Dec 14, 2010, 11:53 PM
USA, OH, Akron
Joined Dec 2006
Originally Posted by dunbar58
Modify, thanks for that, I just noticed Joe 1320 had this as a standard upgrade on his planes and several others made comment that with an outrunner the wings can fold. So if I convert to ailerons on the Zero is 5 degrees wing dihedral enough? Mark
Enough for what? You should decrease the dihedral on a plane with ailerons. The stock dihedral is OK and ailerons will work with the stock wings. Joe 1320 makes ATOMIC planes as he calls them and I suppose they are very fast and perhaps very heavy. I subscribe to a "light is right" build theory using AR6400 Tech and leaving the CF reinforcements and glassing off the plane. This is a left over vestige from the days of heavy wing loading. Todays planes no longer need all that reinforcement due to the lighter electronics available. Also keep the lipo small say 350 mah or less to keep the weight down. They fly so much better with light wing loading IMO. Maybe not ATOMIC blazing fast but fast enough and makes for a good flying plane instead of a flying brick.
The plane in the video I posted uses a 10g outrunner and a 2s 350 mah lipo with a AR6400 brick and dual AS2000 aileron servos. AUW = 4.5 oz
Here is another P-47 video
