Old Dec 19, 2009, 05:51 PM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
I have that 11 gram motor but haven't used mine. I just threw a Park 250 into my spitfire. This should be fun....=)
danrc is offline Find More Posts by danrc
Old Dec 19, 2009, 07:14 PM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Originally Posted by Ralph_D View Post
Really? So no huge need to use ailerons?
Nope, not a huge need. I should really post my video of
my Corsair flying indoors. Don't get me wrong, just because
I don't have ailerons doesn't mean I won't put them in another model at
some point in the near future.
will3kgt is offline Find More Posts by will3kgt
Old Dec 19, 2009, 08:10 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by splatman View Post
Tex,
Are you cutting hatches for lipo access in your warbirds?
I would. If you put strips of CF at the hatch opening, you don't weaken the structure too much, if at all.
UNGN is offline Find More Posts by UNGN
Old Dec 19, 2009, 09:37 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by smasher41 View Post
here ya go!
If it flies well, I plan to add a 2 cel lipo pack that weighs about the same as the stock nimh, as well as a lipo speed control for proper LVC
Also I plan to use some carbon fiber rod and small wheels, probably from a gillows FF plane to put 4 wheels in back and 1 in front. We have a nice long parking lot beside the soccer field at the park i fly at
Did you fly your Cargo plane yet Smasher?
Sammy70 is offline Find More Posts by Sammy70
Old Dec 20, 2009, 01:35 AM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
Nope, I jinxed myself, Had friday off and it rained all day and night, and today I worked 9am to 8pm, and there was winds off excess of 14mph. If it is calm tomarrow or monday I will be able to try it
However, in the mean time Im looking into possible options of a "drop in" size 2 cell lipo pack. THe battery tray area appears to be able to be "popped" out with a little force to break the glue, without damaging the body, should make install of a larger battery much easier.
The real problem is my mustang seems running out of room to carry planes!! with a totally full trunk, back seat, and passanger seat when driving to the field.
smasher41 is offline Find More Posts by smasher41
Old Dec 20, 2009, 10:11 AM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
So anyones elses thoughts on motor choices?
Originally Posted by EyeFlyPlanes View Post
Hey guys so my mustang came in yesterday, looks great. Ordered Saturday cam in following Friday, from Florida to Cali. Not bad. Anyways I've got 2 motors here and I'm still deciding which one to put in. Both on a 3 cell lipo & 4025 prop..
One is 2200kv @ 9.2g with 145g of thrust.
http://hobbycity.com/hobbycity/store...rust_Outrunner
And the other is 3500kv @ 11g with 220g of thrust.
http://hobbycity.com/hobbycity/store..._3500kv_(11g)#
I'm thinkin the 3500kv motor, it's like 2 grams heavier for 75g more thrust. Seems to make sense.
Thoughts?
Also I've got the ar6300 rx @ 2 grams
2 x 3.7g servos
8a esc @ 7 grams
what should be my auw?
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Dec 20, 2009, 10:37 AM
[]TEX[] is offline
Find More Posts by []TEX[]
Northeast Illinois
Joined Dec 2007
Tex,
No I modify the fuse to easily remove the battery through the wing attaches. I can post pics if you'd like. Very simple mod.
[]TEX[] is offline Find More Posts by []TEX[]
Old Dec 20, 2009, 11:54 AM
aeronaught is offline
Find More Posts by aeronaught
AAces High
aeronaught's Avatar
United States, VA, Midlothian
Joined Feb 2009
Questions
I'm still really new to this stuff. I've only been in the hobby for a year. I have a Park 250 that I have in my E-Flight SE5a with a 10 amp esc. And I use my Mini Super Cub 7.4v 350mAh batteries with it. I also have two small servos ( I can't remember but I think they are 4.9 gram). Would this gear be OK for one of these airframes?
Thanks in advance,
Reset
aeronaught is offline Find More Posts by aeronaught
Old Dec 20, 2009, 12:08 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
I've found you have to have the battery as far forward as you can for CG. I was going to cut a hatch in the nose, but if you can do this from the wing opening, I'd like to see how you do it.
Angelo is online now Find More Posts by Angelo
Old Dec 20, 2009, 12:16 PM
[]TEX[] is offline
Northeast Illinois
Joined Dec 2007
Yes, mine actually sits right behind the firewall.
I will post pics.
Old Dec 20, 2009, 02:25 PM
splatman is offline
Find More Posts by splatman
Vertical Wake
splatman's Avatar
visalia ca
Joined Dec 2002
I will post pics.
I hate cutting into these great looking fuses!
splatman is offline Find More Posts by splatman
Old Dec 20, 2009, 03:26 PM
So Cal FPV Aviator
Joined Feb 2008
Has anyone tried using rare earth magnets for holding the fuse halves together? The ones radio shack sells are super tiny and light. I was thinkin about picking up like 4 pairs.
Thoughts?
Old Dec 20, 2009, 04:12 PM
[]TEX[] is offline
Northeast Illinois
Joined Dec 2007
Here you go. The pin is a scrap piece of a push rod. I used hot glue to affix it. I re-enforced the fuse area with foam safe CA. Plenty of flights and hard landings.
4oz AUW
Old Dec 20, 2009, 04:17 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Thoughts?
I use magnets to hold hatches on, but holding the Fuse halves would be a tough trick.
A glued fuselage is going to be much stronger in torsion and lateral bending, because the magnets are strong when pulling them apart, but are much weaker when sliding them apart. I have a bunch of magnets that are smaller and much stronger than the radio shack magnets, but I wouldn't even attempt trying to hold the fuse halves together (My Aeronautical Engineering background won't let me)
The best source for magnets is K&J Magnetics.
Old Dec 20, 2009, 04:25 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
4oz AUW
I thought about doing this, but Ailerons in the wings mess with the rear mount and I didn't want to cut both off, since they do a good job of centering the wing.
Discussion Banana Hobby A-10 Center of Gravity aileronjack The Builders Workshop 1 Nov 03, 2009 02:00 PM
Sold Three cox micro-warbirds plus futaba radio for sale burkefj Aircraft - Electric - Airplanes (FS/W) 8 Oct 28, 2009 12:32 PM
For Sale Cox Micro warbirds for sale skyforcecapt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 11, 2009 10:19 AM
For Sale Cox Micro Warbirds for sale skyforcecapt Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2009 10:18 AM
