builds.
What size CF? 1mm?
Rich11111 is offline Find More Posts by Rich11111
Old May 03, 2010, 02:53 PM
Rotatorus's Avatar
Joined Apr 2006
Hi Rich,
Carbon is a good alternative to steel pushrods. The Kyosho minium series have carbon rods with steel z-bends at the ends. They can be connected by thread and shrink-tubing. Add some glue and you can get a pretty stiff connection. You will have to check the stiffness of the rod at the desired lenght but 1 mm carbon probably will do the job.
Robert
Old May 03, 2010, 03:10 PM
Rotatorus's Avatar
Joined Apr 2006
Hi skywarp,
I have seen the site but it does not strike as reliable. The image shows an Emile on floats. But it is not clear if it is fake or not. Anybody can photoshop floats under an Emile. Other sites have had this discussion as well.
There might have been ideas for a floatfighter and it could have been an ME109E. However the pictures seen do not strike as correct.
Robert
Old May 03, 2010, 03:12 PM
Rotatorus's Avatar
Joined Apr 2006
Some other ideas for float planes can be found here:
http://www.olddogsplanes.com/floatplanes.html
Robert
Discussion Banana Hobby A-10 Center of Gravity aileronjack The Builders Workshop 1 Nov 03, 2009 02:00 PM
Sold Three cox micro-warbirds plus futaba radio for sale burkefj Aircraft - Electric - Airplanes (FS/W) 8 Oct 28, 2009 12:32 PM
For Sale Cox Micro warbirds for sale skyforcecapt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 11, 2009 10:19 AM
For Sale Cox Micro Warbirds for sale skyforcecapt Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2009 10:18 AM
