BTW-I miss the country name Cyprus on your avatar. Now, it looks almost russian. AJ |
AJ |
My first FW 190 with the 610 mAh did need to come in pretty fast for landings, but it was the only free battery I had at the time.
The motor was perfectly fine on 3S, never got more than warm to the touch if that. Of course it did had tons of power with a 5x4.3 or 5x3 prop. Here are some pics or the aileron and battery hatch setup on my new FW. |
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Fisticuffs I made the same thing with my FW190 as concern the ailerons but ofcourse it was my first mini warbird and it's not such a clean job.
The problem with mine is that the ailerons didn't give the roll rate that I wanted so U cut 4cm and extended the ailerons.. that gave me some better roll rate but I won't take the risk to try a full roll...maybe I didn't get the throw to be enough.. can you post a picture with a full throw at the ailerons? |
I was originally going to use 2mm connectors but when I weighed a complete set decided not too. I used a standard servo connector instead (which can be easily reversed to get the motor to spin the right direction). Quote:
Also, I'm just wondering, can you reverse the shaft of the HK 10g brushless outrunners (and for that matter the 5g outrunners)? If you can, I think by far the easiest and lightest way to mount these would be a little firewall directly at the very nose of the plane (where the 'scale engine' piece would go). |
Brisbane Australia
Joined Sep 2009
Hi mark here from Australia, a lot of guys refer to the HK 18-11 2000 Kv motor on 2s but has anyone got experience on the HK 1818 3500Kv motor and 2s? I already have a couple of these and would like to use them if possible...and what prop would be recommended?
Whilst it's a good motor and would have served it's purpose, it's not really what I wanted on my model - I wanted to swing a 6" prop at low amps. So I looked for other motors and read a lot about how good the 18-11 10g outrunner was - though it wasn't in stock on HK at the time. In the end I thought the AD-100L 1850KV was ideal (though slightly heavy at 13g). However I justified the extra weight because I read from others how the Cox Warbirds would often come out tail heavy with brushless conversions and it's ability to swing a 6" prop and draw only ~2 amps. ![]() I'm hoping this will mean half throttle will probably be plenty and give excellent long flights with a 350mah pack. However, the tail heavy aspect is not really a problem - you can easily use light motors as if you plan things out there's plenty of space inside to balance the model correctly with out needing ballast. I think this motor will work, however you will probably want to run a small prop. The stock prop is about 4x2.5" so is ideal. If that works for you, go for it. EDIT: By the way if anyone is interested in the 2.4Ghz DSM2 compat receivers popped up in HK and promptly sold out in under half an hour. I ordered a few :-) |
| Thread Tools | |
| Discussion Banana Hobby A-10 Center of Gravity | aileronjack | The Builders Workshop | 1 | Nov 03, 2009 02:00 PM |
| Sold Three cox micro-warbirds plus futaba radio for sale | burkefj | Aircraft - Electric - Airplanes (FS/W) | 8 | Oct 28, 2009 12:32 PM |
| For Sale Cox Micro warbirds for sale | skyforcecapt | Aircraft - Electric - Micro & Indoor Airplanes | 3 | Oct 11, 2009 10:19 AM |
| For Sale Cox Micro Warbirds for sale | skyforcecapt | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 11, 2009 10:18 AM |
