Go Back   RC Groups > Aircraft - Sailplanes > Hand Launch
Old Nov 04, 2009, 05:38 PM   #16
jrerickson
jrerickson's Avatar
I'm using a 350 mah NiMH 1/3 AA pack which weighs around 34 grams. I have a Futaba 617 2.4 ghz receiver. 2 Dymond 4.7's and two 6 gram servos. My boom length is 28" from end to end. The rudder is cut into the boom 1 5/8". AUW is around 9.6 oz, but this is prior to fixing the cg. I may try it at a slightly forward position then move it back. If you use the lighter batteries and no regulator (bad idea?) you will be closer.
John
Originally Posted by mpodder View Post
Hi John
I have a Low Wing D-tube on order and was wondering which servos you use and how long you made the boom. I know Bob used all 9 g servos and had to add tail weight. I'm planning on going back to D4.7s and RC Builders 19.5 g lipo, without a reg, to try and get ballance without tail weight and an 83mm CG. What do you think?
Maurice
jrerickson is online now Find More Posts by jrerickson   Reply With Quote
Old Nov 04, 2009, 07:32 PM   #17
I have a 2 cell Lipo and Berg 4ch with 4 D47 servos. I had a NiMH with Hitec Electron 6 before and had to put weight in the tail. The plane is MUCH better in the lighter configuration. The tail weight was bad for the launch, causing hooking to the left. I am now able to compete on an even footing with the famous low wing where before it was just a plane to fly at the park and knock around with.
G Norsworthy is offline Find More Posts by G Norsworthy   Reply With Quote
Old Nov 05, 2009, 12:18 AM   #18
Maurice
Why is no regulator a bad idea John? I did call Hitec and they said an Electon6 will handle 8.4v. D4.7 are rated at 9.6. I did put this set up in my Taboo Gt and it worked well though I only ran it for a few hrs of operation. I respect your advice and your experience so where am I missing it?
Maurice
mpodder is offline Find More Posts by mpodder   Reply With Quote
Old Nov 05, 2009, 09:45 AM   #19
Walter Roos
Quick Comment
Sorry, I know this thread is about "HJZ Predator Challenge, NorCal, 11/15/09"
but feel I should comment on higher voltages for the servos. Using a higher voltage on the servos will make them move faster and have more power, but at a cost. They will draw more current, run hotter and have a shorter motor life. I can't say I have tested this , but it should be correct electrically speaking. Does this hurt us in DGL, I don't know and have no idea of the difference in motor life span. I'm pretty certain we don't need the extra speed, probably more power (torque ) would be good, and with the larger Lipo batteries, then the higher current draw would not matter. I just thought you guys should at least know the pros and cons. Probably non of what I have said will matter one bit
Running one Lipo on a 40" DLG with 4 D47s the servo current used dropped down to about half or less of the current used in my 60" DLGs with 4 D47s. I can't tell any difference in control response between the 40" and 60" gliders.
walt
Bob, it's ok with me if you want to, or have the moderator do it, to move all this stuff to my "minor questions thread" if it's messing up your thread here. I have no idea of how all that works.
ROOSWH is offline Find More Posts by ROOSWH   Reply With Quote
Old Nov 05, 2009, 11:05 AM   #20
jrerickson
jrerickson's Avatar
Maurice,
I'm just speaking out of manufacturer recommendations. I'm sure the receiver and servos can handle 7.4 volts. I think the life is going to be shortened on the servos, but if it works for you, go for it. ASK, for example, sells a 7.4v 2 cell lipo pack but he also sells a regulator that drops the voltage down. I just think of it as "redlining" a small servo and I don't want to replace it if I can avoid it.
John
Maurice
Old Nov 05, 2009, 11:28 AM   #21
Here is the lift!
rcgeorge's Avatar
Maurice
That is no problem, my Blaster-2 for one year. It has D60's wing, D47 in fuse. With 2 cell lipo no reg. I still have this DLG and works just fine. I usually crash in midair or blow up on launch before bad servo.
rcgeorge is offline Find More Posts by rcgeorge   Reply With Quote
Old Nov 10, 2009, 01:11 AM   #22
Kai@UCSB's Avatar
Send a message via ICQ to Kai@UCSB Send a message via MSN to Kai@UCSB
Woooo....
We have 22 ~ 26 pilots registered now !!
Bob M. 2.4, Predator
AJ M 2.4, Predator
Kai 2.4, Predator
Mitch 13, Predator
Marcin 2.4, Predator
Don C, Raven
Greg 35, 37, Predator
Dom 34, Predator
Yaniv, Predator
Stephan, 2.4 Own Zone
Ron L 34 or 45 or 46, Predator
Mike P 33 and 57, Mini FW
John F. 50 or 52, Raven
Tom K 22, Vandal
Mike B 2.4, Predator
Duncan 2.4, FW4
Craig
Bruce M., Predator
Bob B, Mimi
Jack, Predator
Charlie, Taboo
Rich B, Predator
VespaBob
Kevin Predator
Kai@UCSB is offline Find More Posts by Kai@UCSB   Reply With Quote
Old Nov 10, 2009, 07:55 AM   #23
Here is the lift!
rcgeorge's Avatar
Man you should have lots of fun, Take it to them Kai.
Old Nov 10, 2009, 07:45 PM   #24
This is getting big!
We are up to 28 pilots on the list now. It looks like we may have around 18 contestants in Predator 2 class alone.
There is no doubt that CJ’s generosity with the Predator 2 raffle and booms is helping bring people out. Many of these people are from our Predator 2 group buy so again, credit to CJ for providing an economical model that can win contests. The Predator 2 coming on the market has provided a real surge in our Bay Area DLG activity. Thanks CJ!
I am so pleased with the projected turn out. Thanks for signing up everyone!! It really will be great to see everyone again and meet the couple new guys coming out.
With anything over about 20 people we will need to split into 3 flight groups. It looks like that is what we will do. This is a good thing because that means you can get in some breaks during the day to visit, rest, and look around rather than constantly being on the go with flying or timing duties. With 3 flight groups, we’ll fly four rounds rather than our typical five and we’ll still get off the field at about the same time as usual. I expect we’ll be packing up and leaving the field for Pizza Depot at around 1:30.
The tasks for the day will be:
- Round 1: Best 5 flights, 2 minute max.
- Round 2: 1, 2, 3, and 4 minute max flights, any order
- Round 3: Best 3 flights, 3 minute max
- Round 4: Best 4 flights, 2.5 minute max
All rounds will have a 10 minute working time window.
We will explain in more detail at the pilots meeting.
  • Name: DSC02214.jpg
Description: Predator 2, standard high wing Predator 2, standard high wing 11.2 KB · Views: 38
  • Name: DSC02297.jpg
Bob McGowan is offline Find More Posts by Bob McGowan   Reply With Quote
Old Nov 11, 2009, 09:08 AM   #25
RubSon's Avatar
Hi Bob.
Sure would have liked to be there No doubt!
In Denmark we would like some feedback on the 4 X 2,5 min task.
So please... tell us how it went and how the contestants thougth about it.
I know i´m early, but better safe than sorry
Ruben
RubSon is offline Find More Posts by RubSon   Reply With Quote
Old Nov 14, 2009, 08:56 PM   #26
jrerickson
jrerickson's Avatar
Greg,
Just got a 300 mah 2 cell Lipo pack that weighs 16 grams. I cut out nearly 18 grams of battery weight and I also got to get rid of the tail weight. The plane really floats now. I'm at 256 g AUW and I'm pretty sure I'm throwing around 165'. I'm going to put a RAM3 in tomorrow and get some charts.
Good luck all you Predator owners! Wish I could be there.
John
Old Nov 15, 2009, 10:12 PM   #27
the score;
C. J. Hung is online now Find More Posts by C. J. Hung   Reply With Quote
Old Nov 15, 2009, 10:50 PM   #28
Kai@UCSB's Avatar
Score
  • Name: NovDLG_overall.JPG
  • Name: NovDLG_R1.JPG
  • Name: NovDLG_R2.JPG
  • Name: NovDLG_R3.JPG
  • Name: NovDLG_R4.JPG
Old Nov 15, 2009, 10:51 PM   #29
Kai@UCSB's Avatar
Originally Posted by C. J. Hung View Post
the score;
Sorry that there is typo there...
The 1st pilot, Yaniv, actually flies his own Twister.
The condition is very less wind but very weak lift too.
More pictures and reports will come.
Bob M. got shut down at the first round...
Kai was keep making wrong decision that he could ever make... ...
-Kai
Old Nov 15, 2009, 10:56 PM   #30
Kai@UCSB's Avatar
YES, we have 29 pilots show up!!
Some pictures before the contest...
And here is some nice pictures by Mike B. http://battlewing.net/photo_gallery/...enge/index.htm
  • Name: IMG_4406.jpg
  • Name: IMG_4407.jpg
  • Name: IMG_4408.jpg
  • Name: IMG_4409.jpg
  • Name: IMG_4410.jpg
Build Log HJZ-Model Predator-II DLG Build Tread Kai@UCSB Hand Launch 132 Today 10:39 AM
Cool The Official HJZ-Model Predator-II Thread Kai@UCSB Hand Launch 183 Nov 13, 2009 03:07 AM
Swap Meet NorCal: HUGE SWAP MEET at R/C Country Hobbies, 9-12-09 !!! JWink Electric Flight Events 4 Sep 13, 2009 01:48 AM
Sold HJZ-Model Predator-II DLG (2 available) atlav8r Aircraft - Sailplanes (FS/W) 7 Jun 19, 2009 04:46 PM
Discussion HJZ-Model Predator-II DLG -- Bay Area Group Buy Kai@UCSB South Bay Soaring Society 0 Feb 05, 2009 06:06 PM
Bored? Want to fight?
Join the RCGroups clan!
